Question about Albatron PX865PE Pro Motherboard
The heat sink on one of the support chips came off and wedged between the graphics board and the thermaltake cpu cooler after the PC was knocked over. The resultant short circuit to ground has blown the motherboard and probably the graphics board as well. I have tried another graphics board but the system is dead, not even a beep from the speaker. Power supply is ok. I have software on this PC that is licenced and although I have all the licence details, re-installing on a new Windows 7 based PC fails due to incompatibily. In order to export data from this software I need to resurrect the old PC. To do that I need another compatible motherboard. Can you help in locating an Albatron PX865PE Pro please?
    Top Expert:
  • Albatron Master
  • 50,583 Answers
Clue no 1
all of the operating system, files , folders and data are on the hard drive not the mother board
you can fit a new mother board then refit the hard drive and it will be capable of restarting up again
discuss that with a computer repair shop where you buy the new mother board and graphic board
next time use the heat sink adhesive between the cpu chip and the cooling fan heat sink and install it properly
Posted on Mar 27, 2017
5 Suggested Answers
  • 42 Answers
SOURCE: manuals
Here is the page for your manual just choose your language and download.
http://www.albatron.com.tw/English/Product/MB/pro_detail.asp?rlink=Manual&no=52
Hope this helps. M~
Posted on May 04, 2008
mbase213
  • 728 Answers
SOURCE: need to purchase a new board where can i get one
I would try eBay, HERE's a Link to one up for sale as of now, but I'm sure you can find more.
Posted on Feb 10, 2010
  • 1043 Answers
SOURCE: Albatron PX865PE Pro my multimedia controller and
The following link will take you to the actual Albatron webpage. from there you will be able to download all of the drivers that you are missing. It looks like the only drivers they have available will not work with Windows 7 so hopefully you are running an older version. Here is the link:
http://www.albatron.com.tw/English/Product/MB/pro_detail.asp?rlink=Driver&no=52
This should take care of your driver issues for you.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Posted on Feb 23, 2011
  • 13 Answers
SOURCE: I have Albatron PX865PE Pro
I have found that if using a previous used hd and just reformatting the drive wouldn't allways work with some software and some pci cards.
I found out that using a data eraser first on the hd,then installing windows fully,then add the add-ons(pci Boards) and software as directed works fine.
(data eraser) my software overwrites with 00 all of the drive including the system files.
Inspirion 531S powers on. System overheats. I replaced the fans and put in a larger 300 w power supply. Some of the voltages go high causing the fans not to run. The high CPU temperatures trigger a system...
Hi
The 300W Power Supply Unit is still somewhat under-powered 550W is required so that the computer is powered by a PSU working under minimum load strain and well within its power output capacity. 300W is the original Specification, See here:
http://support.dell.com/support/edocs/systems/inspd531/en/OM/appendix.htm
See here:
Expensive, High Heat Conductive, Hot Metal, Medium Quality, Low Power, Dell PSU
http://www.amazon.com/Genuine-Dell-Inspiron-Systems-Numbers/dp/B003AOPMU6/ref=sr_1_3?ie=UTF8&qid=1315113142&sr=8-3
Relatively Good Value, High Quality, Low Heat Conductive, High Power, Dual Fan, Logisys PSU
http://www.amazon.com/LOGISYS-Clear-24Pin-Power-Supply/dp/B000CRHJKA/ref=sr_1_1?ie=UTF8&qid=1315113088&sr=8-1
Cheap, Low Quality Highly Heat Conductive, Hot Metal, Low Power, Generic PSU
http://www.amazon.com/Coolmax-M-ATX-Power-Supply-CM-300/dp/B000C1DXR4/ref=sr_1_1?ie=UTF8&qid=1315113142&sr=8-1
Sometimes, positioning the base unit directly on a carpet with a thick shaggy pile, or enclosing in it, during use in a poorly ventilated under desk cubby hole, next to a radiator, or in place receiving direct sunlight, polarised by glass in the nearby windows or some similar place can have a underestimated impact on the base unit's ability to cool itself when in use. Cooling is essential for the CPU, Motherboard Chipset, Graphics Card or onboard Graphics Chip, Hard Drive and RAM Memory. All need to be as cool as possible to work at optimum efficiency and the performance of each suffers drastically when exposed to over hot conditions, particularly the CPU which, from stone cold, can reach the temperature of boiling water within seconds of the computer being powered up and will underperform, overheat and shut down at the merest incidence of over hot conditions. So review all the salient cooling issues, then consider adding a separate, dedicated, fan cooled graphics card, its GPU Fan adding to the efficient cross circulation of cooling air to more of the interior and, also, its own built-in GRAM freeing up the 16Mb, 32Mb, 128Mb or 256Mb of System RAM that the on-board graphics chip borrowed from the RAM Modules. RAM that has to work less hard, works at a cooler temperature and thus more efficiently. The CPU works more efficiently as it no longer has to compensate as much for the loss of System RAM previously commandeered by the on board graphics, so it also generates less heat in doing so. Consider removing the (usually) green coloured, plastic Heat Conduit over the CPU and changing the CPU Heat Sink for a more effective, higher quality one, the leaving the conduit to one side. Cooling is about the rapid movement of vast volumes of air. The conduit works against itself by unnecessarily confining the hottest component in the case - the CPU. See an example here:
http://www.amazon.com/Cooler-Master-RR-910-HTX3-G1-130-Watt-Hyper/dp/B0028Y4S9K/ref=sr_1_1?s=electronics&ie=UTF8&qid=1315114816&sr=1-1
Consider also Inexpensive but beneficial, cooling Motherboard Chip and RAM Heat Sinks for the RAM Modules. Inexpensive, underside fan powered Hard Drive Coolers that screw to the underside of Hard Drives. See examples here:
http://www.amazon.com/Thermaltake-TMG-HD1-HDD-Cooler/dp/B000ZM8D4I/ref=sr_1_1?s=electronics&ie=UTF8&qid=1315115079&sr=1-1
http://www.amazon.com/Zalman-VGA-Ram-Heatsinks-ZM-RS1/dp/B0009YIJ2I/ref=sr_1_3?s=electronics&ie=UTF8&qid=1315114910&sr=1-3
http://www.amazon.com/gp/customer-media/product-gallery/B0009YIJ2I/ref=cm_ciu_pdp_images_3?ie=UTF8&index=3
The 550W PSU is necessitated by the extra cooling devices you contemplate installing
I hope this helps. If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Sep 04, 2011 | Dell Inspiron 531s Desktop Computer
My laptop trun on for a sec but then it load for a sec and trun off and the fan working it just keep truning off it does not stay on to gmake it to the menu it trun off while it loads help
sounds like its had a knock and one of the heat sinks on the CPU or graphics chip is loose and overheating. It needs to shut of so as not to damage the CPU/graphics chip.
Jul 05, 2010 | Computers & Internet
3 of 4 rings were red, now no lights at all
ok the three red rings was lit to notify you that your board, cpu and gpu have experienced a significant source of heat. So much in fact you really should bring it to a repair shop. I see these at least 4-5 times a day your 360 needs to be disassembled and the heat sinks removed this will allow you access to the cpu and gpu both sides of the board need to be heated with a equal amount of heat to heat up the solder and reseat both chips.
Mar 29, 2010 | Microsoft Xbox 360 Console
My heat sink got dirty and caused a thermal event alarm (overheated) the computer will shut down when the cpu is taxed. do i need a new cpu
No, if the computer will start and it run bios screen and boots into windows
the cpu is fine, you need to get a better cpu cooler.
Buy a better cpu cooler for your socket, coolers are designed for the Socket that the processor plugs into.
Go to Newegg.com and llok for a cooler, you will see reviews by people
and if they liked the cooler, there are little eggs next to the product
is it has high ratings, you will see what I mean when you look at the site.
The page I posted is already on the cooler page, just llok to the left side
and look at sockets and pick your socket out to look at coolers for your system.
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=574&name=CPU-Fans-Heatsinks
Feb 07, 2010 | eMachines T3516 PC Desktop
Our 18 bottle vinotemp cooler quit cooling, the electrical is ok
Sounds like the cooling unit, i.e. heat sink and controller chip. $35 + $10 shipping from vinotemp, and you install yourself. I'm looking at the same thing (on the 28TEDS), though mine came after having to replace (for $45 and my own installation, incl. soldering) the circuit board. I hope yours doesn't go, too. I've read of others. Pretty poor quality parts they appear to use. I'm trying to find somewhere to buy the controller chip on its own, as the heat sink is simply a hunk of metal. Hopefully that's do-able, as it is with computer cpu's.
See:
http://www.vinotemp.com/Browse.aspx/446/Replacement-Parts
Dec 28, 2009 | VinoTemp VT-18TEDS 18-Bottle...
Processor heats up while processing heavy graphics
The only way to keep it cool is a bigger heat sink or more airflow.
We have mounted fans into the top of the side panel of a PC to draw air out of the chassis which seems to do the trick
Get a QMax cutter and put some holes in the lower half of the right hand panel
Cover the holes with stainless steel mesh glued on with a hot glue gun
That way you create a chimney effect causing cooler air to be drawn in at the bottom and the hot stuff out of the top
If the fans can be mounted above the level of the processor then you have the optimum
Jun 18, 2009 | ASUS P5VDC-MX Motherboard
Over heating and how to change admin password
Assuming yours is windows xp.
go to start->control panel->useraccounts->
select the admin account. side list see change the password.
you have to input the old one to change the new one.
and overheating is caused by damaged heat sink interface material or even damaged heat sink.
if interface material is damaged then replace it with the intel original heat sink interface material or cooler master material.
if heat sink is damaged then select the appropriate heat sink for your cpu.
my recommendation other that original cpu coolers is cooler master cpu coolers. very less cost but superb effective against processor overheating.
Apr 21, 2009 | Computers & Internet
Intel D865GBF Motherboard
Hi Jharper91,
There is no easy way to explain how to remove your Intel® Pentium® 4 processor with out some pictures. Intel does have a site showing how to install. Once you understand how to install you'll be able to remove. Try looking through this link from Intel.
http://www.intel.com/support/processors/pentium4/sb/CS-007988.htm
Newer Intel Pentium 4 processor use 4 plastic pins to hold the retention clip onto the board. To remove them you will need to lift the motherboard out of the case. Using a needle-nose plier to squeeze the plastic ends together & pop-out the plastic pins.
The north bridge can be glued onto the chipset & have
2 pins bent inwards on themselves. Bend them in and push them through. If glued, use a hair dryer to heat the cooler, thus making the glue soften. Each board can & do use different methods to hold coolers to the chipset's. You might want to keep in mind the total db of adding a bunch of coolers. It may get very noisy for you.
I hope you find this helpful.
If I can help you more just post you're question's here.
Good Luck Jharper91!
Mike
May 21, 2008 | Intel Motherboard
Motherboard is not booting!!!!!
Hi Jay,
Is you're memory installed in the two yellow slots?
Try using only 1 DIMM in DDRII_1 slot.
Page 17 in you're manual. When using only one PCI-E graphics cards you do not need to plug in extra power to the board, as shown on page 19. (Only need this additional 4-pin Molex when running two PCI-E cards).
Check internal connector is plugged in item,
1 ATX_12V_2X (Pg. 23 in you're manual).
(System will not boot without this).
Also item, 2 main power 24-pin Molex cable is securely connected. Chassis Intrusion Header (By default is opened/no jumper). I don't like the CPU getting hot. It shouldn't. Do you have a spare heat sink & fan for you're CPU? Are you 100% the cooling system is running correctly?
Lastly, here is Gigabyte's Qualified Vendors List (QVL), for you're board. Corsair 2GB is not listed.
http://www.gigabyte.com.tw/FileList/MemorySupport/motherboard_memory_ga-ma790fx-dq6.pdf
Luck!
Mike
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
MOTHERBOARD SOUTHBRIDGE CHIPSET PROBLEM
Thermaltake sell a cooler for this though it depends on Room available
Feb 23, 2008 | ASUS P5PE-VM Motherboard
Albatron PX865PE Pro Motherboard Logo
240 people viewed this question
Top Albatron Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Mark Gough
Are you an Albatron Computer and Internet Expert? Answer questions, earn points and help others
