Question about Whirlpool 17.6 cu. ft. Top-Freezer Refrigerator w/ Factory-Installed Icemaker
I have been using Wirlpool ARC 4020/1 IX for two years. Recently the following problem started to occur at random times: it turns on normally and in a minute it starts beating. The noise, coming from the compressor, is regular and keeps that way on up to 1 hour. At that, the compressor is warming up and gets hot at the end of session, while the heat exchange grid on the back is cool. At last, its turns off and turns on in normal mode at due time. Because it happans at random, I cannot show anything to a serviceman when he comes. Can you advise anything? Alex
  • avinnik09 Sep 07, 2010
    I'm quite satisfied. The advise direct, clear and consents with own (non-professional) opinion. Thanks.
  • 11,800 Answers
It beats because the inflow valve on the compressor locks up. Since the valve is inside it, no way of fixing it. When this happens tap the compressor with something heavy, it might unfreeze the valve - but this is a temporary fix, in the end you will gonna have to replace the compressor.
Posted on Sep 07, 2010
Recently replaced the power supply unit in my 47LD450-UA tv. It was turning turning for a few minutes then would turn off and not come on. After replacing the power supply unit, it stayed on long en
Your original problem of failed electrolytic capacitors (common) may be the same one occurring in the replacement if it was a 'pull' from another set.
Normally, depending on the quality of the parts used, these supplies will survive for several years before failing.
If this was in fact removed from another set, it's time to return it if there was any kind of warranty.
If not, the repair cost isn't that great if you have an honest tech in your area.
Jan 09, 2015 | LG 47LD450 47 in. TV
15amp Eaton Arc fault breaker type BRAF trips every day at same time. There are no high amp electrical things plugged in. What is causing this? should I have it replaced?
"Arc fault" breakers trip when an arc occurs, either in a receptacle or a light switch, for example. An arc can be caused by an old light switch, when turning it on. An arc can also occur when you unplug a chord while the device is still turned on or running.
Aug 25, 2013 | Eaton ARC FAULT CIRC BREAKER
Sony Turntable will only start turning once in a while
Remove the turntable and clean the under side with denatured alcohol. Make sure you remove ALL residue from the alcohol. Next, get a bottle of rubber drive cleaner from an electronics hobby store and clean the drive wheel and the motor spindle. Finally, put one drop of oil at each end of the motor shaft, directly at the bearing.
Dec 17, 2012 | Audio Players & Recorders
I have a syncrowave 250, it is about 12 years old. I bought it new and use it rarely. Recently I went to weld some light aluminum and when I tried to start an arc,it acted as though I had no ground...
Jon,
I would like to suggest to you that you post this question on the millerwelds forum. There are some very experienced tech guys there that can help you much better. Go to millerwelds.com and select the forums under the resources tab. You will be surprised. Hope you can get it running again.
Ryan
Mar 27, 2017 | Miller Electric Manufacturing Electric...
Mo del no. p60752eb spark when you turn on
SOMETIMES a spark at the spark gaps provided at the sockets of CRT'S HAPPENS. They put spark gaps because some tube arc when the high voltage comes up initially and the spark gaps protect the semiconductors which drive the tube grids the gaps are protecting.
Any sustained arc of course is a no-no. A single snap can occur at times. Watch for anything indicating failure in the normal operation and get it serviced.
Apr 28, 2010 | Televison & Video
20 amp breaker pops with only a light (60watts) and a small tv on. samething occurs in another room with an iron and a light on, These items can't possibly be brawing 20 amps. Is there a problem with these...
I have been an electrician for 11 years and when these breakers came out in 2005 what a nightmare. These circuit breakers are extremely sensitive. They are designed to sense loose connections and to protect your house from fires caused by them. By increasing the load (ie. more lights or tv) it increases the size of the "arc" created by the loose connection and the circuit breaker trips before the 20 amp maximum. What I normally find as the cause is a loose connection in one of the receptacles or switches on the circuit. A lot of times, installers will use the "quick stab" inserts on the back of the outlets or switches instead of the side screws. Usually, if you "side screw" all of the receptacles and switches it will resolve the nuisance tripping. One other item that can cause them to trip is too many dimmers on the arc circuit but it doesn't sound like that is the problem you're having.
Nov 15, 2009 | Siemens 20Amp 1-pole arc-fault circuit...
2 year old elect range/oven by wirlpool will not
check your input voltage your probably losing a leg and only have 120volts instead of 240 volts that would cause a reduced heat symptom
Jul 16, 2009 | Ovens
Microwave Arcing
The metal shelf that comes with most microwave ovens must NEVER come in contact with any surface of the cavity wall or arcing will occur. (this is why its is mounted on plastic clips). IF you are not using the shelf to cook multiple items (as most people don't)....Remove the shelf and store somewhere else until needed.
Jun 06, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Random ARC Picture Size Change
What Brand TV do you have? What cable box are you using?
Dec 07, 2007 | Televison & Video
Whirlpool 17.6 cu. ft. Top-Freezer Refrigerator w/ Factory-Installed Icemaker Logo
138 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
