Question about Canon Pixma MP450 All-In-One InkJet Printer
Error code 6000
I have a MP960 There is no paper jam just error code and blinkinglights. Have done the disconnecting restart etc. no luck. Any other suggestions?
Gloria
    Genius:
  • 2,035 Answers
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on May 27, 2008
How to fix code 6000 mx922
The 6000 error is a generic internal error code. Unfortunately, it could mean one of many things. To resolve the 6001 error, please follow the following steps:
1. Turn off the printer and disconnect the power cord and USB cable.
2. Remove paper from the automatic sheet feeder (in the back).
3. Gently pull jammed paper out, if any.
3-1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
3-2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
4. If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
5. Check ASF with a bright light to check for obstructions. Remove any if found.
6. Open the rear cover to check if the paper is jammed.
7. Pull out the cassette and check if the paper is jammed inside the cassette area.
8. Load paper back into the ASF or cassette.
9. Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
If the above procedure does not resolve the error, the unit would require service:http://www.usa.canon.com/cusa/page.action
May 03, 2014 | Canon Pixma MX922
Errror code 6000
Error code 6000 appears when the paper jam, power off the printer and remove carefully the jam paper and power on the printer:
Nov 09, 2010 | Canon Pixma MP450 All-In-One InkJet...
Erreur code 6000
Error 6000 may be a paper feed error. Perhaps there's a paper jam, but it may be a malfunction (a.k.a the printer is broken).
Is it still under warranty? If so, contact Canon immediately to get it repaired.
Canon's 800 number is 800-828-4040. There hours are 8 A.M. to midnight Eastern Time., last I checked.
Good luck! and please rate me if this information helped you. Ex2bot
Sep 16, 2010 | Canon PIXMA MX850 Multifunction Printer
Error code 6A00 print head not moving. Sometimes
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Nov 18, 2009 | Canon PIXMA MP960 Printer
Error 6000 paper jam duplex
Sir,
1. Remove the paper tray.
2. Disconnect the power cord, wait 5 seconds, then plug it back in.
3. The printer will reset and eject the paper. if the paper does not eject, try to remove it manually.
4. Replace the paper tray.
5. Press the Print button on the printer to resume printing.
ThanksGood Luck
Aug 11, 2009 | Canon MX310 Office All-In-One Printer
Printer error 6000, on a canon Mp610 printer. i tried what the manual said [disconnect USB cable... etc] shut down, restart. printer still says error!!!!
6000 says the paper feed is not able to roll. Either something has fallen in to stop the rollers, or the encoder on the left hand side is too dirty to see the marks on the wheel.
Jul 13, 2009 | Canon PIXMA MP610 InkJet Printer
Error code 6000
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Apr 27, 2009 | Office Equipment & Supplies
When the printer is turned on the following message occurs - 6000
The error code: 6000 is explained in the service manual as "Paper feed error".
It could be a sensor issue or something that's fallen down/into the printer that's jamming rollers or similar.
I'd check for any paper jams, foreign objects in the rear paper feed, etc..
Given that you have a MP540 I'm guessing it may still be in warranty so if that doesn't solve it I'd recommend taking it back to your retailer and getting it resolved.
Can I ask if this has done this since purchase or just started doing it?
Feb 19, 2009 | Canon PIXMA MP540 All-In-One InkJet...
Canon MP960 Error - Paper Output Slot
Sounds like you made the right checks for jammed paper. Try uninstalling the printer, disconnect the printer from the computer and then with the printer disconnected, re-install the software. During the software installation the program will ask you to connect the printer. Only then connect it. When finished it should work. If not we can look at other solutions. Bud
Dec 03, 2008 | Office Equipment & Supplies
Canon Pixma MP450 All-In-One InkJet Printer Logo
83 people viewed this question
old marine
old marine
