Question about Zebra Designer Pro for PC
Our files for print with zebra printer are in zebradesigner program that designed in corel and export to zebradesigner program file. When printing the lable one part of lable hasn't be printed.
    Champion:
  • Zebra Expert
  • 285 Answers
Check the length and the with from the driver fisrt. check the same on the printer setings.
Posted on Nov 13, 2010
Printing and counting problem with Zebra ZM400. We have connected a Zebra ZM400 to our network and we now have a problem with printing. When we print he prints the labels 1 by 1 instead of de total...
if you sending a file (ex. pdf or picture). to the printer, can do this, if you send the proper format with normal fonts (caracteres))to the printer, work fine. build new label from zebradesigner
May 20, 2010 | Zebra Z4Mplus Label Printer
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
I want to print a simple jpg file in a zebra Z4M, i have been readind the manuals but it seems that we can save (in memory) forms or formats, then call them and print them, but i want to print an actual...
u can print an JPG file easily with zebra designer . just choose the image and print.
if you don't have zebra designer, u can download it at www.zebra.com
Feb 11, 2010 | Zebra Z4M Printer
How do i input text with this printer
Just like you would any printer. You could use word but word by default is set for a 8.5x11 full size paper so it must be configuared under file, page setup. Your label size gets entered and margins are zeroed out, or use the free label software called zebra designer which can be downloaded from this link.
http://www.zebra.com/id/zebra/na/en/index/products/software/label_design_software/zebradesignerpro/zebradesigner.html
Oct 05, 2009 | Zebra TLP 2844-Z Thermal Label Printer
I have a Zebra S4M printer and it has always printed fine. I downloaded Zebradesigner software to be able to create a label, but i am having trouble setting up the printer through the Zebra Designer...
you need to load the zdesigner driver from the zebra website, the older zebra universial wont work with zebra designer that why you can't pick it.
http://www.zebra.com/id/products/global/en/drivers/barcode/zd_driver_1_4_52.DriverFile.File.tmp/ZD1510Certified.exe?dvar1=Drivers&dvar2=Zebra Designer Driver (32 bit/64 bit, Windows Certified) &dvar3=50
Cut and paste the whole link and paste into the address bar of your web browser or just goto zebra.com and click drivers and downloads.
Jul 08, 2009 | Zebra Designer Pro for PC
Read and print .DAT files on labels
you must embed ZPL/CPCL or EPL command to your program.. or use Zebra Designer Pro then connect the .DAT file to it and design your sticker..
Mar 20, 2009 | Zebra 105SL Thermal Label Printer
Zebradesigner for xml ''error in processing zpf and lvr files''
Somehow, the correct printer driver is not installed when setting up Zebra Designer for XML.
To fix it, clck on "Start->All Programs->Zebra Designer for XML->Add Printer".
A wizard opens, select "Next" and choose the printer you are designing labels for. Click on "Next".
Select "Update existing printer driver(s)". The driver gets updated and voilá!, now you can export your label desgins.
Mar 19, 2009 | Zebra Z4M Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
I have Thermal Zebra Printer TLP2824, I have installed it and
The printer has firmware TLP2844-Z Zebra. This printer uses ZPL commands and not epl. ZebraDesigner can print to a file and have a format command.
Jan 08, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2742
In www.zebra.com ZebraDesigner can download the software to design and print labels.
Jul 22, 2008 | Zebra Eltron TLP 2742 Thermal Label...
Zebra Designer Pro for PC Logo
304 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
