Question about Janome Memory Craft 9000 Computerized Sewing Machine
Hi, I have Janome m.c. 9000. I want to be able to sew larger designs than the standard hoops. Sizes 1,2,3. I have hoop 5 but no software to use it. Is there a larger hoop i can get that is a one position hoop. Thanks Donna
  • 161 Answers
I think you'd have to connect the patterns manually, such as using a clothe setter as i don't think this machine has the reach of other machine
Posted on Sep 13, 2010
Need help using flash stick to download embroidery designs from computer and what they are jef, emb,
.Jef and .Dst will work on a Janome machine. You can buy designs per the hoop sizes for your machine. Buy, download, and transfer received file to a USB drive to transfer deign to machine.
Cheers,
Embroidery Services
San Diego, CA
May 28, 2016 | Janome Memory Craft 9000 Computerized...
How do I clear the memory?
What size lettering are you using? You can try smaller lettering or a larger hoop.
also try going to edit then clear.
Mar 07, 2015 | Janome Memory Craft 9000 Computerized...
My 9700 shows hoops a and b but I have a gigahoop and do not know how to program my machine to reconize it
Your machine will only recognize the 5x7 hoop. The giga hoop is two 5x7 hoops next to each other. When you pull up the design on the screen it will show 2 hoops. Each hoop will be one half of the design. One design will be upside down from the other. That's the way it should be. After stitching out one side of the design, turn the hoop, and stitch the upside down part.
Dec 30, 2010 | Janome Memorycraft 9700 Computerized...
Can a memory craft 9000 embroidery machine embroider hats?
I have seen some clever ways on you- tube to make unusual shapes fit into the hoop, using clips etc. You can also buy sticky stabliser so the hoop holds the items without it being in the hoop. I'm sure you can also get devices to help you embroider hats, but i'm not sure they will fit the 9000. try an internet search for more information and possible devices
Sep 05, 2010 | Janome Memory Craft 9000 Computerized...
I have a Janome 300e. Can I use Memory card#106 (QUILTING DESIGN?) Also what is a clothsetter? Please let me know. I would appreciate your quick reply. Thank you.
the cloth setter shows you exactly where the pattern is going to appear on your garment. the hoop attaches to your cloth setter just as if it was the machine ( so you need the one that goes with your machine), you postion the material and it shows where the design with be,and then you finish hooping. when you take off the hoop its ready to go onto the machine and you'll know the design is the correct palce. there is a tutorial on the clothsetter on youtube.
As for the disc, do a search online, but i think its only for the 9000 and 5700
Aug 19, 2010 | Janome Memory Craft 3000
I bought a large hoop for my machine. But I still
From what I have been able to find out about this model, the embroidery area is limited to 4 x 4.
A larger hoop cannot change the built-in configuration of the machine's computer.
You can use a larger hoop, stitch out what you can and then re-hoop to finish - this is not easy to do.
Measuring the distance between the letters and then centering the last letter to match the previous stitching can be done, but it takes a little practice.
You can make a template using tear away stabilizer.
Stitch out the first 5 letters. Carefully remove the stabilizer - this is going to be a portion of the template.
Hoop another sheet of tear-away and stitch out the last 5 letters (these will partially overlap the first 5 when finished). Remove as in the first step.
Overlap the two templates (tape them together) and this should help you align the letters when you have to re-hoop.
Testing and a bit of practice is how I do it.
There is editing software for splitting designs and if you are interested - check Embird as it seems to be the most reasonable.
May 16, 2010 | Brother HE-120 Sewing Machine
How do you use the Plus Hoop on a Husqvarna Viking "Rose" Sewing Machine?
The plus hoop is a multi positional hoop that allows you you to embroider designs up to 4" x 6". It is essential for monogramming and lettering using your Rose. The Rose hooping system is the same as the 1+, the Scandinavia 300 and 400.
The designs you use must be formatted for the plus hoop. That is, the design has already been divided into two or three elements. Each element is an individual design. For instance, say the design is a long stemmed rose. It would probably be divided something like this: design 1: the flower and the top part of the stem, design 2: The middle part of the stem and the leaves, design 3: the bottom part of the stem.
You would hoop up your fabric to be embroidered, attach the hoop to the machine, set the hoop to position 1, select design 1, stitch out design 1, set the hoop to position 2, select design 2, stitch out design 2, set the hoop to position 3, select design 3, stitch out design 3. You should have a complete design when you're done and everything should match up perfectly!
The hoop is divided up into three squares, 4" x 4". Position 1 square overlaps position 2 square and position 2 square overlaps position 3 square. This overlapping allows the designs to stitch out more smoothly.
I hope this helps. Let me know if you have further questions. Carrie
Aug 27, 2008 | Husqvarna Rose
Bernina deco 600
Sorry to inform you but your machine only sews 4" x 4" . The arm on the machine can only move 4 inches up and down and 4 inches left and right.
The size of the hoop does not affect this. If you have a multi position hoop you can sew multi 4 x 4 areas without re hooping.
Feb 28, 2008 | Bernina Bernette Deco 600
Janome Memory Craft 9000 Computerized Sewing Machine Logo
87 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
