Question about Asko Dishwashers
Hi our Asko wont drain why would this be - Asko Dishwashers
    Scholar:
  • 59 Answers
First you should check the drain spigot under the sink remove the waste hose and see if there is a blockage there. Otherwise the pump in the machine may have a stoppage. Check under the filter in the sump You might hqve a yellow coloured pump cover. remove that and see if there is nothing blocking the pump outlet. After that you will have to remove the drain pump from the machime and test it. zyou might need help for that. You should only attempt this if you arer qualified to do so Cheers Tony.
Posted on Sep 07, 2010
Asko washing machine wont drain
Hi ,it could be a blocked or seized up drain pump.
You can try and clean the pump ,it normally works.
Nov 27, 2013 | Miele Novotronic W1930 Top Load Washer
Asko 10625 washing machine wont drain or open
Take the bottom panel off and there is a large drain under the drum. There will be a lot of water that comes out, so be prepared. When you take the drain off, there should be a debis trap in there. Clean this out look to make sure there are no socks or anything in there.
Nov 27, 2013 | Asko Washing Machines
My asko 3122 dishwasher wont drain
It is likely that there is some minor clogging in the diswasher drain filter.Clean as per the user instructions available with the dishwasher. Also likely the kitchen drain could be clogging. Buy a dishwasher cleaning kit from supermarket. Finish make a good product. Use it to clean the dishwasher as per instructions on the kit.
Nov 27, 2012 | Asko Dishwashers
Asko 3122 wont drain
I think I have replied to this already. Filters or drains might be clogging up. Clean dishwasher using Finish dishwasher cleaning kit.
Nov 27, 2012 | Asko D3122XLSS Stainless Steel Dishwasher
Hi I had f2 flash up on the control panel so we drained it and turned it back on it now shows 5 on the control panel and wont do anything else it is a ASKO D1976
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be there when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps...
Daniel
Jun 08, 2011 | Asko D1976 Built-in Dishwasher
Hi my asko fron load washing machine model W621 wont drain properly anymore and makes a clunking sound as it tries to spin are u able to tell me what possibly could be wrong with it & if its worth...
Not to worry, please check from the drain hose from beneath and open the hose. Look for dirt inside for clogging into the valve/drain pump. Remove and clean the valve/pump if there is dirt. If not during the spin the valves must open and drain. if not check for the controller section for fault. The clunk noise could be misalignment of the suspension or the damper unit. tighen or replace. Hope you try . Good day
Aug 13, 2010 | Asko W6021 Front Load Washer
Asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Nov 01, 2009 | Asko W6021 Front Load Washer
Hi the machine wont drain and door wont open
this is usually a drain pump tha has something stuck in it and will not allow the water to drain out.use a shop vac and put it on the end of the drain hose to drain any left over wat the check th pump for a foreign object and remove this should solve your problem.
Sep 16, 2009 | Asko W6021 Front Load Washer
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Jun 22, 2009 | Asko 1375 Dishwasher
Asko d/w d3122 Hi gang the overfilling protection has been activated, what can I do to remedy the sitution. regards banger35
Have a look to make sure that the pump and drain hose are unblocked. If they are, you might have to call Asko and arrange a service call.
Oct 08, 2008 | Asko Dishwashers
Dishwashers Logo
83 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
