The notebook doesn't turn on. The power supply is ok.
    Sergeant:
  • 191 Answers
It might be due to the lead that actually allows the notebook to start is faulty i recommend you take to tech department for assistance since i suggesting you do not know how to open your notebook.I hope this solution has been helpful.
Posted on Sep 07, 2010
Acer P221W turns off without warning
tried with unplugged and re plugged doesn't resume in normal ?.ok check loose connection in the power adapter.if still doesn't resolved the problem, at this time you will need to check the power supply if it is working.you can use a digital tester or an analog to make a voltage checking.
Oct 07, 2012 | BenQ FP71G 17" LCD Monitor
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
How do I test whether power supply is OK? My unit does not turn on.
To test the system turn it on and plug in a USB device, if it operates you power supply is ok, if nothing happens then most likely the battery is dead not getting charged or is defective, is this what you are asking? if not please let me know
Dec 01, 2010 | Toshiba Qosmio G35-AV600 Notebook
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
Acer aspire 5552nwxmi notebook can't power on.
Unplug the battery and power supply from the laptop, then press and hold the power button for 25sec(No battert and power supply), then connect the cable back to laptop, then try to turn on the computer, if its turning on hten connect battery back to laptop...
Nov 24, 2009 | Acer Computers & Internet
Doesnt turn on
Either there is a bad fuse under the cover, or the power supply is shot. THe fuse should be a glass fuse which has a wire inside of it. The wire should extend all away across the fuse. If it doesn't than the fuse is bad. If fuse looks ok, the power supply is probably shot.
Jun 22, 2009 | Directv Plus HDTV Receiver with Integrated...
Notebook cannot power up
Any lights on the A/C power adapter ?? If not, then the power adapter is faulty. If the adapter is OK, the power connector on your Lifebook is faulty. Good luck
Jun 21, 2009 | Fujitsu Siemens LifeBook E4010 Notebook
My HP NV900 doesn´t start
have you tried charging the battery?so we can pinpoint the problem
Dec 31, 2008 | HP Pavilion dv9000z Notebook
Power supply doesn`t work
get a solder iron and a little solder wire pull the lappy down again and set another post i/ll show you how
Apr 13, 2008 | HP Compaq Business Notebook NX9010
150 W ATX Power Supply HP-150SS
All you have to do is connect the green wire (normally thinner than the rest of the cables) to any black wire. This can be done easily with a short piece of wire. If the power supply doesn?t immediately turn on (within 2 seconds) remove the wire, you may have connected it to the wrong wires, although most power supplies won?t allow a short to damage the unit. Once on, the power supply isn?t loaded so the voltages won?t be as stable as if they were used in a full PC, however it?ll be sufficient for most uses. It?s not a good idea to leave a power supply on in this fashion for a long period of time too."
Aug 10, 2007 | Dell HP-150SS (HP150SS) 150-Watt Power...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
