posted by ronse on May 13, 2008
Spacemaker Microwave completely no power.Checked hardlines and internal wiring for current and all was good except something called "thermal hood" (fuse?) located next to fan. This is showing no current using a multimeter. i ordered a new one and the new one also has no current...is this correct showing for this part?
Solution #1
posted on May 15, 2008
My microwave was totally dead. Things I discovered:
1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this!
2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace.
For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for GE Spacemaker Microwave Oven
Email this problem
Email this problem
Can you Help with these Microwave Ovens problems?
GE Spacemaker (JVM1640SJ) Microwave Oven
Model JVM 1650sho1
Model JVM 1650sho1
Microwave will trip circuit... Answer This...
NO LIGHT OR TURNTABLE WORKING
the light on the microwave no... Answer This...
ge profile microwave not...
how do you get the cover off so... Answer This...
Need to replace light bulb for...
I don't know where to go to... Answer This...
Hi my Microwave will not heat...
Morning My Microwave does... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
Find Parts
