Question about Cell Phones
W58i half of the buttons stopped working , call button up key back key delete key
    Novelist:
    Champion:
  • 202 Answers
I think u need to clean the panel / change the back panel (flexible) of the keyboard
IF still not responding, take to the nearest service centre
I hope that this solves your problem
Bye
Have a nice day
Posted on May 13, 2008
The lower keys wont work without harmonization
Sounds like you have the accompaniment function selected. Find the button on the front panel and deselect it and you will get full control back
Feb 01, 2014 | Casio Keyboard Power Adapter
Message box full-cannot cleat
On most GE 27***GE-series phones the DELETE key on the base is to the left of the down arrow for MESSAGES/CID keys; the DELETE button is the button on the far left on the bottom row of tiny keys.
Press the button briefly during play-back to delete the message being played, or press and hold the delete button for a full 2 to 4 seconds to clear ALL messages.
Nov 23, 2013 | GE 27928GE2 Cordless Phone
Govideo model dv2130
You should be able to get into a list of timer recordings by this method:
1 Open “Initial Setup” menu
Press the SETUP button or the TIMER button while the DVD is in
Stop or Play mode.
2 Select “PROG”
Use the ??/?? buttons to highlight “PROG” then press the
ENTER button.
3 Select the recording to be deleted
Use the ?? and ??/?? buttons.
Press the ?? button to move to the next setting.
The squares are the arrow keys! You should be able to delete the settings using these keys or some other key.
Next time you set a timer recording make certain you don't set the weekly setting!
Apr 29, 2010 | GoVideo Go Video DVD/VCR Combo
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Dec 27, 2009 | Clarity Lands Phones
P and delete button not working on g1
did you ever get a solution to this? my G1 just did this today
Jun 16, 2009 | HTC G1
Ris, Hold and Feature Buttons
Have you tried unplugging the set?
Try unplugging the set wait for about 15 seconds then plug the set back in... i he set will flash for a while, stop, and flash for awhile... just be patient and it will return.
Then test to see if the Feature, Rls and hold buttons work again.
PS those buttons are hard coded, and cannot be erased, they may fail, but they will not erase.
Maybe you also have a stuck button, that is affecting the set?
Jun 01, 2009 | NorStar Meridian M7310 Phone
Keys won't work on sanyo mm 8300 phone
I used a very small eyeglasses-repair flat-bladed screw-driver that was the same width as one side of the tri-angle screw head to remove the screws on half of a sanyo scp-8300 phone that I found on the road. I do advise caution when releasing the hidden plastic clips around the edge of the phone where the seam between top and bottom is. Once open, you will find a ribbon-cable that leads to the top half of the phone, a rubber pad that has all the keys on it, and the phone's circuit-board, where there is a white plastic sheet overlaying the actual physical buttons mounted on the circuit-board. My advice would be to gently clean the rubber key-pad with warm water and dish-soap. Also, check for sticky gunk around the edges of the key-holes in the plastic case of the phone, if you find some- carefully wash it off with a wet tissue or a cotton swab, use rubbing alchohol if it won't clean off. But, be aware that some plastic can melt or turn gooey when cleaned with alchohol, or it might just remove the color from it. Hope this helps, TechnoWolfy.
Feb 12, 2008 | Sanyo MM-8300
Delete button, plus sign button not working
try to hit fn key on it once that flips throw the #s and letters on it thx nick
Feb 04, 2008 | HP Pavilion dv6000z Notebook
Cell Phones Logo
110 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
