Question about Fujitsu LifeBook A6020/C Notebook
Error 00410001? How to resolve? - Fujitsu LifeBook A6020/C Notebook
Tip
Blue Screen of Death - How Do I Fix It
Those who are using Windows operating system are aware about the Blue Screen of Death (BSOD) and may be they have faced it in their PCs. This is a common error which usually occurred when something wrong with PC in hardware and software. Sometime it occurred when some major problem has been created in PC but it also come when a minor corruption occurred in it. So, the most important thing to recover the desktop screen is to detect the problem.<br /><br />Blue Screen of Death has not proper technical guideline to solve but it has various way to resolve - depends upon condition or error. Sometime it automatically resolves by restarting the PC but sometime it take great effort and time to resolve. In short there is no simple answer of "how the blue screen of death can be resolved?"<br /><br />To get the desktop screen and resolve the BSOD, user has to recognize the error. This error detection can only be done manually because both parts - hardware and software, are checked one by one. At the blue screen the error is displayed but this display shows the error in computer codes which are not easy to understand by the user. But these codes help to diagnose the error. So, once you get the BSOD error write down it on a paper.<br /><br />Unfortunately, if you couldn't get success to resolve the BSOD by rebooting the machine, then you have to do some effort for resolving the problem. It is not easy to concise the instruction of all resolving method that's why there are some hints to resolve but if you cannot resolve the blue screen error through the following guideline, then write the error code on search engine and get method for resolving through Internet.<br /><br />The first method of diagnosis the problem is to check the windows at safe mode. If you couldn't get success to reach the desktop screen in safe mode that's means there must be a hardware problem. One of your computer physical devices has been corrupted or destroyed. To resolve the screen in this condition check your devices one by one in other PC.<br /><br />If you get desktop screen in safe mode, so you're PC has software or driver problem. Once you reach at the desktop screen, scan your PC through anti-virus immediately. The anti-virus will detect the software if there will be anything wrong. If anti-virus detects any software which is virus infected, uninstall and delete the software immediately from your computer, then re-install the windows because your PC have get the virus.<br /><br />Sometime both of the above method has been failed and computer reached at the desktop screen in safe mode and anti-virus also doesn't find any infected file. This is the condition of driver failure. You have to re-install the driver to resolve the blue screen of death.<br /><br />
on Apr 19, 2011 | Computers & Internet
E studio 520 code c447
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0." also 447
Jan 17, 2014 | Toshiba Office Equipment & Supplies
Error code c43
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jan 14, 2014 | Toshiba Office Equipment & Supplies
TOSHIBA E STUDIO 207 ERROR C 44
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jul 08, 2012 | Toshiba E Studio 207
Unable to resolve "scanner error
how can i resolve the error code 22 on my hp laserjet m1212nf MFP?
Jul 23, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
When I ran the test on the computer it says error code 00410001 "may be hardware error on HDD"? The computer barely stays on, it shuts off randomly, wont even start up and just has a black screen with a...
Go into the BIOS and reset it to defaults. Then reboot it and see if the message goes away. If it doesn't then try another hard drive in the laptop, if the message doesn't go away at that point then the controller on the motherboard is bad. In that case the motherboard would have to be replaced.
Jun 02, 2010 | Fujitsu LifeBook A6020/C Notebook
Cannot print true color.
How do I resolve the error message "Calibration Page Not Found"? Error code: 3610 Question : How do I resolve the error message "Calibration Page Not Found"?
Answer : To resolve this error condition, correctly position a calibration page on the scanner. See the User's Guide for more information. How do I resolve the error message "Cover open"? error code : 3501 Question : How do I resolve the error message "Cover open"? Answer : To resolve this error condition, close the access door. The printer will not operate while the door is open. How do I resolve the error message "Color ink cartridge missing or not installed correctly"? Error Codes : 3511 Question :
Answer :
To resolve this error condition, reinstall the ink cartridge:
  1. Remove the color ink cartridge:
    1. Open the printer access door by lifting from the front center of the unit.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
  2. Check the two electrical contacts on the ink cartridge for small marks, which should appear if the cartridge was installed correctly.
    If the electrical contacts do not have small marks:
    1. Reinstall the ink cartridge, making sure you press down on it until it clicks into position.
    2. Remove the color ink cartridge, then check the two electrical contacts on the ink cartridge again for small marks. Repeat if necessary.
    3. Reinstall the ink cartridge.
  3. Close the printer access door.
NOTE: See the User's Guide for more information about removing and installing the ink cartridge.
If the error persists:
  1. In the KODAK All-in-One Home Center, select the Help (?) icon.
  2. Select Maintenance.
  3. Select Firmware Upgrade, then follow the prompts to download the latest version of firmware, free of charge.
From Kodak support:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=9104/7269&pq-locale=en_US
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Fujitsu LifeBook A6020/C Notebook Logo
650 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
