Motherboard fires up and goes to bios no prob but when its time to install operating system it freezes up on green screen before that. reads allvmy hardware in bios
    Scholar:
  • 128 Answers
Try to restart the bios by gently removing the BIOS battery to restart the setting and for it to load the default settings which is much advisable.
Posted on Sep 07, 2010
How to reset bios?
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
this will set the boot order
hope this helps
if this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Aug 01, 2012 | Asrock G41MVS3 Motherboard
Sylvania Netbook 7
sounds like the bios battery is dead , it looks like a watch battery and may be soldered to the motherboard. I would trash it and get something newer. any new android phone or tablet would be better.I would suggest the 7 inch fire tablet for $50
Apr 21, 2017 | Sylvania G-Netbook
Hello sir i have new M4N68T-LE-V2 with new amd athlone 260 my prob is when i install drivers in xp and restart then blue error appears i update bios change install directory also change ram and try...
Hi, you can download a manual here if you don`t
have one:
http://www.asus.com/Motherboards/AMD_AM3/M4N68TM_V2/#download
Please select your operating system 32 or 64 bit system.
Select manual and click on global for download.
Unzip the file before you can read it.
My guess is that your harddrive has a defect.
Or the windows disc is broken so all the files on
it not being loaded properly on the harddrive.
A blue screen is typical harddrive failure.
Try to change the harddrive with a new one
and see if the problem helps you.
Aug 31, 2011 | ASUS M4N68TM Motherboard
Just frozen on hardware monitor, can't install operating system.
it freezes on the bios screen or the post bios screen (black screen white letters)
Mar 13, 2011 | Biostar ATX AMD Motherboard A770E
I am using a MS-6309 N1996 Ver 1 motherboard...how do I get into BIOS? I changed my hard-drive and now the screen eventually goes black at power up and a cursor flashes. I tried the 6 floppy discs initial...
Hello, you usually press 'delete' or maybe the tab key on power-up. Try and read the message that will flash up on the screen, usually momentarily, just before it starts to boot. Instead of powering down then back on, press your 'restart' button then you might see the messages that you may have missed if your monitor was still warming up. Regards, nicam49
Jan 22, 2011 | Intel Motherboard
WINDOWS NOT SHUTTING DOWN COMPLETELY
dude i think its the BIOS prob try reseting the bios u can do so by removing the maotherboard battary for one min aand then replacing it this will surely rester the bios.this should it
Feb 03, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
First Hello. Before few days,when I turn on my PC(but I was unpluged my machine from electricity) and on monitor displays CMOS wrong set date/time,cpu frequensy.I hit BIOS set up sittings and Windows xp...
Replacing the bios battery was the correct thing to do. Answer me this. The Asus motherboard should have a green LED light lit (Standby power LED), when the system is turned off. Also keep the power cord for the power supply connected at all times. Though it is possible the replacment bios battery was all ready low on voltage or dead. When you're system is turned off the power supply continues to send 5volt DC to the motherboard which maintains the bios 3volt DC.
If the green LED is not lit than there is no power charging the bios battery and every time you boot the system the bios will have lost its settings. If the green LED is red in color, than the problem is within the standby switch built into the motherboard. The standby circuit can not be repaired. Double check all power connectors from the power supply to the motherboard. If everything has a good connection and you're bios settings continue to reset you should consider replacing the motherboard. At this point you have nothing to loose. Install the latest bios update,
(Beta Version 1010.005). 2006/02/14 update.
http://www.asus.com/product.aspx?P_ID=d2Gi3Hr6quXOk51C&content=download
Mike
Jan 23, 2010 | ASUS A7V880 Motherboard
Problem with installing win2003 on motherboard DG31pr.
Try another set of memory modules.
Perhaps remove and reinstall the memory modules.
Mar 27, 2009 | Intel DG31PR Motherboard
Problem with installing video/audio drivers..
i don't have audio driver of intel p4 processor.how can i download it?any website for that?
Dec 03, 2007 | Intel 845GE Motherboard
Presario v2555us harddrive and bios
A damaged hard drive will NOT affect your bios, however a bad motherboard, ROM, chip, memory, etc. can cause your system to freeze when entering BIOS. You probably need to send it out for repair.
Sep 07, 2007 | HP Compaq Presario V2555US Notebook
Computers & Internet Logo
David Payne
David Payne
