Question about Hummingbird GPS
Hi I have a Hummingbird dc25 marine radio without a power lead. I would like to make a power lead complete with 5 or 6 amp fuse. Is there a diagram which will show me the positive and negative points of contact? Thank you Vincent Browne
    Problem Solver:
  • 7 Answers
The power cable for the DC 25 is still available. Its part number 720002, its available from several places as well as ebay for about $15, I believe it still needs a fuse though.
Posted on Jun 16, 2011
How to repair wires to battery pack on hummingbird fishin buddy 149c
Hi Susan
I'll try to help you out if you could tell me what repair you're trying to do and why.
-Steve
May 06, 2015 | Hummingbird Boating
What size supply fuse
I = P/E Current = power/voltage
Therefore 25 watts of power divided by 12 volts if that is the battery voltage, equals about 2 amps. You should try a 3 or 4 amp fuse..
Jul 30, 2014 | Cobra 25-Watt VHF Marine Fix Mount Radio,...
My hummingbird 175 does not show fish contacts
Obviously your hummingbird has stopped humming.
Check the most obvious things first. Power to the unit. Correct voltage at unit (no volt drop). Does the main box power up and appear to function OK. Then Check the Transponder connections. Clean with contact cleaner or methylated spirits & dry. Check for transponder cable damage. Try connecting a replacement transponder. Swapping parts to a certain what is working and what isn't. If you don't have parts then it will have to go to a dealer that does.
Good Luck
Jul 22, 2014 | Boating
My Solara Dsc radio, which has worked well for several years, suddenly began blowingthe 2 amp fuse on the red power line whenever the transmit button was pushed on the mic. Why?
No worries here.
According to Uniden, the 6 amp fast blow fuse is the correct one.
Not entirely sure why there'd be a 2 amp with your old radio, but I suspect the radio is good.
-Steve
Uniden VHF radio fuse Google Search
Dec 04, 2013 | Uniden Solara DSC VHF Marine Radio
Matching wires from Seaworthy Marine Radio to Clarion M109
yes you dont need the orange but the yellow in the main power red is the iginition.
Jul 23, 2009 | Car Audio & Video
CAN I POWER MY FISH FINDER GOING DIRECTLY TO THE
Yes you can. Basically the red wire goes to the fuse box connection. The fuse box should then be wired into the positive battery terminal. The black wire is the negative ground wire and needs to go directly back to your negative battery terminal or to a common negative buss bar.
Jun 15, 2009 | Humminbird Fishfinder 565 With Transom...
I WANT TO CONNECT MY MARINE RADOI TO THE WALL CURRENT 110V. I'M GOING TO USE THE CONVECTOR FROM 110 V TO 12 V. WHAT CAPACITY SHOULD I BUY THE INVERTER (OR CONVERTER - WHATEVER ITS NAME) IN AMPS ?. IS 5...
5 AMPS would be more then you need. 3 Amps would run it ok. I would go with the 5. But do not, DO NOT, sorry for stressing this but you will ruin your radio if you do go any higher then 5 amps
Apr 29, 2009 | Standard Horizon Eclipse Fixed Mount Vhf...
2 way radios
Your radio with model number M33GMC09C2AA is a GM300 made for Central Asia, Eastern Europe and Turkey. It is VHF 25 watt with 12.5 channel spacing. It will do frequencies between 146-174 MHz. It should be able to be "read out" by a Motorola dealer. If it has been in a boat, it most likely is programmed with Marine frequencies. If you have another marine radio you may be able to determine the frequency by process of elimination.
The wiring kit for power is readily available for around $18 ea. If your boat has a marine VHF antenna onboard, you will be able to attach the antenna to this radio. It takes a mini-PL connector.
Sep 14, 2008 | Motorola Radio Communications
GPS Logo
652 people viewed this question
Top Hummingbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Are you a Hummingbird GPS Expert? Answer questions, earn points and help others
