Question about Fisher and Paykel GWL11 Top Load Washer
Hello , I have a F&P smart drive excellence 7.5. The final spin cycle goes on for far too long. Is there a way I can adjust the amount of time of this spin cycle? Thanks for any help.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now can you tell me how long the spin part of the cycle takes and I will check the time it is supposed to take.Looking forward to your reply.
Posted on Sep 07, 2010
Continues to go out of balance
The stainless steel bowl has lost its ballast water & goes out of balance,Replace faulty bowl.
Oct 03, 2012 | Fisher Paykel Fisher & Paykel AquaSmart...
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
I have a Fisher & Paykel smart drive 9 excellence 7.5 washing machine and the is a squeak coming from the bottom of the tub?
Hi Craig,just read your posting.The squeak could be the bearings.Is the machine noisy on spin?Could you reply back and tell me what part of the cycle the squeak happens.Looking forward to your reply.
May 17, 2011 | Washing Machines
F & P excellence 6.5 smart drive - Model GW608U - the machine will not fully progress throught the "Rinse" cycle. It will empty the wash water and spin & spray a little, then power...
Hi - this sounds more likely to be a faulty motor control module, its overheating and a electronic component is failing. Only way is to fit a new control module to eliminate the possibilty, another probable cause may well be the RPS sensor failing as it goes into spin mode.
Really need to do a few tests with a multi-meter, see if the motor/stator windings are ok, a faulty RPS at times will give a similar head ache..
May 05, 2011 | Fisher and Paykel Fisher & Paykel Washer
Won't drain in last cycle
Hi just read your posting.Now can you confirm the model number please.Please ;look underneath the machine to the front right and you should see a pump with a red or black fan attached.Turn this fan clockwise and anticlockwise a few times to hopefully loosen the pump if it is jammed.If the fan turns freely then put it back on its feet and start a spin cycle to see if it drains the water.Please reply with additional information on the questions and to tell me if you have the pump with the fan or if it is not draining or if it still is not draining.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hey, my f&p smart drive 9 excellence washing machine does not start wash cycle after entering water level etc.... upon pressing the start button nothing is happening any thoughts?
Is the bowl turning slowly when you press start.if it does then you may have a faulty inlet valve,make sure taps are turned on.try advancing the machine to spin cycle,see if it will do any other things such as spin & drain.if it does then probably just not letting in water & inlet valve needs replacing..try filling machine by hand & see if it washes.
May 24, 2010 | Fisher and Paykel (IWL12)
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
