Question about LG KU990 Viewty
Lg vx920v06 won't work with my mac - LG KU990 Viewty
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
How to sync verizons LG 840 with a mac computer to sync music photos etc.
For a MAC, I believe you need an SMB application. This is not free for mobiles, but I'm not sure on the MAC. SMB is a file sharing protocol that is standard for Windows file share and transfer. Apple has their own protocol that is exclusive Apple. The SMB interface app allows you to share files with a Win computer via local LAN. I do this with WiFi on my Android - PC. Really nice for quickly posting pics to net drive when you get home from outing. The Android mobile app on my LG Lucid that I use is Ghost Commander. It's a bit clunky, but once it's set up it's great for getting files from PC or posting pics-vids etc from smart phone. There are Apple SMB apps for iPhone, to do this, but the Android was free.so my LG won this personal use setup.
Dec 31, 2012 | LG Lucid VS840 4G Verizon
Lg Gp08 Lite Drivers Download Free
Sorry it will not work on a mac
see the technical specs here where it only specifies Windows:
http://www.lg.com/levant_en/video-players/lg-GP08
If you run windows from within mac (http://store.apple.com/au/browse/guide/windows) you can get it to work but it will not work in OSX
Dec 21, 2012 | Computers & Internet
I just bought the Portable Super Multi Drive from LG GP08 Lite. On the back of the box, it says that it's compatible with Mac OS X v.10.5.4 or higher, which I have, so it should work. However, when I...
Hi there! First we have to make sure the drive has power. As soon as it is plugged in and turned on (if it has a switch) you should feel it vibrating lightly. Once you feel it vibrating and it is plugged into the computer go to your Applications folder, then to Utilities. In there is a program called Disk Utility. Open it and in the column on the left you should see your drive listed. Click it and select "Erase" from the tabs on the right. Make sure that you select "Mac OS Extended (Journaled)" for the Filesystem then click "Erase." Should work great after that. Keep in mind that if there was any data on it then it will be erased by doing this. If you do not see the disk in the column on the left, then the drive is most likely bad and should be returned.
May 23, 2011 | Computers & Internet
Just got an lg ge20 not working on mac
I wish I could tell you that your Mac is compatible with the LG GE20 20X DVD Burner but unfortunately it is not.
Here are the system requirements for this burner
LG GE20 20X DVD Burner Technical Specifications
The CD included is not the only item that is not compatible with the Mac, it is also the DVD burner itself. It is only windows compatible I'm afraid.
However, I do know that the Apple.com online store, has a comparable DVD+RW burner, the
LaCie 22x d2 DVD+RW with LightScribe
which will work with your iMac.
This is a genuine incompatibility issue.
If you had an Intel iMac, there actually is a workaround process where virtual machine software, like VMWare Fusion or Parallels, could be installed, with a version of Windows XP, Vista, or 7, display as a 2nd terminal within a Mac OS X desktop.
What's makes this effective, is that the LG GE20 could work with a windows virtual machine and because software like VMWare for example, can share devices, including optical CD/DVD drives, the Mac could share that drive with the windows virtual machine.
But since you do not have an Intel iMac, unless I am reading the description of your Mac computer(Apple iMAC Mac Notebook) incorrectly, the LaCie burner information, I provided above, would be the best option for your model of iMac.
Again, if I have described your model of Mac incorrectly let me know and I will be glad to assist further.
Regards,
-Mactechtrainer
Feb 01, 2010 | Apple iMac Notebook
I've just bought one of these for a Mac G4 running
You need to locate a piece of software called Patchburn - but I think that might be difficult now.
This particular vintage mac only worked with the drive that was in it. in order to use a different drive you had to patch the system so that the new drive would be recognised as a burner - that said, it should just work as a player/CD-ROM.
The later Macs didn't have this problem and you could stick a drive in and it would be recognised straight away as a burner. I recently put a LG drive (with lightscribe) into a G5 mac and it worked straight away as a burner/player but I did have to install the lightscribe software.
Oct 13, 2009 | LG SecurDisc 20x External Double-Layer DVD...
LG GE20LU10 DVD drive will not work on Mac, why?
I can t say that i am an expert. but i think the lg only work on the pc system not on the mac. if u have mac to pc. problably give many problems of compatibility. so. what u can do is see on the website o the company and see if the have some kind of drives to mac.
Feb 10, 2009 | LG Computers & Internet
Can't get LG Viewty to sync with Apple Mac
You might gat help using a company called "mark-space software" we used it to sync a windows based GPS, it works well.
May 03, 2008 | LG KU990 Viewty
Viewty sync to mac
LG has not yet developed the drivers for mac. And you won't find them on the CD, so don't get crazy to put the minicd con the mac... it won't be useful. Just monitor the lgmobile.com mobile for the drivers to be published. LG has promised them for the first half of 2008. Until then, you can only use USB or Bluetooth to exchange data.
Apr 11, 2008 | LG KU990 Viewty
LG KU990 Viewty Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
