Question about Insignia IS 20" TV040919 TV
TV does not switch on.
I have a Insignia TV and it used to work fine till 10days ago. Suddenly it stopped working. The TV does not turn on. THere is no light indicator or anything. Looks like no power to the TV set.
Cld u pls suggest.
  • 1 more comment
  • dj wonka May 20, 2008
    i have the same problem as described in the May 13 th story.... how can I be sure that the technician is telling the truth about the high voltage power supply? What if it's a fuse?
  • Radhikarlk May 31, 2008
    I am yet to call a technician to look at the TV set.
    Thanks for the initial analysis.
  • jumpabout22 Dec 29, 2008
    i have the same problem - the tv was doing fine and suddenly just shut off and has not worked since
  • 2,712 Answers
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). It could even be a blown fuse..
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
Posted on May 13, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
I have a Powerbook G4, and suddenly my airportcard stopped workin
OSX has become unreliable.
You could spend hours troubleshooting, or simply backup and re-install from disks, takes about 40 mins
Jun 20, 2010 | Apple PowerBook G4 Mac Notebook
Insignia 26"LCD TV "No Signal"
Your description pretty much narrows it down to tuner failure. I have had experience with Insignia products so not surprised.
Mar 03, 2017 | Insignia LCDTV26 26 in. Television
I purchased a 27'',Insignia tv about a yr 1/2 ago, it has been working fine till about 3 days ago, when it decides to shut down by it self. however, when i unplug the tv cord and replug, it comes back on....
To start unplugg it for a few hours, I know it sounds dumb but it will reset the set. If that does work get the TV on a surge protector. It would surprise me if this needs service beyond that, this brand is very service prone
Nov 12, 2009 | Televison & Video
Programm bell expressvu 4100 remote control
I had the same problem. I used the code 660 and that works fine for power, volume, and stations for my Insignia with the bell remote. Hold tv button till all 4 lights light up and then press 660 # and everything (minus the menu option) should work. I also tried these insignia codes (which might work if this dont.) 659, 573, 570, 405, 245, 456.
Mar 09, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
you might try checking the sap (secondary audio programming) option in your tv if it has one make sure it is turned off. if it is off or does not have that option you will most likely have to take it to a repair shop. i would not try to fix it my self as you will do more harm than good.
Dec 09, 2008 | Insignia IS 20" TV040919 TV
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Sep 08, 2008 | V, Inc. Vizio P4 Plasma Television
Sub titles
Do you have your manuel? Hit caption on the remote control and it will say off on the screen. Then click again and select CC1. Just make sure you are watching a program that has CC. Some shows do not have that. Try a major network.
Jan 06, 2008 | Insignia IS 20" TV040919 TV
Remote problems
Take the remote to your local Radio Shack and have it tested.. They used to carry IR cards and now have a pen-like tester that can tell if the remote is operating properly. Then, if you're sure the code is correct, you probably will have to have the IR detector in the Tv replaced...
Nov 20, 2007 | RCA RCU300WBL Remote Control
Insignia IS 20" TV040919 TV Logo
101 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
