Question about Ricoh Aficio 1018D All-In-One Laser Printer
What is the toner number?? - Ricoh Aficio 1018D All-In-One Laser Printer
  • 360 Answers
Hello toner number is ricoh 1220D
Posted on Sep 07, 2010
Fix error code on phaser 5500
That error means wrong toner installed. Are you using OEM toner? If it's not the toner it's the Crum board that recognized the toner, part number 160K95831.
Sep 01, 2014 | Xerox Phaser Office Equipment & Supplies
How to reset oki b411dn cartridge after refilling
Producers of printers protecting oneself against the mass copying of original toners implemented the number of solutions being aimed at hampering the copying of their solutions. Towards a number of recipes for individual sub-assemblies of the cartridge intended for a laser printer applying special scaling circuits installed in the casing of the toner which are suming the number of printed sides up was the most spectacular solution and are freezing the laser contribution after the achievement of set limit of printouts. Toner do drukarki materiay eksploatacyjne Chip toner co jak
Apr 23, 2014 | Oki Electric Industry B411dn Printer
C390
[C390] Auto-toner sensor-C abnormality (Cyan)
<Color toner low density>
When you check the printing status to find out that the color printing ratio isless than 5%, color toner low density might be the cause.
Turn the code 08-2692 "Prevention of color toner low density / ON/OFF setting" to ON, and then set number of sheets to be judged at the code 08-2693 "Prevention of color toner low density / Judged number of sheets setting".
If the color printing ratio is 5% or more, check the following.
(1) Is the developer unit installed properly?
(2) Check if the connector CN340 on the LGC board isdisconnected from the auto toner sensor or the harnesses are open circuited. Correct if necessary.
(3) Check if there is any foreign matter such as toner in the drawer connector of the equipment and fuser unit or the connector of the auto toner sensor. Remove if there is and reconnect it.
(4) Service or replace the auto-toner sensor.
Apr 04, 2014 | Toshiba E Studio 2330C
I have a Toshiba Dp85F Fax machine and need to replace the toner cartridge...I do not know what model number I need to replace it with. Please advise
Ink, Toner & Accessories for DP-85F Printers, Copiers & Faxes Select from the list below Compatible or Original ink and toner cartridges that work with your DP-85F.
TOSHIBA TK-18 Compatible Black Laser Cartridge, TK-18
  • - Condition: Compatible
  • - Page Yield: 6000
  • - Color: Black
  • - Printer Technology: Laser Cartridge
  • - Item Number: TK18-70
- OEM Part#: TK-18, TK18
Item #: TK18-70
MSRP: $114.99
Price: $38.99
Toshiba DK-18 DP-80/DP-85 Drum Unit
  • - Page Yield: 20000
  • - Color: Black item-color-black.gif
  • - Printer Technology: Drum Unit
  • - Item Number: DK18-70
- OEM Part#: DK18, DK-18
Item #: DK18-70
MSRP: $114.99
Price: $39.99
Toshiba DP85F Toner Cartridge, Black
Toshiba TK18 Toner Cartridge, Toshiba TK-18 Fax Toner
$73.59
Nov 29, 2010 | Toshiba DP-85F Fax
Want copier to use up more toner in machine
If you know where the "Toner Eye" is in the copier, cover it with black tape. Usually though, the copier counts the number of pages printed and then at a predetermined number thinks toner is low and stops printing. If the toner cartridge is chipped (has a electronic chip) it keeps the count in there. These type of cartridges are refillable, but still have the "Empty" count. The counter must be reset. These resetters are hard or impossible to get.
Jun 23, 2009 | Brother MFC 7840W Printer
CLP 300 toner cartridges invalid toner
the drum has chips encoded,need cartridges with chips.
May 29, 2009 | Samsung CLP 300 Laser Printer
How do you change the toner in a Minolta Dialta copy machine?
Check the back of the machine see if the sticker is still on it. Model number should be there. As for toner carefully remove the toner bottle turn the machine off wait ten seconds turn the machine on do not put the bottle of toner in until the waning comes on to tell you to add toner. The word "up" on the toner bottle should be visible onthe tup when you install it, so should the hole. Theres a small nub that will lock int place when installing it.
Apr 01, 2009 | Minolta DiALTA Di183 Copier
Replace toner message still displaying
Have you already tried powering the printer off/on to see if this would clear the error? If so, are you using a Dell branded toner? If not, this could be why the printer has not recognized the replacement. It could be you recieved a bum toner cartidge, although this does not happen often, it can still happen. If you take your old toner cartridge and put it back in the printer, does it recognize it? If so, perhaps it is the toner cartridge.
If it is a bum Dell toner cartridge, Dell carries a seperate warranty on toner, apart from the warranty on the printer. Call Dell laser printer tech support. They will need your order number for the toner and have the cartridge handy as they will need an identification number off of the cartridge.
Mar 28, 2009 | Dell 3000cn Laser Printer
Ricoh Aficio 1018D All-In-One Laser Printer Logo
29 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
