Question about GE Refrigerators
Model#Gss25KSWA SS,Serial #GM400705 Purchased 10/10/07-- Problem with water dispenser. Press dispenser arm,getting drink. Pull glass or cup away & dispenser shoots water out on floor then shuts off & again shoots water on floor. Have to reach in & push arm again. Usually several times a day happening. what's wrong??
5 Suggested Answers
Bgillespie
  • 89 Answers
SOURCE: Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Posted on Dec 31, 2007
  • 18 Answers
SOURCE: Water dispenser is not working
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Posted on Jan 07, 2008
aborcass
  • 2651 Answers
SOURCE: Auto Water Dispenser
that maachine shoulnt work with out the filter inplace, all i can suggest is replacing the filter.
Posted on Mar 18, 2008
  • 61 Answers
SOURCE: -whirlpool refrigerator water dispenser
this may still be under woranty check with sears / the padal makes contact with a micro swich and the switch enerjizes the water solinoid at the water line inlet . this solinoid may be sticking open as well. if you unplug the fridge and the water still runs its likely the water valve. if the water shuts off when you unplug the fridge it'll be the micro switch.. good luck
Posted on Oct 06, 2008
  • 2692 Answers
SOURCE: water dispenser wont shut off
Something from the filter went into the dispensor valve and is holding it open. You can try to backflush it with a can of air by disconnecting the filter pushing open the valve while holding the can straw tightly while discharging it. You could also backflush it with water.
Posted on Jan 12, 2009
How do I get the water I need to drink - to come from the dispenser?
Hi Holly
Is pipe getting pinched somewhere.
Disconnect & blow through pipe to test.
Sep 13, 2015 | Electrolux Refrigerators
How do you remove the in the door dispenser cup and lever for cleaning
Depends on the make/model, but usually there are a few screws that go in from the front that hold the plastic arms in place along with the spring blade. Most of the time you need to remove the decorative plastic cover around the front of the dispenser to get at them. Pay attention to how things go together, or take pics before and during the process. It will save you a lot of headaches later.
Mar 20, 2015 | Refrigerators
How do I get the water to start coming out of the dispenser?
check that the supply valve is open, and that any filtration components are current. In areas with high mineral content, filters will clog/become impenetrable quicker than manufacturer specs,blocking water flow.
Dec 27, 2014 | GE Refrigerators
Can drinking water with lemon prevent kidney stones? Also, I have been told not to drink city water. What is the best water to drink?
One-half cup of lemon juice concentrate added to drinking water over the course of the day is a preventive therapy for calcium oxalate stone formation.
As for city water, it is safe to drink but the concern is with water softened using a sodium ion exchange. Softened water should not be used for cooking, drinking, or for ice dispensers.
visit http://knowlious.com/
Aug 27, 2013 | Refrigerators
Water Dispenser Works Intermittently
either the micro swith is bad mounted on actuator arm.if it is a ge check the barrel connection located under upper door hinge cover round barrel connnectors sometimes do not make good contact.spread male eds with small ponted awl or anything
Apr 10, 2013 | Refrigerators
The water dispenser is leaking
Is it a side by side? Did you change the filter recently? If so, Could be air bubble in water tank.
Mar 31, 2011 | GE Refrigerators
No water to the water dispenser
the water goes to filter first . then through water valve to the ice maker or foutain . . ck the valve it sounds like this is your problem .. mm hope this helped ..
Jul 04, 2010 | Refrigerators
My maytag is model MFD2560HES serial number
does the water dispenser work OK ? if yes , a try this : pour 3/4 of a cup of water into the ice maker, right into where the ejection fingers are. also , take all of the ice out of the ice bin. then , give the freezer time to freeze the water you have poured into the ice maker and see if the ice maker ejects the ice into the bin. if it does, it might reset itself and refill the unit and work normally.
Mar 17, 2010 | Refrigerators
Water dispenser gets stuck
It could be the switch that activates the lever. This happens when you have soda in the glass and then fill your cup with ice. It splashes up to the switch then it becomes sticky.
Jun 06, 2009 | LG Refrigerators
Water dispencer
Hi. This is normal and there is nothing wrong with your refrigerator. Whenever you replace the water filter on any refrigerator, you must run a couple gallons of water thru the water dispenser until all the air from the new water filter is out. Use a large container to do this. The water will not stop when you pull a cup away because the water valves used on refrigerators are so weak it will not close until it has pressure on both sides of it. If you don't get the air out, the air from your new water filter can go to the ice maker and stop ice production. So flush the air out of your new water filter. The water you are drinking from your drink dispenser may not be healthy. It may contain a small plastic floating substance. This is part of the plastic that the water tank is made of. The chemicals in the water do this. You will have this problem even with a new water filter because the water tank is after the water filter. You have to replace the Water Tank. The water tank is located in the refrigerator section on the bottom back wall. I sell low cost new designed Water Tanks on Ebay as username: themackshack. Good Luck, Mack
Mar 18, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
236 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Brad Goodale
