Question about Samsung Convoy Cell Phone
My samsung convoy won't turn off. I hold down the End key and it powers down then powers right back up again. I've pulled the battery and also done a Restore to Factory Settings and neither fixes the problem
  • Jim Boselli Oct 19, 2011
    Did you ever get a solution to this problem without trashing the phone? I have exactly the same problem.
    jboselli@juno.com
hemantraj
  • 638 Answers
SOURCE: reset to factory mode on Samsung U900
taking it to the service center is much advisable
Posted on Aug 30, 2008
sWatti
  • 188 Answers
SOURCE: Samsung A707 Stuck at startup screen (loop)
No hard reset wont help!You should try following to get rid of this problem:
  • Change your phone's battery.
  • Change your charger.
  • Hard reset wont be possible in this case.
  • You should also consider charging your phone for long time but still if does the same loopy thing then change your charger.
Thank you and good luck!
Posted on Dec 03, 2009
  • 68 Answers
SOURCE: How do I do factory reset of my Samsung i-900
try it again and make sure you are pressing the buttons
Posted on Jan 24, 2010
asber
  • 291 Answers
SOURCE: Samsung Jet S8000 Cell Phone how to Restore
Remove your sim card and sd card, and type this to your keypad, *2767*3855#
Posted on Feb 17, 2010
SOURCE: what is the lock code for samsung sgh-450i mobile
00000000 is the default code for this model. Try this.
Posted on Jun 28, 2010
Samsung Convoy 3 SCH-U680 Rugged 3G Cell how do i turn it on?
Open the phone, then press and hold the End/Power key
Jun 01, 2016 | Samsung Cell Phones
How do I turn off "safe mode" on a Samsung Galaxy S4?
To turn off
Powering down , then back on should do the trick. Be sure to completely down. Do not select "restart". If you still have problems, remove back cover and pull battery from device. Leave the battery out for about 60 seconds, then place the battery back in, assemble the rear cover and start the phone again.
Some galaxy s4 models may require you to press and hold the volume down button during start-up in the same manner as enabling it to exit safe mode.
http://www.technipages.com/samsung-galaxy-s4-turn-safe-mode
Nov 17, 2015 | Samsung GALAXY S4
How do i reset my samsung galaxy 3 if it wont come on?
1. If your Samsung Galaxy S II is frozen, Shut the POWER OFF, take the battery out and put it back again.
2. Hold the Volume Down button
3. Briefly Press and release the Power button
4. A menu will then appears that let you allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Quickly Press and release the Power button
7. Select Volume Up for YES and Volume Down for NO
If the above procedures doesn't work. try this another method:
1. Turn the POWER OFF, pull the battery out and put it back again.
2. Simultaneously press the Volume Up, Home and Power button
3. If the Samsung Symbol appears, release the Power button
4. A Boot Menu will then show, Use the volume up/down to choose and home to select.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
Phone locked up
To Restore to factory settings
1. From the application menu, Select Settings
2. select SD Card & Phone Storage
3. Select Factory data reset
4. Select Reset phone
5. Enter your password if required, then Select Yes to confirm
To do Hard reset if your phone is frozen:
1. Turn the power off. If your Samsung Moment is frozen, pull the battery out and put it back again
2. Hold the Volume Down button, Call and End until "Samsung" appears on the screen along with a menu
3. Select Master reset device
4. When the phone is done erasing, choose the option to reboot
Once the Samsung Moment reboot it returns back to factory-fresh default state settings.
Feb 21, 2014 | Samsung Galaxy Reverb SPH-M950 Virgin...
Samsung sgh T669 won't turn on
Dear Brother;
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 06, 2012 | Samsung Gravity SGH-T459 Cell Phone
Phone is not turning on
5.Wait 10 seconds.
Step
Thanks
Oct 08, 2012 | Samsung Convoy Cell Phone
My samsung phone crashed and won't open again
You can first attempt to do a "soft reboot" by pulling the battery at the same time as the screen is flashing the logo as you stated. (Pulling the battery IE:remove battery with phone in 'ON' state) If this does not solve your problem, a "hard reboot" might be your only other option, (short of bringing it into to a service center location for your cellular provider or sending it into to a service center via postal delivery). To perform a hard reboot on the Samsung Galaxy Pro please follow the proceeding steps as they are listed: Press & Hold The "Power/Lock Key" & "T/3" Key Of The Qwerty Keyboard At The Same Time Until The "Android system recovery " Menu Shows Up. Use The "Volume Key" To Scroll Down & Select "wipe data/factory reset". Press The "Home Key" To Proceed To The Next Confirmation Step. Use The "Volume Key" Again To Scroll Down 7 Times & Select "Yes - delete all user data". Press The "Home Key" To Perform Hard Reset. After 2 Or 3 Seconds It Will Show Data wipe Complete. All User Data Will Be Removed And The Device Will Be Restored To Manufacture Default. Press The "Home Key" To Reboot System Now.
Sep 26, 2012 | Samsung Galaxy Pro B7510 Unlocked...
Virgin mobile venture won't start
Take the battery out. Then put it back in. I couldn't find anything that would work but doing a hard reset. Once I did that the phone worked again. I lost everything but my phone works again.
To hard reset the Virgin Venture please follow the instructions below:
Start with the phone turned off.
  1. Press power button until the phone turns on and vibrates.
  2. Press and hold the up volume button until you see the word hello.
  3. Release the up volume button.
    Note
    : You will see the word hello on the screen for about 5-7 seconds.
  4. The screen will display the android guy next to an exclamation point inside a triangle.
  5. Press the home button to access Android system recovery screen.
  6. Scroll to and select wipe data/factory reset.
    Note
    : The volume button scrolls and the enter/return key selects
  7. Scroll to and select Yes.
  8. The Venture will reset.
  9. Select reboot system now.
The Venture will reboot to the initial setup screen
Aug 10, 2012 | Virgin Mobile PCD Venture No Contract...
My samsung convoy phone will power on, but it stops there. I get the Verizon wireless logo with the back light - than nothing.
I don't have a solution but I experienced the same problem tonight, which is why im here! any answers would be lovely, i've only had this phone for 2 weeks! :(
Mar 29, 2011 | Samsung Convoy Cell Phone
Samsung Convoy Cell Phone Logo
1,037 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
