Question about Maytag M6X06F2A Air Conditioner
It sounds like there is water inside my unit. what should i do? it's almost "gurgling" and very distracting!
    Master:
    Sergeant:
  • 449 Answers
Clear the drain path
Posted on Sep 08, 2010
Why is the inside fan is not running and hearing a gurgling sound with the outside unit still running?
The gurgling sound sounds like freon is flowing thru the system pipes. Is the larger of the 2 copper tubes running cold to the touch? Hi-Low module make also be the problem. It tells the inside fan when to turn off and on.
Sep 05, 2014 | Coleman Heating & Cooling
I have a frigidaire fac105p1a that is spiting water out though the vents what do i do about that?
Good Morning Friend,
I understand that you have water spitting out of the top vent on your Frigidaire air conditioner, model# FAC105P1A. I also see that it sounds like water is gurgling through the pipes and you want to know how to fix it. If your air conditioner is also leaking outside, this is normal during excessively humid days, due to it removing large quantities of moisture from a humid room. If it is also dripping inside, I suggest slightly tilting your air conditioner to the outside, to allow water drainage. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 15, 2014 | Frigidaire Heating & Cooling
Gurgling sound
Refrigerant migration nothing can be done.
Apr 28, 2014 | Scotsman Kitchen Appliances - Others
Gurgling sound dash
Depends.
It could be water trapped inside the heater box, or air in the cooling system. If the sound happens when you take off from a stop, it could be low on coolant. If it happens when you are making a turn, it could be water in the heater box. The drain could be plugged up.
Feb 24, 2014 | Jeep Cars & Trucks
Freezer gurgles
    • Give it mouth wash lol
      Check the water valve on the back of the refrigerator if it has an ice maker. Make sure the valve is turned completely on and not constricting the flow of water to the refrigerator via the water supply line. You might also hear a simultaneous buzzing sound when the gurgling noise occurs. In some refrigerator models, this filling process is on a timer, and you might hear the buzzing and/or gurgling every 15 minutes or so.
    • Check the water supply line for leaks or damage. You might see a puddle of liquid on the floor. If air is pulled into the water line as the refrigerator is pulling in water, that can create a gurgling noise. Replace the damaged hose yourself, or contact an appliance repair technician for assistance
      • f he refrigerator to feel a slight vibration. This is probably the compressor processing the refrigerant, which is a liquid. This flow of refrigerant can produce a gurgling sound, and it is normal. However, a simple way to reduce this noise is to make fewer trips to the fridge. When you open the door, you let hot air in, which means the compressor has to work harder (and gurgle the refrigerant more) to cool things back down.
    • Wait while the refrigerator completes its defrosting cycle if you hear water dripping and gurgling in the freezer area. When the heating coil turns on, the melted water from the frost flows down to a drain pan for evaporation to take place. The defrost process usually takes about 30 minutes. This is automatic and cannot be prevented in most refrigerators. Keep the closed to try to prevent unnecessary frost buildup.
    • Wait while the water equalizes in the refrigerator if you hear a gurgling sound when shutting the door. This is normal and is a result of air being forced through the drain tube. The gurgling can last several seconds but should eventually dissipate this usually happens with old fridges upgrade its a good investment
Dec 10, 2013 | Freezers
My sub zero refrigerator makes a gurgling sound when you close the refrigerator door - sound is coming from the side of the unit.
Hi this is the drain tube sucking water back up through, this is caused by the vacuum inside the refrigerator that is formed when the air condenses, not much you can do about this sound its fairly normal.
Sean
Apr 01, 2011 | Sub-Zero 650 / O Bottom Freezer...
Sewer smell in house since installing the new toliet and the toliet gurgles when the washing machine is on. It started with the new toliet now the gurgling and smell is also present in another bathroom.
It sounds like a vent problem.
On top of each house is a vent stack.
There should be a vent stack above each toilet, and above kitchen sink.
Look for pipes sticking out of roof.
These pipes are open to the sewer line.
When you run a column of water down a drain, the vent stack lets air flow in front of and behind the column of water.
This air flow prevents the gurgling sound.
The gurgling sound is the drain water pushing air in front of it because of a clogged vent.
If you have a two story house, there are vents that run between floors to prevent the air flow from gurgling or bubbling sewer air into each drain as water column moves down pipe.
http://www.bradyinspects.com/plumbing-vents.html
http://chestofbooks.com/home-improvement/construction/plumbing/Standard-Practical/Venting-Part-3.html
Look for bird nest over vent pipe on top of house.
Run a snake down into pipe from roof and see if the is a stoppage.
You many need to call plumber to track down each vent and the cause.
For example if there are quick-vents installed inside a wall and the quick vent is no longer working.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 25, 2010 | Kohler Bath Highline K-11492-96 Biscuit...
My culligan water filter makes a gurgle sound
The reverse osmosis faucet you have incorporates an AIR GAP to prevent cross contamination to the RO system. The waste water first goes up the to RO faucet AIR GAP and then goes to drain. The "gurgling noise" is the waste water going to drain. Some of these are much noisier than others.
RJ
Jun 10, 2010 | Culligan Under Sink Water Filter
Bubbling water sound in AC. Water in the tray is cold. Unit continues to make a gurgling sound.
The gurgling sound is the liquid refrigerant going through the refrigeration copper lines , it's normal. And the water in the tray is condensation and is cold because is from the circulating air that gets cold going through the air handler(inside unit) You only has to keep the drain clean ,by pouring 1/2 cup of clorox every 3 or 4 months.
Sep 25, 2009 | Goodman Heating & Cooling
Suddenly no filtered water comes out, but there are gurgling sounds inside
I guess make sure the filter didn't unseat itself first, also check the O-rings, etc. to make sure they didn't roll off their position on the filter. If that's all OK, you really need to find that gurgle sound cause that's likely the water you are missing going "somewhere" it's not supposed to go. Look all over for water leaks even if you have to pull the unit out from the wall... keep looking!
Dec 21, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Maytag M6X06F2A Air Conditioner Logo
392 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
