Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
I have a raypak 2100 heater and it display a PLT code what can i do to fix it it tray to start but shoot down rigth a way
  • 331 Answers
The "PLT" error code means pilot failure. The lack of spark may or may not mean an ignitor problem.
The "PLT" code could come up because the main valve in the heater was in the "off" position. No gas = no pilot.Also check clogged pilot-burner orifices. The lack of spark can also have to do with water flow issues (dirty filter, clogged basket, etc.), or it may be a problem with the electronics of the heater.
After checking the above, a service call by an authorized tech may be necessary.
You can also call Raypak at (805) 278-5300 for Customer Service
Posted on Sep 10, 2010
Is there a power reset button?
You may want to make certain that the pump is running ( moving water into the heater ) in order to activate the heater. The heater will not try to fire without water moving through it. PLT code means that the Pilot is trying to ignite. If you see nothing on the display, you may want to verify voltage.They are typically wired on the same circuit. Therefore if one has correct power ( activated ) than so should the other.
May 29, 2014 | Raypak RP2100 DIGITAL POOL HEATER R206...
What part do i need when plt code comes display ?
spk I think means spark for ignition and plt means pilot so i assume the heater tried to light but the pilot light is not staying on. could be dirtly contact on the ignition spark plug or dirty pilot flame need to be cleaned and the unit serviced.
i hope this was useful.
May 28, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
Plt code comes on display ?
Plt means pilot light failure. the heater has failed to ignite. either the ignition unit needs cleaning or replacement or the pilot light valve where the flame is, has got dirty and needs a service.
recoment you get a heating service engineer to have a look at it.
ROL keep displaying on my raypak rp 2100
check gas pressure if too low it will overheat replace rollout fusible link if it happens again you might need a vent stack
Jun 23, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
RayPak 2100 series digital pool heater Code "EOL".
press the mode button until the display reads "off". Remove the four screws holding the control cover on. Swing panel down so that the back of the board is visible. Press the mode button until "RESfl" appear. Press and hold both "up" and "down" buttons for 5-7 seconds until three dashes appear (---). This resets the fault history and clears any stored faults.
Sep 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
RayPak 2100 pilot won't light heater. I'm getting PLT message.
Well your right it is your ignighter the spk is spark the plt piolet light this pc is about 200 .
THANK YOU FOR USEING FIXYA
RATE ME
Mar 29, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
1,080 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
