Question about HP DesignJet 1050c InkJet Printer
While replacing print head & cleaner system error 060308 00000008 appearing and contact hp representatives.
  • 141 Answers
SOURCE: print head failures HP 1050c
the tube system has an air leak causing a dryfire situation. air + printheads = damaged printheads. most users replace the black printhead more often than the colors. the seal where the printhead feed pin fits into the carriage is the end of the tube system. the hole in the seal becomes to large and doesn't properly seal the air out. order the tube system. complete and concise instructions are included in the box for tube replacement. this is considered an end user replaceable part. good luck! please rate this!
Posted on Oct 02, 2008
  • 53 Answers
SOURCE: System Error
System Error 21:10 refers to the Service Station, the Aerosol fan is probably dirty. Clean the station and especially the fan, check that there is no ink build up on the fan and its running freely, do a reset if necessary or replace the unit.
Good luck
Dave
Posted on Feb 18, 2009
SOURCE: Will not print black , HP PSC 1610 All-in-One
Here was the solution. You MUST use HP brand black cartridge. Originally I purchased a #94 Office Max brand black cartridge. After it did not work I took it back and they gave me a second Office Max brand and that did not work either. So I took it back and they sold me an HP brand (I only needed to pay the difference in price so Office Max was good to work with). I installed the HP #94 black cartridge and everything now works.
Posted on May 11, 2009
  • 99 Answers
SOURCE: hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Posted on Aug 01, 2009
SOURCE: hp photosmart error code 0xc05d2381. does this
french oeioe
Posted on Aug 16, 2009
Error Oxc 18a00001
you may need another print head with that error code message. I would contact HP Total Care (1800-474-6836) and check to see if your printer or print head is in warranty, and it could be replaced.
Error 0xc18a0001
Jan 20, 2016 | HP Photosmart D7260 Printer
System error 0B000D 00000005
Hi, I believe this error occurs when there is no 24 volt supply to the PCB. Go back and check you have plugged all the connectors back in correctly.
Thanks
Sep 29, 2014 | HP DesignJet 1050c plus InkJet Printer
Printer heads errors
switch on the machine wait till error appears on panel, go to the system open internet explorer type IP address enter you can view the entire printer over view.. check which print head showing faulty, ask to replace the head open top cover of the printer open print head cover remove print heads clean print head contact pcb as well as carriage contacts insert print heads back then check for the print head recognition, printer will perform its own priming and all wait till ready mode comes onece ready mode appears.. print heads are OK.. if not replace faulty print head/s.Most of the cases cleaning is enough.
Jan 08, 2012 | HP DESIGNJET T1120 44 Printer
Why has my hp designjet 1055cm has started printing everything with a red tint
Check helth condition of print heads, per form align print heads if nozzles are clogged replace print heads & cleaners..
Sep 09, 2011 | HP DesignJet 1050c plus InkJet Printer
Fixing unit error.\r\nTurn off and unplug the printer, and then contact the store where you purchased the printer or your service representative. When contacting the service representative, inform them of...
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Dec 19, 2010 | Canon LASER SHOT LBP-2900 Printer
I keep getting System Error 0A0000 00000002
The error indicates low air pressure to the ink supply station. There is either a leak or the Air Pressure System (APS) is bad. Check for ink inside the rear door to the Ink Supply Station (ISS) and at the print head locations at the carriage.
If there is ink leaking at the ISS, replace the ink cartridge that is leaking. If there is a leak at the print head, replace the ink tube system. If there are no leaks, replace the APS. See the following link for parts: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Apr 14, 2010 | HP DesignJet 1050c InkJet Printer
Five flashes pause then a further 5 flashes
This error mean "non installed or defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number is QY6-0057.
Nov 25, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
5 amber flashes
Operator error.
Press printer's RESUME button.
If this doesn't clear the error, cancel printing and turn the printer off and then back on.
When press Resume button, ip3000 not responed(not print)
Aug 07, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
HP DesignJet 1050c InkJet Printer Logo
206 people viewed this question
Seeker5211
Seeker5211
