Hello, I have a Initial IDM 1210 portable dvd player. Yesterday, after inserting a dvd, suddenly appeared the message "WRONG REGION". Consider that I live in Italy and I bought the player 4 years ago in Miami and the Initial assistance already sent me some instructions to reset the region code in order to play italian dvds. But I have lost these instructions. Consider, also, that the "preferences" item in the Setup Menu is disabled (why?) Can you help me? Thank you
  • antonio_saol Sep 07, 2010
    As I have written in my ask, I cannot go into "preferences" item in the Setup Menu because it is disabled. So, how can I do it?
    Thank you
    Antonio
    Hi Ginko,
    what do you mean by "service mode"? Is it another way to enter the preference menu? How can I do it?
    Thank you
    Antonio
  • 19,396 Answers
Hi Antonio.
If the preference item looks disabled there is no way to apply the region hack. The only region change procedure known for this player is by operating such menu. I think I wrote you yesterday in Italian. The preference menu is also needed to enter in service mode.
The only repair that I can think of is by reinstalling the DVD firmware. Online there is no firmware available for this unit. The only way to get the firmware is by contacting the manufacturer.
The Initial IDM 1210 was built by Mintek. Although there was no notice of company closing down, they did shut down any online support.
Check if there is any number or contact in your copyy of the manual. If there is none, then there is no way to get the firmware for this unit, and the DVD cannot be fixed.
Note: A last resort can be dropping a mail to this folks here. They do program chips, and have done a lot of works on different Mintek Initial units. I suggest giving it a try.
In case you get back use of pref. menu, here the hack (again):http://www.videohelp.com/dvdhacks/mintek-mdp-1020/4432
Here the manual (no support contact in there): http://lib.store.yahoo.net/lib/acekaraoke/IDM-1210.pdf
Posted on Sep 07, 2010
  • Ginko
    Ginko Sep 07, 2010
    Hi.
    Service mode is the special menu that the tech uses to access diagnostic and change some setting that is precluded to the user. Like the region code change, which is not supposed to be available to the user.
    Unfortunately on this units service mode is accessed through the preferences menu. Accessing service mode is part of the hack procedure described before. I think this was procedure for this model:
    From preferences menu press 2 2 5 4 2 2 on the remote.
    It is a dog (...or a cat in Italian) biting its tail.
    I assume that you try already the simple reset that gets done disconnecting power and removing battery for about ten/twenty minutes, to drain power completely. If that does not work, a further reset can be done disassemblying the unit, locating and interrupting contact to the internal EEPROM battery (which is not necessarily a coin battery, it is probably soldered). That job is better done by a technician and may not solve the problem.
    President:
  • 1,932 Answers
Battery #24EO511010244P
check our the online battery stores .perhaps through the place you bought it even
Apr 12, 2014 | Initial IDM-1210 Portable DVD Player
It's showing the video in a split, black and white screen
could be a pal/ntsc region code problem, either the menu setting is pal and your playing a ntsc region coded dvd or the menu is correctly set at ntsc and the dvd is pal that you are trying to play
Dave
Dec 27, 2010 | Initial IDM-1210 Portable DVD Player
Says loading but will not play
check out the OPTICAL LENS , take a Qtip and gently rub the optical lens , Qtip must be dry , good luck AJ
Nov 28, 2009 | Initial IDM-1210 Portable DVD Player
Region unlock
Quick 10 Steps:
- Power
- Setup
- Down 2x
- Play
- 253135
- Left
- Down
- 0
- Play
- Setup
Done
Detailed version:
1. turn Power 'On' - slider switch left side of unit
using the included credit card remote:
2. press 'Setup' button, bottom left (next to down arrow button) to display menus
3. 'Down' arrow 2x to Preferences menu
4. press 'Play' > button, center of arrow buttons, to select Preferences menu
5. press numbers: '2,5,3,1,3,5'
6. 'Left' arrow < button
7. 'Down' arrow button
8. you should now see REGION CODE 1 or similar
9. Press '10/0' button for all region, or whatever region you want
10. Press 'Play' > button again
11. Press 'Setup' button to exit menus.
Oct 17, 2008 | Initial IDM-1250 Portable DVD Player
Open Questions:
35 people viewed this question
 Grubhead
Grubhead
