Question about Compaq Armada E500 Notebook
My compaq armada e500 pops up vmm32.vxd is required to run windows. If this file is not in ur path..you may need to reinstall windows
    Guru:
  • 689 Answers
Youll have to reinstall if it stalls
Posted on Sep 07, 2010
I have upgraded my compaq armada e500, it has all the requirements to upgrade from windows 98 to windows xp. i tried to install a fresh copy of xp, the set up stops in the middle. i tried several times...
We check of the requirements of you loptop to isntall a windows Xp so we determine that windows xp you installed is not a genuine..
maybe the OS that you installed is not a genuine so you cannot install .it.try to install a genuine OS
Aug 31, 2011 | Compaq Armada E500 Notebook
I deleted windows\system\vmm32.VXD on my etower633id
You must either recover that file from a backup, copletely reinstall windows, or use the Windows Recovery disk that came with your computer to repair the partition.
Mar 20, 2011 | E-Machines etower 633ids PC Desktop
It doesnt want to start it says what im describeing.
From http://support.microsoft.com/kb/194679:
Cause:
This behavior can occur if the Windows\System folder is missing or renamed, or if the PATH line in the Autoexec.bat file is missing or does not include the Windows\System folder.
To resolve this behavior, use the appropriate method:
Method 1 loadTOCNode(2, 'resolution');
  1. At the command prompt, type: dir vmm32.vxd /s If the Vmm32.vxd file is not found, you must install Windows 95 or Windows 98 again. If the Vmm32.vxd file is found, note the folder in which it is located, and then continue with step 2.
  2. At the command prompt, type the following commands, pressing ENTER after each command cd windows
    ren folder system
    where folder is the folder you noted in step 1.
  3. Restart your computer.
Method 2 loadTOCNode(2, 'resolution'); Using a text editor (such as Notepad), edit the Autoexec.bat file and add or modify the PATH line so that it includes the Windows\System folder. For example, add the following line to your Autoexec.bat file: path=c:\windows\system
Hope this helps,
-LL
Mar 16, 2010 | Toshiba Satellite 2060CDS Notebook
Hi... my problem is my PC cannot find a VMM32.VXD
You can find instructions on how to get around this issue here. You will need to be able to boot to a command prompt from a Windows Startup disk. When using these instructions, be very careful about the commands you enter. You must make sure you don't mistype anything since it could cause more problems.
Jul 07, 2009 | Microsoft Windows 98 for PC
Was downloading windows sp3.Download stopped now get continous reboot with message:auto program not found-skipping auto check.Armada e500 laptop.
Turn of the computer and press F8 every few seconds.
A box will pop up with a list of choices.
Choose Safe Mode with Command Prompt
Let me know when you get this far.
Feb 25, 2009 | Compaq Armada E500 Notebook
Vmm32.vxd problem on windows millennuim edition its saying load windows loader dont knoe it please help have no disc omputer given to me thanks
just go to start button goto run type regedit and press ctrl F and then type vmm32.vxd and press find and if the file that type is showed delete the vmm32.vxd and press F3 to search again the if you find another file like that again just delete it and its finished restart your computer.
Nov 25, 2008 | Computers & Internet
Compaq Armada E500
your product key may be on a sticker on the bottom of your laptop.
Aug 27, 2008 | Compaq Armada E500 Notebook
The following file is missing or corrupted; C:\WINDOWS\SYSTEM\VMM32.VXD type the name of the windows loader (e. g., C:\WINDOWS\SYSTEM\VMM32.VXD)
That is a special file, created during Windows installation. Every computer uses a different VMM32.VXD file, so you can't simply copy one from another system and expect it to work.
If you can't find that file by searching the system in DOS, you could wipe the drive and reinstall Windows again, or do a repair install, installing Windows on top of itself. That should force the creation of a new VMM32.VXD file, and that problem should be history.
If you DO find the file somewhere on the HDD through a DOS search, copy it into the Windows\System folder, then reboot the system.
Jul 23, 2008 | Computers & Internet
Compaq Armada E500 Notebook Logo
43 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
