Question about Intel D850MV Motherboard
Hi, Computer is not able to start because its not able to perform POST. CMOS/BIOS is not starting.Nothing displayed on monitor when starting computer. I had reinstalled XP then when i had reset BIOS by Jumper setting as per manuals...pc not starting. i have Checked power supply . its fine.. RAM is also fine.. But when i m starting computer.. nothing dispalyed on Moniter. Monitor is also fine.. I have checked motherboard without any IDE, HDD,RAM... fan running fine.... Computer was working fine on previous day of problem. What may be the exact problem? Previously when i was starting pc, sometimes it was giving error as "Verifying DMI Pool Data" error. but I think it may be due to bad sector.
  • Intel Master
  • 27,725 Answers
Bad leads
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive they probably be faulty
hope this helps good luck
Posted on Sep 07, 2010
How to remove bios password
hi lata.
you can try this.
  1. Remove the computer cover.
  2. Locate the 2-pin password connector (PSWD) on the system board.
  3. Remove the 2-pin jumper plug and set the jumper plug aside.
  4. Replace the computer cover.
  5. Connect your keyboard and mouse, then connect your computer and monitor to electrical outlets and turn them on.
More items...
How to Perform a BIOS or CMOS Reset and/or Clear the NVRAM on ...
https://www.dell.com/.../how-to-perform-a-bios-or-cmos-reset-and-or-clear-the-nvram-o...
or go to this link.
How to remove bios password Google Search
Nov 06, 2017 | Computers & Internet
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
CMOS checksum error defaults loaded
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
Press F2 to load default values and continue
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Sharp Actius PC-RD10 PC Notebook
Tenho uma placa mae ibm 49p1599 mas nao esta entrando o windows xp erro na inicializacao
If power to your computer is interrupted while BIOS is being updated, your computer might not restart correctly. The Clear CMOS/Recovery jumper enables you to restart the system and recover the BIOS. To perform a Flash/BIOS recovery using the Clear CMOS/Recovery jumper, use the following procedure: Before proceding, be sure to review the safety information.
  1. Turn off the computer and any attached devices, such as printers, monitors, and external drives.
  2. Unplug all power cords from electrical outlets, and remove the cover.
  3. Locate the Clear CMOS/Recovery jumper on the system board.
  4. If necessary, remove any adapters that impede access to the Clear CMOS/Recovery jumper.
  5. Move the jumper from the standard position (pins 1 and 2) to pins 2 and 3.
  6. Replace any adapters that were removed.
  7. Replace the cover.
  8. Reconnect the power cords for the computer and monitor to electrical outlets.
  9. Insert the POST/BIOS update (flash) diskette into drive A, and turn on the computer and the monitor. The system will begin to beep.
  10. After the update session is completed, there will be no video and the series of beeps will end. Remove the diskette from the diskette drive, and turn off the computer and monitor.
  11. Unplug the power cords from electrical outlets.
  12. Remove the cover.
  13. If necessary, remove any adapters that impede access to the Clear CMOS/Recovery jumper.
  14. Return the Clear CMOS/Recovery jumper to its original position.
  15. Replace any adapters that were removed.
  16. Replace the cover and reconnect any cables that were disconnected.
  17. Turn on the computer to restart the operating system.
  18. You may now want to update the BIOS normally. Refer to the readme.txt file that came with your flash BIOS update.
Nov 30, 2010 | IBM NetVista PC Desktop
Hi, On my aspire L310 the logo ACER stays on to long (over a min). I checked in BIOS but dont see any way to reduce or to eliminate the logo. Do you have any solution for my problem? Sinerely...
Acer displays that logo to cover up the 'ugly' POST code that runs every time your computer starts up. If it used to do this quickly before but has now slowed down then your computer may be discovering various hardware issues on startup. This can also happen if your CMOS battery (which keeps the internal clock working) is running down.
First thing to do is update your BIOS by visiting Acer's support site and installing the latest one they have for our model.
If this does nothing to improve the POST time and you feel comfortable taking apart your min-desktop. Check for bubbling capacitors.
These can be replaced.
If all else fails, check the CMOS battery. It is a small coin sized battery connected to the motherboard. It is a standard battery you can find at the drugstore.
Sep 27, 2010 | Acer Aspire L310 (ASL310UD631A) PC...
No post screen, cant access cmos settings. but windows starts as usual just a blank screen til then?
Its possible that your cmos settings were changed prior to this problem so as not to display cmos settings options at boot up. Have you tried resetting your cmos settings to fix the problem? You can do this by a jumper which is usually found on the mother board named "clr cmos" (clear cmos).
Let me know if this is of help or not.
Regards,
Graemevm
Apr 25, 2009 | Dell Dimension 2350 PC Desktop
New video card wont work, acer monitor no signal
ok the IGFX is the on motherboard video you will need to set the cmos to clear the setting you did or move the video cable to the motherboard output.
after you have used the bios to switch back to the AGP you can start widows in safe mode to access the video card display options you need to reduce the resolution to a lower setting compatable with your monitor it can't resolve as high as this new video card can go.
Apr 05, 2009 | Acer X193W LCD Monitor
Mag monitor doesn't display bios post
I have no experience with the DVI links because such technology is still unavailable here in Argentina. We have DVI video cards but finding a suitable DVI monitor is another (long) story.
I think that your card (that has 2 DVI ports) is initializing one port first (the primary one) and then, when windows starts, it initializes the other and outputs video from both ports.
Try connecting the monitor in the other DVI port.
If your card has a VGA output, the VGA gets initialized first.
May 06, 2008 | Computers & Internet
After 18 month the computer will not go into POST on a re-start but will start normally when completed turned off.
simple. clear the CMOS by using clear cmos jumper setting or remove the cmos battery and put it again and then change the bios settings as per ur machine configuration.
Feb 23, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
Intel D850MV Motherboard Logo
101 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
