Question about Eureka 431A Optima Bagless Upright Vacuum
Where can i buy A NEW FILTER FOR OPTIMA 33.0 - Eureka 431A Optima Bagless Upright Vacuum
Need filter everstar vc 9550
I'm needing a filter for my everstar 3 stage heap vacuum model bck 9550, do u know where I can purchase one?
Oct 27, 2013 | Eureka 431A Optima Bagless Upright Vacuum
Ho wdo I change the filter on the Eureka optima.. HELP!!! thank U !
open the canister like you are going to empty out the dirt canister. there will be a tab to push in near the back side of the machine on the lid of the dirt canister. It has a push tab at the back and a stationary tab that locks in at the front.
If you do not have a new filter handy, you can brush out as much dirt as you can with say an old tooth brush or paint brush. you will want to replace the filter on this unit at least once a year.
good luck.
Nov 19, 2010 | Eureka 431A Optima Bagless Upright Vacuum
Eureka optima model #431 type bx have misplaced filter trying to find replacement filter
you should be able to get this filter at any eureka or beam dealer part number is 62396
Feb 27, 2010 | Eureka 431A Optima Bagless Upright Vacuum
Very little suction? Someone give me an answer please.
You must have something obstructing the airflow. There is sometimes a small trap door under the vacuum where the brush is located. Open that door and see if there is something jammed in it. If you don't have the door, then there is an obstruction somewhere in the vacuum. You should also look in the hose.
Jim
Jun 10, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Eureka Optima vacuum has suction at the hose but not at the floor. I took out the filter and it still isn't suctioning so I don't think it is the filter.
it sounds like you have a plug. check where the hose goes into the back of vac. it should have a clip remove this and see if there is a plug there
May 18, 2009 | Eureka 431A Optima Bagless Upright Vacuum
CHANGING THE FILTER
You have to install the filter in the dust cup lid first, then put it in the dust cup. There are some clips that filter will fit into on the lid. Also, take a look at the maual. http://www.eureka.com/service/manuals/75287_eng.pdf
Feb 26, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Eureka Wide Track Superlite vacuum roller brush motor
Don't know if you can find something that will work, Eureka doesn't make these motors available thru them. Try some local shops or a place that sells small motors.
Jun 14, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Eureka optima
The filter probably needs a darn good clean. If it is clean, wipe the inside of the canister with a clean cloth to get rid of static.
Oct 13, 2007 | Eureka 431A Optima Bagless Upright Vacuum
Eureka 431A Optima Bagless Upright Vacuum Logo
301 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
