Im having a problem with my canon mp 510 scanner, the problem is when i go to scan a piece of white paper with black writing on it, it reverses and shows me on the computer black paper with white writing on it, how do i stop this?
  • 67 Answers
This could be because.. in the printer preference / properties .. you have the option of Mirror printing../mirror image.. so, pls uncheck/disable that.
Also make sure that you are keeping the paper face down , correctly on the slot provided ..
Posted on Sep 07, 2010
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
How do i get my scanner to operate - I put a piece of paper on the glass - hit the scan button - then nothing happens - the printer says " PC scan standby" . What do I do next ? Do i need to...
1. Install the MP Navigator EXsoftware located on the disc that came with the printer.
2. Go to Start > Programs > Canon Utilities > MP Navigator EX > MP Navigator EX.
3. Select Photos/Documents or Stack of Documents.
4. If Photos/Documents was selected, open the top of the scanner and place the document you wish to scan on the glass with the top facing to the left. If Stack of Documents was selected, flip the plastic tray open on the top of the printer and place the stack of papers in the tray.
5. Select the Document Type in the left pane, then click the Scan button.
6. The scanning process should start. When it's finished, select Save to save the document(s) as a JPEG, or select Save as PDF to save it in PDF format.
Jul 07, 2011 | Canon PIXMA MX340 Wireless Office...
Will my Canon MP510 work if Black ink cartridge installed alone?
No, Canon machines only work with all inks installed, you can get air bubbles in the printhead without inks and that would ruin the printhead.
Jan 14, 2010 | Office Equipment & Supplies
Canon MP 510 paper jam
I had the same problem and found a small coin in the back feeder. Remove the back coverplate and tip the machine onto its back and give it a good shake. You might be surprised at what falls out.
Apr 30, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Black vertical lines on the sent copies when faxed on Sharp UX 510
Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Mar 31, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Images scan black via flatbed or auto feed
Check your software settings, Try Auto Brightness for scanning a white sheet.
S. Mohan
Nov 06, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Canon Dr-2580C
Try and scan a white paper. If the output is black, then may be the LEDs are not glowing, likely the wire is loose. Actually it is not easily reacheable! Try duplex scanning to check if both scan modules are fine.
S. Mohan
Oct 14, 2008 | Canon DR-2580C Path-Through Scanner
When scanning color document, blue tone is present as background shade
Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
Sep 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
67 people viewed this question
k24674
