Question about APC Smart-UPS 1000VA UPS System
I have a UPS 1000 VA with 12 V X 2 Battery, Problems: when we on ups input 200 V without load, it gives output 210 V. when load it gives 230 V on electricity. When Electricity cut off it gives 250 V. When we go on back up (battery) with load it gives 290 V. I have checked with Volt meter. Please give us solution
  • 732 Answers
Arif qc, Are you using a DMM that is or will make "true RMS" measurements or is it an "average responding" type of voltmeter? Is this APC ups designed for 120 vac input/output or is this unit a 220 vac input/output type? Use only a "TRUE RMS" type DMM to make your measurements!!! I believe if you visit Tripp-Lite site, you will find a tutorial video clip of why you should use a true-rms meter to make measurements of output voltages. 12fixlouie
Posted on Sep 07, 2010
The output voltage is 101 volt between la y n, I expeccted 120 volt
There`s two configurations that you need to check.
On UPS display, what voltaje is showing as output voltage?
There`s a chance that it is configured to 200 vac, then the transformer module will convert this to 100/200 vac.
If this is not the situation, probably the error is in the input connection of transformer module.
Sep 09, 2015 | Eaton MGE O.P.S. EX RT - UPS - 8 kW -...
How long I need to keep plug the back up battery to use to charge my phone?
Most manufacturers recommend an overnite charge, but the power you require to recharge a phone is very minimal, so I would recomend at least 4 hours, unless the battery back up is new then you can charge your phone while charging the battery back up for the full 12 hrs.
Sep 10, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
Why no OMNIVS1500XL power?
you have 3 output connectors connected to battery back up ( there is output when input power fails
other 3 sockets are connected to main power / when main power off , no output on the mentioned connctors
May 13, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
How to cennect the input line, L1 and L2
If you open the back of the UPS and unscrew the 3 large screws you should see where the input and the output hook up. I have a user manual if you need one. Just email me at ericpettingill@hotmail.com and ask for the manual. If you have one then can you be a little bit clearer on what is needed.
Sep 20, 2011 | Emerson Fans Liebert GXT2 6000RT UPS AC...
Having UPS Model No. BR 1500 in time of opening UPS shows over lode without giving any lode. Battery is new . can you tell me the solution.
Try to reduce your load. in a overload condition the UPS can not tell you what the load is if it has more then the 1500VA your UPS can not put out more then 1000 watts. Battery has nothing to do with the load.
Sep 09, 2011 | APC Back-UPS RS BR1500-IN (BR1500-IN) UPS...
How do you check the battery status?
Check battery voltage using Volt meter=> it should be about 12.6 to 13.8 vdc.
Pull the battery out... checking the deforming at the case ..such as "swelling"... if yes .. replace the battery.
Replacement battery is about 10-20 dollars on e-bay (watch for shipping charge and size. and terminal connection sizes )
The average life of battery on UPS is about 5-7-10 years wi)th UPS plugged in (Charging
One I had my local Autozone checked my 12 VDC -8 AH ... ask them to set CCA at about 100 AMP...
for 12 VDC -14 AH ask them to set CCA about 200 AMP.
For a 12 VDC -75 AH (group 24) they set the load on their tester at about 700-900 CCA.
You can also buy a manual battery load test at Harror freigt tool for about $20 US dollars (On sale)
Feb 18, 2011 | APC Back-UPS ES 350 - UPS ( external ) -...
APC Smart Ups 1000 VA overload Alarm
you have too much plugged into the UPS. Either buy a bigger UPS or reduce the load
Jan 07, 2011 | APC Smart-UPS 1000VA UPS System
How many systems support for 1 KV UPS
1 KVA UPS will provide you good back up with 2 pcs simultaneously without any power fluctuations.
May 24, 2010 | Liebert 1 KVA UPS MODEL RT1000-60...
I just replaced the battery with a brand new one. After a few seconds of being plugged in, the unit beeps continuously. What is the problem?
Definitely you have replaced a new battery, but my dear friend every battery need to be charged by electricity before using it. Connect the UPS for at least 10-12 hours with power & do not switch your UPS ON while charging.
Good luck...don't forget to rate the solution
Feb 23, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
APC Smart-UPS 1000VA UPS System Logo
115 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
