Question about LG Heating & Cooling
COMPRESSOR STOPS AFTER RUNNING FEW MINUTES - LG Heating & Cooling
    Master:
    Sergeant:
  • 449 Answers
Sounds like your compressors on its way out
Posted on Sep 09, 2010
My 2003 VW Jetta air conditioning is cooling for a few minutes and sometimes longer and then it stops cooling. The fan continues to run but the compressor apparently stops running.
Have you watched the compressor in action? The compressor is driven by the fanbelt which turns a pulley on the compressor shaft, but there's an electric clutch that disengages the pulley from the friction plate attached to the compressor shaft. You should hear a click when the clutch engages and disengages. Do you hear that? Can you see the friction plate turning with the pulley or does it stay in one position while the pulley turns? If if works for a bit then stops turning, you may have a damaged friction plate such that it doesn't engage with the pulley. Take your car to an auto A/C specialist and let them examine it. It's also possible that the relay that sends 12 volts to the clutch is intermittent and needs to be replaced.
Jul 22, 2015 | Heating & Cooling
Knocking noise coming from bottom of refrigerator
check the compressor for operation adn check the fan in the back of unit to make sure it is running...whirlpool units are notorious for compressor relay failure normally they click in and out every few minutes... if it is a knocking noise and continuous make sure compressor is not trying to start and sitting there shaking... normally it will stop after a few minutes and then start again....
Jan 25, 2011 | Whirlpool GS6NBEXRS Side by Side...
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
So-low freezer try to start, but stops after a second
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Oct 23, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
2005 chevrolet venture load levelers not working
had the same problem with my ford a few years back, found that the rubber seal on the piston in the compressor had run dry and it was too hard for the compressor to push the piston up and down the bore which cut the power to the compressor and you had to stop the car turn it off for a couple of minutes and restart it and the compressor would pump air for another couple of minutes and stop again.
I solved the problem by replacing the shocks with a pair of pump up shocks that have a valve like a tyre valve and you pump them up at the service station
hope this helps
May 25, 2009 | 1999 Chevrolet Venture
Fridge compressor problem ?
Seems to me you have a faulty cold control. (behind the temp control).Not too expensive , about 40 bucks.
Feb 23, 2008 | Refrigerators
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Heating & Cooling Logo
65 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
