Question about LG X-Note LM50 Notebook
LG M1 Express Dual Laptop
Two questions:
1. The CD/DVD unit doesn't stay closed. How can I get it fixed?
2. The laptop doesn't work for long if unconected to the main power supply. Is it something to do with the battery miser setting, or some other issue?
    Scholar:
  • 72 Answers
  1. Does it go back in and then pop back out as if you pressed the button, or is there something mechanically wrong that prevents you from pushing the drive in?
  2. Laptop batteries are notorious for losing capacity over time. Sometimes this can be due to the battery "memory" getting uncalibrated. Run the laptop on battery power until you drain it as far as it will go (save your work.) Then leave it off as you power it all the way to full charge. Turn the machine on without the power cord and once again run the battery all the way down. Several cycles of draining and charging the battery can help reset the battery. If it's just a dying battery then you may just need to get a replacement. Here are a few tips for reducing battery drain when on the go:
  • Decrease screen brightness: most laptops will have a function key (Fn+Up and Fn+Down are common keys, but find the ones with a sun icon on them) that will let you darken the screen. This will improve the battery life as less power is required for your backlight.
  • Defragment your Hard Drive: if you defrag your drive then the "arm" in it will have less distance to travel between sectors on the disk, thus saving some battery.
  • Use Power Profiles: in Control Panel you can change your laptop's power settings. If you set the profile to Portable or Max Battery most laptop motherboard's will actually under-clock the processor which will reduce the power-drain and the heat. Lower heat is explained below:
  • Improve Heat Dispersion: the hotter your laptop gets the harder the fans need to spin to compensate and disperse the heat. Keeping your laptop dust free and with unobstructed air in/out vents will save a lot of battery. Use a small pin to keep your fan from spinning (or else you will wear out the ball bearing) and shoot small bursts of compressed air into the in and out air vents. If you haven't done it in a while (or ever) then dust will probably go everywhere, so do it outside or in a well-ventilated area.
  • Remove Disks: the less time your computer is physically moving something the better. Windows will sometimes spin up a disk and scan its contents, so if there is no disk you avoid this power-draining "feature"
Posted on May 13, 2008
Is it possible that a cdrw/dvd of Toshiba Tecra M1 be replaced with a dvdrw?
Yes, it is possible to replace CD, DVD with DVD+RW on Tecra M1. Generally, it is possible to upgrade optical drive on almost all the laptops.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 27, 2011 | Toshiba Tecra M1 Notebook
Hi I have LG M1 Express dual win xp laptop i want its all drivers please help me to get it
You can download the device drivers for your model LG laptopor desktop from this WEB site. Make sure you select the correct drivers that match theversion of Windows that is installed on your laptop or desktop.
You can download the drivers from this site : -
www.notebook-driver.com/lg/lg-notebook-lm40lm50-driver/
May 28, 2011 | LG X-Note LM50 Notebook
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
LG laptp booting problum
try starting your laptop in safe mode by pressing f8 during the boot up process
Aug 19, 2009 | Computers & Internet
Dvd writer GWA-4082N (laptop)
There is a small round hole in the front of the door. Insert a paper clip in the hole to release the tray.
Mar 18, 2009 | LG GWA-4082N DVD RW Dual Layer Burner
Hi - can you tell me whether the Medion Akoya E6210 notebook has a webcam? Thanks
I checked a few sites just to verify, this laptop does not have a webcam
Here are the specs:
Performance designed for life on the go
Intel® Pentium® Dual-Core processor T3400 (2.16 GHz, 1 MB L2 cache, 667 MHz FSB) has proved a particularly powerful system. Increase your efficiency by the simultaneous execution of multiple applications: Edit a video and download music simultaneously from the Internet or use sound business applications, while security tasks are executed.
Intel® Pentium® Dual-Core technology
with Intel® Pentium® Dual-Core processor T3400 (2,16 GHz, 1 MB L2 cache, FSB 667 MHz)
Massive storage
250 GB Western Digital hard disk for storing more than 50,000 music tracks/photos*
Huge memory
3GB DDR2 SDRAM
Home cinema experience in 16:9
16" TFT widescreen display with HD resolution (1366 x 768 pixels)
Crystal clear graphics
Intel® Graphics Media Accelerator 4500 MHD based on PCI-Express technology incl. digital HDMI audio/video output to HD displays
High speed wireless connections
Wireless LAN 802.11 b/g Draft-n with up to 300 Mbit/s. 802.11 b/g compatible**
Battery life
Powerful 8 cell Li-ion rechargeable battery
Burn CDs and DVDs
LG multi-standard DVD/CD Burner with DVD-RAM and Dual Layer support***
Stay connected
Gigabit Ethernet LAN (10/100/1000 Mbit/s.) on board
Convenient extended keyboard
Integrated numeric key pad
2 integrated speakers
Stylish high-gloss design
Ports and connections
4in1 Multicard reader**** for SD, MMC, MS & MS Pro
1 Express Card Slot 54
3 USB 2.0
1 eSATA/USB 2.0
1 HDMI Out
1 VGA Out
1 LAN (RJ45)
1 Mic In
1 Line In
1 Line Out
6 Channel Audio Out (analogue & S/P-DIF)
Connect this notebook to a HD-Ready TV via the HDMI port to experience brilliant colours and picture perfect clarity with pure digital surround sound. The ultimate high definition digital cinema experience.
Huge Software Package (OEM Versions)
pre-installed and/or on CD/DVD and recovery DVD or CD
Windows Vista® Home Premium with new Media Centre user interface incl. Service Pack 1
Microsoft® Works® 9.0 incl. Office Home and Student Trial Version 60 days test version (Internet connection required for activation). After 60 days you have to purchase a licence if you want to continue using the product.
Nero essentials (Nero Burning ROM 8, Nero Recode 3, Nero Express 8, Nero Vision 5)***
Corel®Draw Essentials 3 + Corel® MediaOne
BullGuard Internet Security Pack Incl. 90 days update (free registration required) via Internet. After 90 days you have to purchase a licence if you want to receive ongoing updates.
System Recovery powered by Symantec www.symantec.com
Accessories included
Notebook carry bag
AC-adaptor
Li-ion high capacity battery
USB scroll mouse
Windows Vista® Home Premium recovery DVD
Jan 19, 2009 | Computers & Internet
Drivers for my laptop
plz check the manufacture website for the drivers
Dec 15, 2008 | LG X-Note LM50 Notebook
New 200GB HD on my LG P1 Express Dual
i have p1 express dual, i have put windows 7 ,2 gb ram , and upgrade HD to 250 7200rpm, i only have to run a cd so i update the bios. my email is m4rios@hotmail.com it took me many hours of searching to find it, i ll send it to anybody i dont believe that even lg company has that bios, is from ''phoenix''
Mar 17, 2008 | HP Pavilion dv6000z Notebook
Gateway laptop dvd drive promblem
ok you need to completely remove the cdrw from the pc remove all software (turn your pc off ) reboot it with out it ,then reboot it with the cdrw in it and go to add and remove hardware in your control panel and add driver when it asks and i think it will work correctally lala linda
Feb 01, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
LG X-Note LM50 Notebook Logo
1,471 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
