RCA, rear prjetion, 46" tv,no power, ticking sound
The tv is model # p46720lvlg2 and chassis # is ptk169pka.
If i hold down the power button the green light blinks and when i let go of it nothing happens.but When i go to the back of the tv there is a ticking noise coming out around the flyback and a transformer when i hold the power down not sure where it is exactly.
Iv had 2 years of electronic training. But its been about 3 or 4 years since iv done any work on electronics and im a bit out of practices.
I did do some research before asking. what i have found is its ether the flyback or horizontal output transistor and the blue caps. Im not sure witch it is or if its something else.
or if at all possible to get a new board would be better yet
  • 8,617 Answers
Ticking is usually related to the horizontal output and the flyback with the flyback being more suspect. If you need more assistance please let me know
Posted on May 13, 2008
My sanyo 42" green light is flashing on and off and there's a ticking sound coming from the back where two matching, looks like batteries.
Posted on Sep 17, 2011
Model number p46151wk, can turn tv on with power button but automatically turns back off
A number of possible answers---I need to know two things= on back of set aside from model number is there a chassis number like PTK 195 etc? Is power light green and going off or remains on?
Aug 27, 2012 | RCA P46924 46" Rear Projection Television
Have Hd 1080 series tv model # vs-50111 tv will not turn on. When you try to turn it on green light stays on for 3 seconds then nothing.
it may or may not have the self check but try this:
When green light comes on and goes off ON THE FRONT OF THE SET press and hold the menu and input buttons at same time for 5 seconds or more and release both.
Power light should blink a two digit error code like 2 blinks, 2 blinks and pause--repeat it several times--all their sets after 1999 have this feature.
If yours does not someone has to go inside and measure voltages etc to find problem---a lot of the older ones develop broken solder connections and the chassis would have to be examined for that.
SD TECH
Apr 22, 2012 | Mitsubishi Televison & Video
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Sharp aquos 45 inch tv power light blinking
Please let me know if you can get any sound at all out of your unit.
solution
I had a similar problem. I had a 52" RCArear projection tv. It would do this when I initially turned on the television, but then after a few "on/off, on/off, on/off" cycles it would stay on. Eventually it started doing it more; until finally there was a spark and that was it. The tv was dead.The bloggers called it "the blinking green light of death" (because of green light on the panel).The power board is going out.ALSO holding down the Input and Menu buttons afterward will give you some diagnostic information via 2 sets of blinking indicator lights.
You may very well have issues with capacitors on this set being that it is or very similar to the V26 chassis. Since I have spare test lamps laying around, I would normally try that first. If the lamp still would not stay lit, I would then suspect the electrical chassis (capacitors). When I suspect the chassis, I can usually verify it by pulling it out and partially disassemble it and find blown capacitors
Jan 12, 2011 | Televison & Video
The tv was working fine. Pressing the button to turn it on only turns it on briefly (sound but no picture) then it turns off. The standby/timer light blinks six times repeatedly.
I have a sharp Aquos LC-65D64U TV that does not turn on when I press the power button on the remote and on the TV itself, the power light on the TV just keeps on blinking. Can it be that it is on...
Do you get any sound at all?
Solution
Jan 12, 2011 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
TV DOESN'T TURN ON AND BLINKS RED LIGHT 5 TIMES
Please follow up with me if you get any type of sound.
Jan 12, 2011 | Sony KDL40EX500 40 in. HD-Ready TV
Plugged in, do not have power, no stand by light or power on light. When I push power, nothing happens. I tested 110 circuit all the way through the cord and into the tv and it has power. I do not have a...
Please follow up with me if you get any type of sound at all.
Jan 12, 2011 | Fujitsu Plasmavision P55XHA30WS Television
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
