Question about Canon MVX330i Mini DV Digital Camcorder
My canon MVX330i had a drink spill on it and now the buttons (play, rewind etc...) dont work. can i get that fixed? or is there a remote control for this camera that i can get so i can play what i have recorded?
    Genius:
  • 1,812 Answers
Yes you can. My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 07, 2010
I have a vcr-dvd player combo ,ive hooked it up twice and cant get it work.i dont have the remote to it ,but it should work manuely right?
Model? and yes chances are if it has controls/buttons on it(power,play,rewind/prev......) then basic functions should operate fine without the remote
May 02, 2017 | Sony Televison & Video
Tip
How to program an rca universal remote without codes
If you have a universal remote but dont have the codes or the codes dont work then what you can try is to scan all the frequencys using the remote to manually scan to work for your telly or other equipment your trying to control.
Follow these simple instructions
1. Turn on the device you want the control to control ie the tv or dvd or stereo etc
2. You need to now press and hold the button for the device you want to control and also the power button untill the light on the remote stays on( for this case we are going to program it to control a tv) so press and hold the tv button and power button hold them down untill the light stays on
3. press the play button once every 5 seconds( a bank of 10 codes is being sent every time you press the play button)
4. when it turns the tv off wait press the rewind/reverse button and check it turns the telly back on if it does then you need to hold the stop button untill the light goes off.
Once you have done this check the remote is working properly ie changing channels ets if it dont work properly then follow the instructions again and try again you may need to do this a few times till it gets the right signal
on Jan 18, 2010 | Televison & Video
What causes a blinking red x on RTI TV remote?
it could be a button stuck in key pad clean pad some times drinks spill and stick.
May 06, 2015 | Rti Technologies Rti T1 Remote Control
How can I get my remote to start working again
Hi, Did you replace the batteries with new ones? If remote had water or drink spilled on to. The remote may have to be replaced.
You may be able to buy a universal remote sold in many electronic stores. Radio Shack ...etc Good luck.
May 03, 2015 | Televison & Video
Teac manuals
There are three main reasons a remote stops working.
1. Batteries require replacing (you have done this).
2. The remote is a programmable one and requires programming to the equipment you wish it to operate (you have not specified what the remote is or what it is controlling)
3. By their nature, they end up sat on the table at the side of drinks and often have drinks spilled on them.
If you have a decent phone (NOT iPHONE as they do not work), turn the camera on and point the remote to the camera. Press a button and see if the IR emitter flashes (try a working remote to ensure your camera does not have an IR filter).
If a good remote flashes but your faulty one doesn't, you need a new remote as they are generally not worth fixing.
Sep 04, 2014 | Televison & Video
Akai X-360 Reel to Reel won't play
The Akai X-360 will not function if the remote control or the remote dummy plug is not plugged in to the back of the machine. The remote Dummy plug has two jumpers for completing the circuit paths for the relays so that the front panel buttons will function.
Apr 17, 2009 | Audio Players & Recorders
Want to view my canon mvx330i camcorder through my tv
Open the front plastic cover to the right of the lens and expose the ports. The yellow one is the AV port. Press the MENU button on the left side and use the rocker switch above to display AV-PHONES, select AV, and press the MENU button to set it and close the menu. Turn both  the camcorder and TV OFF.
Connect the camcorder AV port to the TV RGB inputs (VIDEO + AUDIO L + AUDIO R) with the cable that came with the camcorder. It has a mini stereo plug at one end and three RCA plugs at the other.
Switch everything on, press PLAY on the camcorder (don't forget to make sure the cassette is wound back to the start). sit back and enjoy.
Dec 11, 2008 | Canon MVX330i Mini DV Digital Camcorder
Won`t Rewind
Do you still have the remote control? Try with the remote. If this works, the button of the camera is broken and have to be replace by a qualified technician. Good luck!
Sep 27, 2008 | Sony Handycam CCD-TR517 Camcorder
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
Canon MVX330i Mini DV Digital Camcorder Logo
51 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
