Question about Nikon Coolpix 5600 Digital Camera
Subjects are glowing
It's kinda hard to describe my recent problem..my subjects seem to have a glow around them. It actually looks kind of neat on some pics, but obviously I'd like to not have this problem..;)
here's an example..
Thanks for any help.
    Problem Solver:
  • 5 Answers
You probably have some moist (grease) on the lens, or the optics has been damaged, i.e. lenses are not longer aligned correctly.
This effect can be obtained by putting some vaseline on the lens, thus spreading the light that falls into the optics.
Posted on Jun 01, 2008
No heat from my whirlpool dryer... is there a thermostat? already replaced the glow bar
Yes, there is a thermal fuse. It's a one inch strip of whitish plastic with two terminals sticking up on each end. Just look around behind the blower housing, it's usually somewhere around there.
Check that thermal fuse for continuity if your glow bar isn't glowing at all.
If your glow bar IS glowing, then the culprit is usually the coils for the gas valve.
Oct 18, 2014 | Dryers
If i let my 7.3 ford diesil set 4 or 5 hour it hard to start again
A diesel uses glow plugs to fire the fuel when it is first started. If one glow plug quits working the glow plug controler shortens the time that the rest are on. If two its even shorter. If the wait to start light goes off sooner than it used to check the glow plugs.
Glow plugs can be checked easy with a test light.
Unplug a glow plug. (located on the head by the injector).
Just hook up a test light to battery positive (+) and touch the other end to the glow plug connector. If the light lights that one is o.k. Check all 8. Replace any that dont work.
If the glow plug system is working then check for fuel leaks. If fuel can leak out than air can get sucked in the fuel system and cause a hard start.
There is also a transfer pump on the frame rail under the drivers seat. This can be a issue if it fails.
When the key is first turned on this pump will come on and prime the system. You can hear it if you get close to it.
I hope this helps you. Re-post if you need more info.
Feb 14, 2011 | 1988 Ford F 250
Gas Oven - no flame at Bake Baffle - Glow Bar glows fine
If the glow bar is working (glowing) it is the gas valve. BUT, the glow bar can also actually glow and still not be working 100% and letting enough current through to the valve. You could swap an identical valve out to check it, if you don't have a meter. It's more than likely the valve though.
Jul 23, 2009 | Kitchen Ranges
VW passat glow plug problem
Yes you have a defective glow plug relay if you have your owners manual you can find it and replace it, the unit also has a timer on it, if you don't have a book look for the glow plugs and follow the wires from the glow plugs to where they terminate there you will find the relay unit and replace it, to test the glow plugs you remove the wires and test each plug by pulling off the wire and with a cheep ohm meter touch one end to the glow plug and one end to ground if it swings almost al the way over it is ok, if it dos not move then that glow plug is bad. if you find 2 or more bad then replace them all, and if a glow plug has shorted and caused this problem you will have to replace the glow plug relay. Good luck.
Jun 19, 2009 | 2003 Volkswagen Passat
No image on monitor
Looks like the Video card, or Video chip has bought the farm
Try hooking up to another monitor to confirm where the problem is.
Jan 30, 2009 | ViewSonic VX922 19" Monitor Flat Panel
I just replaced the glow plug relay dur to hard starting
HAVE YOU REPLACED ALL YOUR GLOW PLUGS RECENTLY? EVEN THOUGH THE GLOW PLUGS APEAR TO BE WORKING I FIND WITH AGE THEY NO LONGER HEAT UP QUICKLY ENOUGH BEFORE CONTROLER TIMES OUT. THEREFOR CREATES A HARD OR NO START CONDITION.
Jan 17, 2009 | 1992 Ford F250
Prescario v6000 mute buttons and sound button dont work
you have to install the driver
get you driver driver through hp site
Oct 04, 2008 | HP Compaq Presario V6000T Notebook
Frigidaire gas range FGF337
The ignitor should be almost a white hot color very bright . If it is orange or kinda reddish, the ignitor probably isn't getting hot enough to open the saftey valve. you could check the amp draw on ignitor , but most of the time if the ignitor isn't glowing bright almost white , that is probably the problem, besides that if and only if ignitor was good then i would look at the saftey valve. My money is on the ignitor.:)
May 19, 2008 | GE JGBP28 Gas Kitchen Range
Brightness Problem
If it is a glow around the edges, it could be one of two problems. The Picture tubes could be getting soft or weak, or there is a bad capacitor in the screen drive circuit or in the sweep power supply. If you have a service manual and a multimeter, you should be able to locate a bad capacitor with an ESR type capacitor checker. If you do not have any knowledge on solid state repairs, please call in a pro to assist you in this repair. Good Luck.
Mar 14, 2007 | Philips 60P8341 60" Rear Projection...
Nikon Coolpix 5600 Digital Camera Logo
16 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
