Question about LG DLE2514 Electric Dryer
Vibration my lg dle2514 dryer vibrates loudly. This vibration sounds as if it coming from the area of the drum
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
The noise on the wheels was usually a thumping noise and it went away after they heated up. Came back as it cooled down and a new flat spot was made. It is possible that the rollers have worn out in such a way that they have bumps in them and or the drum itself may have a bad joint that caused damage to them. Inspect them both. The drum has a part warranty of 5 years from date of purchase.
Sgt 48
Posted on Jun 07, 2008
I had a technician out who said it is the nylon wheels - when it's cold outside the dryer drum is cold - once you start the drryer ( I know it's very loud) the wheels warm up and quiet down - you can order new wheels I think - different material.
Posted on May 18, 2008
What is cause of loud vibration noise
In most cases, vibration sounds come from which ever helps the drum to spin with no resistance, In most cases those would be drum support wheels or bearings depending on the model.
In some rare cases, blower or belt pulley could also cause similar symptoms.
Feb 11, 2015 | Dryers
LG DLE3733 loud vibration from bottom
If that vibration is while running it may be from an imbalance of the clothes in the drum. Open the door, when the drum stops reorder the clothes around the drum and see if the rumbling stops.
Jan 22, 2013 | LG DLE3733 Electric Dryer
Loud vibration
Lot of these dryer had a split or defect in the drum. They will give a free drum but ya gotta pay labor to replace it.
MY LG dryer service manuals and repair videos
Nov 16, 2012 | LG Home Applaince LG DLE2301W 7.3 Cu. Ft....
LG DLE 2514W DRYER MAKES RUMBLING NOISE WHILE RUNNING
Hi Willie Bolden
Sounds like your problem is drum rollers are in need of lubrication or replacement.
Go to the following webpage for a schematic of your dryer and parts.
Please take time to rate me
Bud
http://www.appliancepartspros.com/parts-for-lg-dle2514w-abweeus.html
Oct 11, 2012 | LG DLE2514 Electric Dryer
Loud rumble sound, Vent hose vibration
That model of neptune dryer had a problem with the blower housings cracking. When the housing cracks, it binds forward into the blower wheel making a loud "rumble" noise and vibration. If you open the door and manually turn the drum and you hear a rubbing noise and feel alot of resistance, then you have a cracked blower housing and need to replace it. It is not an easy job to replace, so if your not familiar with dryers, you should have a technician replace it. Let me know if you have any further questions. shane
Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Makes a loud vibrating sound when its on
It is most likely the rollers the drum rest on , they wearout commonly and are not expensive to replace.
Phil
Apr 14, 2009 | Dryers
LG DLE7177WM began making loud RuMbLiNg sound.
I have the same problem; pulled it apart and discovered the drum was cracked at the seam where it was welded. the noise occurs as it passes over the wheels the drum rests on. called LG's Cusomer Diservice and nobody was interested. found the same problems by others while searching myself so its clearly a manufacturing problem.
Jan 24, 2009 | LG DLE7177 Dryer
Kenmore electric dryer vibrates loudly
Yes the kenmore uses the roller wheels . dr fixit in the service providers has them. Any way I can help otherwise?
Dec 15, 2008 | Kenmore 659 Electric Dryer
LG DLE2514 Electric Dryer Logo
199 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
