Question about HP ProLiant ML150 G2 Server
"ProLiant ML150 G2 Server" "Windows server 2003, Standard Edition Setup" Setup did not find any hard disk drives installed in your computer. Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration is correct. This may involve running a manufacturer-supplied diagnostic or setup program. Set up cannot continue. To quit setup, press F3.
4 Suggested Answers
Fredinot
  • 96 Answers
SOURCE: why I can't boot from DVD
You must have a bootable files in a DVD where system files are usefull as bootup system.
Posted on Mar 17, 2010
  • 18 Answers
SOURCE: when trying to install window
The setup program does not recognise your storage controller.
HP and Dell usually supply a startup CD, that will help you configure RAID levels and partitions and start the Windows installation. If you have the supplied CD boot from it and it should work OK, if not you can download it here
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=15351&prodSeriesId=316541&prodNameId=327476&swEnvOID=1005&swLang=8&mode=2&taskId=135&swItem=MTX-d7672226b6284520b9e292b9bd
Please let me know if it works, any issues send a reply :)
Posted on Dec 22, 2010
info2u
  • 596 Answers
SOURCE: i bought Few HP proliant
First, make sure all your connections are secure and the BIOS is seeing your hard drives. When you start the install of Server 2000, you will see a prompt at the bottom of the screen saying if you have third party software to install press any key. (or something to that effect.) Press any key and install the needed software drives for the SCSI controller. You will need this to move forward. If you do not have the drivers, you will need to download them to a cd or usb drive to complete your server install.
Good Luck.
C2Solutions
Posted on Jul 11, 2011
How can install windows xp in proliant ml 150
As long as the server meets the XP minimum spec, you can insert the XP boot disc and reboot your server. As long as the CD/DVD is bootable, you should be ableto install XP without incident.
Good Luck,
C2Solutions
Nov 24, 2011 | HP ProLiant ML150 G2 Server
I am unable to instal windows server 2003 on HP Proliant ML150 G5 because it gives me message no hard drive found
Option 1 (HIGLY Recommended): HP servers should come with an install disk that prepares the windows installer for you. Boot from that disk,tell it your OS, and pop in the disk for the OS when prompted. It will come up fine and have all the HP monitoring agents installed.
Option 2: Load the driver the old fashioned way. Unless you have a floppy drive the standard "Press F6 to load drivers" trick won't work. If you do, then you'll need to put the RAID driver on the disk.
Option 3: Use an installation customizer like nLite to pre-add the RAID driver to the Windows 2003 installer.
Good luck.
Feb 26, 2011 | HP ProLiant ML150 G5 Server
Hard disk not found message coming while installing windows server 2003 on Hp Proliant ML150 G5
You need to press F6 and load special drivers for your disk driver card
See which disk adapter your server has and get the drivers on a floppy disk
Put the disk into your computer before seutp, then click F6 when prompted
it will search your floppy drive for them
Feb 15, 2011 | HP ProLiant ML150 G5 Server
Configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Feb 24, 2010 | HP ProLiant ML150 G2 Server
How to install Win2003 on HP ML150 G2?
u need to have Win2003 install disk...
insert the disk in the CDROM drive
let it boot and load all system files and then it will ask u to format the disk
let it format the disk
and it will auto install the win2003 os
before u do this take a backup of ur data...
Dec 25, 2009 | HP ProLiant ML150 G5 Server
When doing new installation i can not find hand disk drives
Check your BIOS if it's detect your Hard Drive.If detected then check your system BIOS whether SATA setting is enable or not. Disable it if you have enable it in IDE configuration.If you find there is no way to configure SATA in your BIOS setting then you need to download SATA driver for that Hard drive and used a software called nlite.
Here is the link for nlite software
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
Here is the guide link for using nlite software to make a bootable OS cd with SATA driver pre-installed.
http://www.nliteos.com/guide/index.html
Here is the link for SATA driver for your ProLiant ML150 G2 Server from HP.
ftp://ftp.hp.com/pub/products/servers/supportsoftware/ZIP/HP6-port_SATA_RAID_Controller_Driver_for_Windows_v4.2.1.7365.zip
For more information on how to installed and configured check the link below
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=15351&prodSeriesId=435422&taskId=115
the above procedure is for Windows based Server Operating System.If you are planning for Linux based then download the drivers by selecting the operating system from the link given below
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3279685&lang=en&cc=us&prodTypeId=15351&prodSeriesId=435422&taskId=135
Dec 23, 2009 | HP ProLiant ML150 G2 Server
When i repair my windows at my server (HP ML150 )
reboot, and check to see if BIOS 'sees' the hard drive...if bios lists the drive, right click on 'My Computer' and select manage drives. the interface there is pretty straight forward... if bios does NOT see your drive, check your pin settings, be sure your connections are tight ...and check the BIOS settings match your drive
Jun 04, 2009 | HP ProLiant ML150 G3 Server
Can i have a hp proliant 150 generation 3 server bias setup guid line for intalation obunto sever pack.
ML150 G3 is on the certified HW list for Ubuntu Server edition. There should be no special steps required to install this.
May 04, 2009 | HP ProLiant ML150 G3 Server
Instalation of windows server edition
You have to make a floppy disk with the raid drivers on it. Start the Setup process and just as it's beginning it will ask you to hit F6 to install raid drivers. Hit F6, insert the floppy, install the drivers.
Feb 18, 2009 | HP ProLiant ML150 G3 Server
STORAGE
Hi, I found this thread interesting. Will try it out today.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?prodSeriesId=3799613&prodTypeId=18964&threadId=1285096&admit=109447626+1237817674797+28353475
It says that the right driver is not in the support CD!! As per the link, the problem was solved for him once he used a USB Floppy drive (Windows compatible).
Sep 08, 2008 | HP ProLiant ML150 G5 Server
HP ProLiant ML150 G2 Server Logo
352 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
