Question about Sampo LME-17S2 17 in. LCD Television
When I boot up my Windows XP PC the system starts to boot but then displays NO SIGNAL on the SAMPO monitor.
  • Sampo Master
  • 8,457 Answers
This is not a monitor problems.Check ur video cable connection.The computer might have a bad video card.
Posted on Sep 07, 2010
Emachines T3516 won't boot and displays "no signal" message
If you're using a VGA monitor, select to start up using VGA mode.
May 20, 2012 | E-Machines eMachines Desktop PC
I HAVE BEEN GIVEN A LT 456s MONITOR AND AM TRYING TO HOOK UP TO A GATEWAY COMPUTOR WITH WINDOWS XP- WHEN I TURN IT ON THE GATEWAY WINDOW SHOWS UP AND THE THE WINDOWS XP AFTER THAT IT IS BLANK UNTIL A NO...
I think you are experiencing something that happens a lot when you change monitors, possibly 'downsizing'? Your graphics settings on your actual PC were set too high for the new, smaller flat-screen, so what you'll have to do is hook it back up to another monitor, even an older CRT-style one, and then do the following steps before hooking it back up to your new 14" LCD:
  1. boot into Windows as usual, but on an older, perhaps larger monitor
  2. right-click on any empty area on your desktop, then left-click on 'Properties' at the bottom of the little pull-down menu that pops up
  3. when 'Display Properties' window comes up, click on the very last tab to the right, labelled ''Settings'
  4. find the 'Screen Resolution' slider bar about two-thirds the way down that window, and adjust the slider control to a more standardized, universal setting, like '800x600', or even '1024x786'. Either of those should work with your new LCD flatscreen.
  5. make sure you click 'OK' on that window, then 'Shut Down' Windows properly (using the Start button, and all that)
  6. disconnect your old monitor, and hook your new one back up. It should work!
This happens a lot. I build HTPCs, so it's even worse the more 'options' you have, believe me.
Hope this helps!
Mar 10, 2011 | Mag Innovision lt456s 14" Flat Panel LCD...
Computer boots up shows windows xp and start up then monitor goes black if i switch it of and on it comes on for a couple of seconds and displays desktop then goes black have tried another monitor same...
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 14, 2010 | Computers & Internet
Monitor says: "Out of range"
This means that a video signal has been detected but it is beyond the range for display. As an example, if the monitor can only display 1024x768 and you send it a signal at 1280x1024, you will get that message. Try to downsize the display settings on your computer system until the monotor works.
Dan
Nov 06, 2009 | BenQ FP767 17" LCD Monitor
Will not boot up. Screen displays Window XP
Use your original Windows XP CD and run the recovery console when starting up the pc. Thats should repair any files which are hanging the pc at the XP logo
Oct 13, 2009 | HP vs17
Princeton Digital VL1716 Monitor "No Signal Message"
Roxio Changed Your display settings on the dual display.
Right Click on desktop>goto Prefences>
You should see both monitors indentfy the one and change it to a lower resolution.
Apr 28, 2009 | Princeton Digital VL1716 17" LCD Monitor
"No Signal" on monitor after boot
hi try to use different slot on your motherboard see if that helps if not try different video card...if that didn't help it might be your motherboard that went bad
Aug 23, 2008 | HP Pavilion a400n (DQ173A#ABA) PC Desktop
Sampo PME - S7: Screen is blurry when using as monitor....but looks good when i play a movie on the pc
could you give more info?? how are you getting the signal out of the computer? have you tried other computers on the same monitor. could be the video out of the comp. do you have another source for the monitor you can use??
Jul 31, 2008 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Sampo LME-17S2 17 in. LCD Television Logo
57 people viewed this question
Top Sampo Televison & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
