Question about NorStar T7316E Corded Phone
Norstar System I would like to know how to access the Set Relocation Menu from my 7324 phone
  • 60 Answers
Set relocation needs to be turned on from the Admininstration programming, under station config. You turn it on per station. This can be a problematic feature, use it with caution.
Dan
Posted on Jul 29, 2009
I have M 7324 phone and how we can turn off paging on one phone
Do Not Disturb will do it temporarily, otherwise you have to go into system programming, (via Ftr**CONFIG"), "Terminals and Sets", select that set, then "Capabilities", then go to "Paging Zones" and change to none. If this doesn't make any sense to you, you should ask your System Administrator.
Apr 09, 2014 | NorStar Meridian M7310 Phone
We want to relocate phones but keep the original extension numbers. Following the 'set relocation' instructions we're unable to do this. After entering the 'system programming' the
FYI
23646 spell Admin and contains onsite Admin programming.
266344 spells Config and is where tech programming is, be careful int there.
Jul 20, 2012 | NorStar M7310 Corded Phone
Installed this NT9K08AD03 where a NT8B30AD03 was and the new phone does not work. Meridian Compact ICS 2.0
The M2008 set (NT9K08AD03) doesn't work on a CICS system. It works with the Meridian PBX systems. The type of sets that work with a Compact ICS system are M 7100, 7208, 7310, 7324 and T 7100, 7208, 7316, 7316e as well as some of thier cordless sets.
Oct 01, 2010 | NorStar M2008 PBX Phone (nt9k08ad03)
Feature
Programming system speed dial numbers can be done for any extension providing that the telephone set is a model M 7310, M 7324 or a T7316. Are you trying to reprogram it with a 7208?
Feb 26, 2010 | NorStar M7310 Phone
We relocated a M7310 phone and it kept the extension of where it used to be. I need to change it to the extension it's at now and I've tried finding the Set Relocation option but I think our phones are too...
First, move the telephone sets back to where they were.
Next, we'll have to change the system programming2.gif.
Programming2.gif is done on 7310, 7324 and 7316 type sets.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the next key 7 times(bottom right arrow).
The display should say system programming.
Press the show key (top right arrow)
The display should say hunt groups
Press the next key 2 times(bottom right arrow) .
The display should say Featr Settings
Press the show key (top right arrow) .
The display say Backgrnd music2.gif.
press the next key 20 times (bottom right arrow)..
The display should say set relocation.
Press the chng key. change from N to Y.
Press the release key when finished
Move sets from their old locations to their new locations
Oct 08, 2009 | NorStar M7310 Corded Phone
Are you able to move or change extensions?
Next, we'll have to change the system programming.
Sep 28, 2009 | NorStar Meridian M7310 Phone
Norstar 7324 time change
Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 266344 which also is Feature * * config.
If asked for a password enter 23646.
When in programming2.gif just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, just press back (lower left)
Example: To change the Time & Date Press next until you see Time & Date. Then show Then change Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
Sep 21, 2009 | NorStar Meridian M7310 Phone
My Norstar M7208 phone wont ring. We've moved into a new facility and the ringer does not work now.
Is set relocation on?
If not then probably what has happened is that the new station port does not have ringing programming of the old port.
if you know how to do this go into riging programming of the set and activate it
Aug 03, 2009 | NorStar M7208 Corded Phone
How do i get to system programming on my norstar m7310 to get to auto relocate
Enter Administration Mode
  • Using you telephone set push feature * * 266344
  • Display will read Password
  • Using you telephone set enter password: 2 6 6 3 4 4
  • Display will read Configuration
  • Press Show
  • Display will read Trk/Line Data
  • Press Show
  • Display will read Sys speed dial
  • Press Next several times until the display reads Set relocation: Y or N
  • Press Change until the phone displays Y for ON or N for OFF
Jul 02, 2009 | NorStar M7310 Corded Phone
I'm looking to rotate phones around the office so that they can remain with their employee. Basically, I want to plug in the original phones to another line and reprogram for the original extension with...
In my workplace, when you move the Nortel M7100 phone, the programmed info (extension number, etc) moves along, just like if I was rewiring all phones. Have you tried just to unplug the phone and plug it on the new location? Here the extension number moves along with the equipment... (Nortel Norstar M7208 and M7100). Good Luck!
NorStar T7316E Corded Phone Logo
99 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
