I have installed a scanner device:fujitsu fi-4220c every seems to be ok but when i run the image program i got the following message: failure in initialization of scanner.scanner is off-line or scanner is power-off. but my device is on and ready.
    Sergeant:
  • 191 Answers
Check the cable and i would advice you try installing the device software again.I hope this solution has been helpful.
Posted on Sep 07, 2010
Mac driver
Not from the manufacturers website but I found this interesting application that you may need to investigate as it claimed to fix your problem. http://www.hamrick.com/vuescan/fujitsu_fi_4220c.html
Apr 27, 2014 | Fujitsu fi-4220C Flatbed Scanner
FUJITSU Twain 32 - Code DS42019 Error pops up on screen whenever I try to use my scanner. I have restarted it many times. Any advice?
Here's what I've done. Maybe it's too late to help.
1) install the latest driver
2) restart
3) go to device manager
4) right-click on unknown device and click update driver
5) Select Let Me choose and select an imaging device
6) Click have disk and browse to c:\windows\fjmini and select fi4120c.
7) let it install the unsigned driver
8) You may have to restart after installing
9) Try opening your scanning software and then select the WIA driver for your scanner
I've installed many fujitsu scanners on windows 7 systems
Works perfectly.
Apr 21, 2011 | Fujitsu ScanPartner fi-5120C Pass-Through...
Does fi 5120 driver works on Window 7?
Fujitsu fi-5120C is compatible with Windows 7. However, you have to download and install the scanner drivers for Windows 7. Click HERE to download the required drivers and toolkit (Installation & User Guides are also available).
Run the downloaded file and follow the on-screen instructions to install the scanner drivers/ toolkit.
Hope it helps! Good Luck!
CreativeTECH
Mar 16, 2011 | Fujitsu fi-5120C
Fi-6140-Rollers keeps moving even when doc feeder is empty.
There may be a piece of paper stuck in the sensor area, the scanner assumes there is paper and it keeps working. Blow gently and remove all shreds of paper.
S. Mohan
Aug 09, 2010 | Fujitsu fi-6140C Document Scanner Flatbed...
Fujitsu FI-4220C only scans one page at a time.
The problem is not just to roll over, be changed and separation pad. These two components change very easily and boxes that are delivered and indications for replacement.
These are the codes for parts:
Pad Assembly - Part Number: PA03289-0111
Pick Roller - Part Number: PA03289-0001
After replacement counters to be reset for each Pieces. Open the scanner properties.
Usually have to display a maintenance message on the computer display, such as: separation pad should be replaced.
If there is to scan any messages like that, you have to clean the sensors around the separation pad. They are round and are getting a little inside. Click on the blue button at the top of the ADF and open the lid.
I hope you was helpful.
Aug 10, 2009 | Fujitsu fi-4220C Flatbed Scanner
TWAIN Driver Error
If connected via USB, unplug cable and insert into another available port and error message should disappear.
Nov 14, 2008 | Fujitsu fi-5120C
Windows can't find driver for FI-5660C
THE PROPER WAY ON INSTALLING USB DEVICES 1. Do not plug in your device right away. Install all drivers and software first! 2. Reboot 3. Plug the power or turn on your USB Device 4. Plug in the USB Port. 5. Windows Will detect the Device Automatically. Finish! Hope this helps.
Sep 19, 2007 | Fujitsu fi-5650C Path-Through Scanner
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
