Question about Saeco Magic De Luxe Espresso Machine
Water tank stay's on
Water tank light stay's on (can't make espresso) water is leaking into tray, is there a filter, if so where, and how do you find it?
    Scholar:
  • 70 Answers
2 things. Water tank has a magnet in it (little rectangle black plastic piece on the backside). Thats gone bad. need a new water tank.
2nd is you need a water tank gasket.
Gasket is easy to fix, flathead screwdriver.
Posted on May 14, 2008
  • alex cataldo May 15, 2008
    one other thing. if you hear a hissing sound coming out of your machine it could also be the boiler may need repair
How to repair water leak from tassimo base?
The water tank at the rear must make a proper seal. Make sure it is clean and lubricate with Vaseline. The cup tray also catches drips so remove it and empty any water into the sink.
Nov 04, 2014 | Braun Tassimo Espresso Machine/Coffee...
Leaks water
the tray you pour the water into sits directly on the tank that heats the water with a gasket between tray and tank, this gasket has worn away, Bunn no longer sends replacement gasket, I made one myself
Feb 25, 2013 | Bunn 10 Cup Home Coffee Brewer
Why is water leaking out from the side tank
It is also smoking from the top of the warming plate and get's very hot. The water seems to be leaking from the top down to the side of the water tank.
Is it worth fixing? How much would I have to spend to have it fixed? Maybe I should just by a new one. My machine is only 4 year.
Jan 22, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Saeco cappacino maker leaking
Hi
If its leaking under the water tank, its this.
There is a seal on top of the machine under the water tank. To get to it, remove the water tank, and set aside. There is a large doughnut shaped cap on top of the machine. Slip a screwdriver on the outside edge of the cap and pry up gently. When it snaps up, go to the other side of the cap and do the same. There is a black seal in the center and if you stick your finger in the center and it lifts out, it needs to be replaced. Clean any residue inside the opening with a Q-tip.
When you get the new seal, it won't slip in. Insert it at a slight angle (double lips down), then take your finger nail and run it around the bottom edge of the seal until it slips in, then push down. Snap the cap back on and your set to go.
If its leaking under the machine, its your boiler.
If its leaking into the dredge drawer, its the thiumbscrew in the brew unit, that holds the filter screen in.
If its under your drip tray there is a pocket behind the brew unit that has a cloged drain, just above the center of the drip tray in back.
Jan 07, 2011 | Saeco Vienna Espresso Machine
Hello my saeco vienna coffe machine leaks on the side when I make my coffee
Try changing the water inlet seal under the water tank (part # NM05.006)
May 14, 2010 | Saeco Vienna SuperAutomatica Coffee...
Kitchenaid proline espresso maker, model KPES100NP 2. Espresso boiler frequently discharges outside of unit instead of into removable tray.
I took out the water tank. Found a return discharge hole in the middle of the over hanging brewer body. It was in the middle of the deep indention.I placed a self adhesive folded plastic door weather stripping between the discharge hole and the brewer body. I used about 1 and 1/2 inches of the stripping. I made sure the fold was angled back away from the brewer. That seemed to force the water back into the water tank and my counter has stayed dry. I still get quite a bit of water under the catch tray, but if i clean it one every 20 pulls it has never over flowed.
Jul 19, 2008 | KitchenAid PRO LINE KPES100PM Espresso...
Central unit light on a Magic delux is on Saeco
My water tank light stay's on ( can't make espresso) plus water seem's to be leaking out into tray area, also can you tell me where the filter is, and how to get to it? Helpppppppppppp!
Apr 28, 2008 | Saeco Magic De Luxe Espresso Machine
Water light is flashing but tank is full
I had the same problem - Cause: plugged water filter. We always used RO water so never replaced the filter. After 4 years I guess it was due.
Solution: Reprime the water system. Remove water filter. Fill tank with water. Turn machine on. Put a container under the steam/hot water wand and open the knob on the front panel. You may need to run half a tank of water through it before it resets. Hope this works for you all.
Mar 09, 2008 | Saeco Magic De Luxe Espresso Machine
Water leaking into machine
This happens when the boiler develops a leak, usually due to scale buildup. Order a new boiler and o-rings and replace.
Sep 29, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
234 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
