Question about Zodiac Baracuda G4 Automatic Pool Cleaner Ne221
Does not move through entire pool but gets tangled at the weir all the time
    Novelist:
  • 116 Answers
Is this a new cleaner or old? how old? As these cleaners get old say a year or two, parts wear out and effect the performance. Also a number of other things can effect the performance. For example if the cleaner and hose get left out of water and the hose gets tangled if will develop a memory and can greatly effect the way it runs. sometimes adding a hose or two, or removing, or even twisting each hose a quarter turn with change the way they run. You can often adjust the eyeball return fittings to redirect the water and push a cleaner a certain way or have it avoid an area. Let me know if you need more help
Posted on Sep 18, 2010
Pool weir leaks repairs required
if the skimmer is leaking or you have a cracked weir plummers putty or replace what is broken check pool supply store
Sep 09, 2013 | Pool & Spa
My Hayward pool cleaner hose keeps getting tangled
check to see if swivels are free if not move them or replace also cold water will do it
Aug 24, 2013 | Polaris 3900 Sport Pool Cleaner ()
TANGLED POOL HOSES
Tangling is sometimes problematic with the cleaners. If any of the hoses have gotten stiff it is time to replace them. If the hoses are still soft and pliable, you may need to add more swivels to the hose. This helps a lot, and make sure there is a swivel within 3 feet of the cleaner itself.
Aug 13, 2013 | Pentair White/Gray Legend Platinum...
VIPER 5500 SPINS AROUND IN CIRCLES CAUSING HOSE TO GET TANGLED. ANY SUGGESTIONS WHY?
There are a couple of things that you should try if this pool cleaners hose is frequently becoming tangled. Make sure that your floats are evenly and correctly spaced. One float should be 18" inches from each end and a third float located in the middle, 5 feet from either end. You should also make sure that the hose length is not too long for your pool size. Your spin out might be too high. Try moving it to a lower setting and then running the cleaner again.
May 10, 2011 | Hayward Viper Pool Cleaner
My bull shark does not move around anymore. I was advised I had to put weights on it but all this does is keep it in one area of the pool. There is a suction noise at the weir as well. What could be the...
Slow moving or stationary cleaners usually do not get enough suction from the skimmer. Inspect the hose to skimmer weir connection for leaks - sometimes the hose end can be worn or cracked, allowing it to **** air. Check the hose for obstructions and check the hose connection to the cleaner. Lastly, if all suction hose items check out okay, check the drive belt tension and condition.
Nov 18, 2010 | Aqua Vac Tiger Shark
Hose gets twisted all of the time Have replaced almost everything
Try laying the hose out on the ground and stretching it out as straight as you can get it. Let if sit this way in the sun for several hours. You might have a warp in the hose material that is causing these tangles. Allowing it to sit stretched in the sun for several hours will help. Also, try readjusting your return lines. They could be interfering with the pool cleaners pattern and causing the cord to become tangled.
Aug 20, 2010 | Hayward Navigator Pool Cleaner
Ray Vac Pool Cleaner for Inground Concrete: after cleaning out debris from my ray vac my jandy...
What model is it? Is it robotic (indepentdent of your pump and filter)? If it is attached to your pump system, it could be the cord getting tangled and causing the pool cleaner to move in circles. You might want to consider running it when you are available to watch it or getting a robotic cleaner that you can set to operate at certain times. You might just need to check the hose for defects that would cause it tangle.
May 17, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Krauly gets tangled in the hose constantly and will not untangle
With these pool cleaners, that is almost always going to be a problem with your hose balance. To determine if your balance is correct, turn off the pump and observe the cleaner. Hose balance is correct if the cleaner's seal rests flat on the pool floor and drive tubes make a 45 degree angle with the floor. If the hose rises toward the surface at an angle greater than 45 degrees, move the weights closer to the cleaner or move the first two weights closer to each other. If the hose sags at less than a 45 degree angle, move the weights away from the Kreepy Krauly or separate the first two weights away from each other.
May 16, 2010 | Universal Kreepy Krauly In-Ground Pool...
Seems like the movement of the navigator causes the hoses to tan
It sounds like it is time to pull the head and take it to the shop for repair. They can pinpoint wear and will usually do the repairs in the store for a small shop fee or just the cost of parts. It sounds like an "A" frame kit and gear box. Other things can be worn at the same time.
Jun 28, 2009 | Hayward Navigator Pool Cleaner
Barrcuda inground pool cleaner flips over
Often when you are having this problem with automatic pool cleaners, it has to do with the hose. Make sure that you have plenty of slack in the hose to cover the entire pool. Also, make sure that you do not have any obstructions in the hose and that it is not tangled.
Jun 13, 2009 | Zodiac Baracuda Zippy Pool Cleaner
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Logo
174 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
