Question about GE GSH22SGRSS Side by Side Refrigerator
I replaced heater and thermostat and I'm trying to assemble.
But I don't remember where green wire goes.
one end is circle shape and I know where it goes
but the other end is square shape and I don't know where it goes.
please help me.
  • ALBERT GARCIA
    ALBERT GARCIA May 11, 2010
    usually the green wire is "GROUND" , did it came with the installation instruction ?? let me know AJ
  • 975 Answers
ME again , check out this link ,to make sure you got the right parts
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on May 14, 2008
WD1000 Cnn anyone tell me the color of the wires location on the thermostat, the small thermostat next to the large one anf the round preheat unit near by. THANKS
If I understand your question correctly . . .
Here are the wire colors connecting to the heater enclosure:
From the front, on the right side of the heater assembly (wrapped in shiny foil): First, the "working thermostat" (which cycles heat on and off to maintain 155 deg) - red on bottom, gray on top. That gray wire goes over to the right, connecting to either side of little round "overtemp - klixon" sensor, at a double connector (two gray wires). A brown wire goes to other side of klixon sensor.
At rear of heater assy is another klixon sensor and the ends of the heating element itself From L to R: Short black "jumper" wire goes from left connector (Klixon) over to far right connector (on heating element). Long black wire goes 2nd to L, and long red wire goes 2nd to R (again on heater).
Dec 15, 2013 | Malber WD1000 Front Load Washer/Dryer
I am trying to convert a three wire prong to 4 on my whirlpool dryer.
Inside the back of your dryer is a strip where the electric cord fastens on, behind a squarish panel about 5" X 5" sort-of.
There should be 3 screws/nuts in a row of the cord to hook to.
The right and the left screw/nut is HOT, for the black or red wire on a 4 wire cord. It does not matter which gets black and which gets red, they are both HOT. These wires are attached to the FLAT lugs on the plug end of the cord, NOT the "L" shaped or the round lugs.
On a four wire cord, there are also a white wire and a blue or green wire. These are both ground wires. The white wire goes to the middle screw/nut on the 3 connection bar of the machine, and the blue/green wire goes to the body of the dryer itself. (Use one of the little screws along side the opening for the wire.) The white wire goes to the "L" shaped lug on the plug, and the green/blue wire goes to the round lug of the plug.
Be blessed.
Jun 23, 2013 | Dryers
My ice maker stopped producing ice. Instead the water goes through the chute. There is no water or melted ice in the ice bin. Freezer is working fine. What should I do? Thanks for your help.
Take off the back panel in the freezer. 1/4" screws. Use a nut driver or ratchet and socket with an extension. 2. Behind the frost is the evaporator and the defrost heaters. One heater in the middle and one at the bottom. They are glass tubes. If you can see the bottom heater that is great. If not use a hair dryer and defrost only the very bottom to expose the lower heater only. 3. Now in the refrigerator section at the top where the controls are, take off the long plastic piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and the refrigerator turns off. This will put it into defrost. 4. Now look at that heater that you exposed and see if it glows and gets hot. If it does, then the timer is bad. 5. If the heater doesn't come on then go ahead and defrost the rest of the evaporator with the hair dryer. This will take a little while. Don't poke at the evaporator!!! 6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running thru them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator. 7. If the heaters look ok the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem. However the best thing to do is replace the heaters and defrost thermostat . It is easy to install. Follow these steps and this will solve your problem.
Aug 27, 2011 | Refrigerators
THE WATER DON'T COME OUT AND DON'Y MAKE ICE, AND THE WATER SUPPLIES IS OK
Good day,
6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running through them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator.
7. If the heaters look okay the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem. However the best thing to do is replace the heaters and defrost thermostat . It is easy to install.
May 13, 2011 | Kenmore Side by Side Refrigerator
Can't seem to be able to wire up thermostat.
Hi!!
Just remember that the thermostat is a control device, like a flip switch, this means one end comes from the outlet (IN) and the output goes to the heating element or, if there are other control devices before the thermostat, goes thru them and then to the thermostat and heating element. The other end from the outlet goes straight to the heating element.
If you need extra help, let me know.
Aug 08, 2010 | Fahrenheat PLF1504 Baseboard Heater
I want to replace programmable thermostat with old dial style
The terminals should be the same on both thermostats, except for C- common.
R- usually RED, goes to hot side of transformer,
W- usually WHITE, goes to heat
Y- usually YELLOW goes to outdoor unit
G- usually GREEN goes to furnace blower
Any of the other wires just cap them off you don't need them. If you have an Rh and Rc terminal instead of R and don't have them on the programmable then put a jumper from Rh ro Rc.
If you need more, then let me know what terminals you have on both t'stats and brand of furnace and AC, if you have a heatpump then there's more wires let me know.
Oct 13, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Wiring
red goes to RC and RH, White goes to W, Green goes to G and Blue goes to Y. iam assuming on the old tstat that Red whent to R White went to W Green went to G and Blue went to Y
Sep 20, 2009 | Honeywell Programmable Thermostat Heater
Replacing heater element
on your old heater there was a "thermostat, mounted to the lower end of the heater correct?? youllneed to remount that to the new heater( one end will gp to one terminal on heater) ohter "thick wire" goes to the other heater terminal, and on eto the open thermostat connectore, the last wire should be smaller in size and connect to teh side of the thermostat you just installed
Jan 21, 2009 | Whirlpool LEQ9858P Electric Dryer
You mean the heater and thermostat installation instruction? No.
give it a couple of hours ,so system can function , also set the knob to high , and let me know later AJ THANKS FOR THE RATE !!!!
May 14, 2008 | GE GSH22SGRSS Side by Side Refrigerator
I replaced heater and thermostat and I'm trying to assemble....
There should be an open plug in for it where you removed the old one from. The flag you referred to on the end is a male spade connector. You should find it is a female end on a white wire.
May 13, 2008 | GE GSH22SGRSS Side by Side Refrigerator
GE GSH22SGRSS Side by Side Refrigerator Logo
63 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
