Question about Lexmark X4270 All-In-One InkJet Printer
Printing problems everything is hooked up properly yet when the paper to be copied, or printed, comes out it is blank. Tried replacing ink, nothing is working! Help!
    Guru:
  • 1,463 Answers
Hello treese
have alook here Customer Support
see if this will help you .
riz.
Posted on May 15, 2008
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Making noise like its printing but nothing comes onto the paper
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jan 21, 2012 | Lexmark X4850 WIRELESS All-In-One InkJet...
Trying to copy and nothing printing. Ink levels are good, paper is coming out
Perform "clean print heads" in printer properties select printing preferences,service then click clean nozzles, perform twice or thrice then do the nozzle test, if print heads are recovered your will be in safe, other wise***Two print heads are in this printer each print head leads two colors, left print head leads black & yellow and other one leads cyan & magenta. You need to replace the print heads based on the color which missed.
Jan 03, 2012 | HP Officejet 6500 Wireless All-in-One...
I cannot get my HP 6500A Printer to print my Safeguard checks. I can print the checks on blank paper and then copy them onto my Safeguard checks, but I cannot print directly to the check. I can print to...
I had the same problem and a HP Tech finally found a solution and I hope it works for you...When you print, change your ink quality to "Draft". I tried EVERYTHING and could not believe this worked. Good luck.
Feb 03, 2011 | HP Officejet 6500 Wireless All-in-One...
Only blank pages
The print head, which is integrated into the machine, is dried and clogged. You probably could have guessed that. If you and cautious and daring you can attempt the disassembly of your machine to extract the print head. Be very careful and remember where everything goes and in what order. Anything you de-grease, re-grease. The print head is the component that your printer cartridges hook into. Once out the bottom side will look like a large gray square. The best you can do at home is to set in on a folded paper towel thoroughly dampened with distilled water. Let this sit over night in an area that seeping ink will not damage anything, i.e. on a plastic disposable plate. If in the morning you see the four colors flowing you may have success upon reassembly. The worst you can do here is not get it back together and then you're at the same place you are now. Good luck, email with questions.
Feb 02, 2010 | Epson Stylus CX4600 All-In-One InkJet...
Canon MX850. Print blank after ink changes. The black ink, PGBK-5, ran out so I replaced it with a cheap generic ink tank. But it didn't work, nothing print, not even color copy. I thought the ink is bad...
That is a common problem on all Canon printers, the purge assembly on the right where the printhead parks, has a pump inside and hoses that go to the filters and ink absorbers. When that unit goes out you need a replacement. A job best done in a shop. When the printhead is not cleaned and primed properly you get blank pages no matter how full the inks are.
Dec 24, 2009 | Canon PIXMA MX850 Multifunction Printer
FAX MACHINE WILL NOT PRINT OR MAKE COPIES. I GET BLANK PAGES ON EVERYTHING
try wiping the contacts on the cartridge itself and the cartridge holder with a DRY paper towel and then re-install it.
Feb 19, 2009 | HP 1040 Plain Paper Inkjet Fax
Prints Blank Pages
i was having these same exact problems then i looked at my old ink cartridge and saw that the blue tape was off and that i hadnt taken it off my new one i was trying to print with.!!!
Sep 19, 2007 | Dell A960 All-In-One InkJet Printer
Printer problem
This may sound silly, but I've seen it done many times. When you installed the new ink cartridges, did you take the little piece of tape off the printhead? It's put there to prevent leaks, but it also prevents printing if it's not removed.
Aug 27, 2007 | Xerox DocuPrint M750 InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
