Question about Vizio VX32L Television
Lost picture and sound. Is there a rest button or a reboot procedure? or is the board toast??
  • Vizio Master
  • 8,457 Answers
Try unplug,replug the tv an hour later.That to reset the tv,back to the factory setting.Tv should work now.Not,the power supply board is dead.Common problems on LCD tvs.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Sep 07, 2010
How do I get my LED TV to start working?
depending on the model, if the backlight has come on but nothing else then the main av board has fun into a fault, some models have a rest sequence to use on the original tv remote to reset to factory settings, if your model does not have this feature, then turn the power off for 10 min and plug power on and holding down the either of these, power button or menu and select. some times these work to reboot.
May 19, 2017 | Televison & Video
Need solution for Samsung 39EH5003, Has sound but no picture
if the inverter board for backlight get to work so the cause either your lcd panel get malfunction or the t- con board doesn't work.
Jun 15, 2014 | Samsung Televison & Video
The radio buttons on 09 altima are not responding when u try to change to a new radio station and to cd or radio plus when u put the cd in u can't skip to the next song
First impression is you radio is toast. It maybe some component gone bad on a circuit panel inside the radio. Before you consign it to the deep try "rebooting" it. Most electronically controlled radios have some king of logic and memory boards in them ...so treat your radio like your computer when it starts misbehaving. To reboot the radio disconnect the battery (remove the black/negative lead first then the positive/red lead from the battery), put the key in the ignition and try to start the car (it won't of course but this is to discharge any holding capacitors) and turn on the radio ...again to discharge any holding capacitors. Turn everything off and let it sit overnight if you can. Reconnect the battery. The radio should have lost all saved information (time, stations, EQ settings etc) and may now be responsive to button inputs. If this doesn't work then I'd say the radio is a goner.
May 01, 2014 | Cars & Trucks
3rd gear has always crunched when drivin hard but other day lost 3rd gear altogether and then it come back and i lost 4th gear and then 4th come back and i lost 3rd again which continued the rest of the...
sounds like the syncros in your tranny are toast. they are what let your car go into gear and have little teeth on them. You know they are going bad when they start grinding. Id look in a salvage yard for a new tranny or have yours rebuild. Which can be pricey. Rate my answer man!
Jul 23, 2010 | 1991 Mitsubishi 3000GT
No Picture
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. It works fine now.
Apr 02, 2010 | Vizio L32 32 in. LCD HDTV
My plasma tv has just lost it's picture. I do have
There will be a fault in either the Y or Z sustain boards, these are responsible for driving the screen 9hence sound but no picture). The popping sound willhave either been a fuse blowing on the board or another possibility is one of the drive ICs on the buffer board has blown. If so it's best to replace the board.
Mar 21, 2010 | LG 42PX3RV 42 in. EDTV-Ready Plasma...
Lost the sound on my compaq key board has a orange light on by the mute button but i can't get the light to turn off
That definitely means the sound is muted, is the rest of the keyboard functional? I believe there is an option to turn off the mute in control panel under hardware and sound. However, I am unsure.
Mar 19, 2010 | Compaq Presario 5000 PC Desktop
Picture lost sound still ok 42" LG
Since it is coming back after a union-like break, it is probably the inverter for the fluorescent backlight rather than the light itself; they can flicker and die but normally don't recover after a rest. The inverter may be a separate board in the unit and you should be able to recognize the right board due to its relationship to the backlight.
This kind of problem will not repair itself but decay further with time.
Sep 04, 2009 | LG 42LC2D 42 in. LCD HDTV
No picture or sound
If you had a burning smell, well the board is toast. These sets are made to replace the entire board at one time. Before installing the replacement module, the picture tube should be checked. A defective picture tube ( such as a G1 short) may cause a failure in the power supply section.
Sep 07, 2006 | Zenith C32V36 32" TV
Vizio VX32L Television Logo
104 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
