Question about Zenith Z50PX2D 50 in. Plasma HDTV
No Picture, but have sound
Can you help me figure out if my tV needs a simple bulb replacement? And how do I figure that out? The manual was absolutely no help. The sound is great, but there is absolutely no picuture, as if the tv was in the off mode.
  • 1 more comment
  • TippyTNT May 23, 2008
    I have a plasma 50" from Zenith. While watching it, I heard a pop like a firecraker go off and then I smelled what appeared to have been a blown capacitor. I have sound but there is no picture. I'm wondering if it is just the bulb or is there something else that could be worse. Can anybody help me out?
  • Anonymous May 30, 2008
    TV was on for about 10 minutes it sounded like a gun went off 2 really loud pops and then no pic. can still change channels and get sound
  • kokoroko Jun 28, 2008
    Don't know how it happen. But the kids were playing a video game when they lost picture. There is sound, and the screen is not quite blanc or black but have some kind of pink lines or sparkles on it. Is there any solution?
  • 1,342 Answers
This is a poor manufacturing defect. Visit this forum for more information on the issue.
Posted on May 19, 2008
Mitzibushi Tv model WD-65638 no picture no sound
Youre lamp has failed. you need to replace the lamp. Refer to the manual to see how to replace it. It only requires 2 or 3 screws on the back to be removed. Please check the manual.
You need a 915B441001 lamp. 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi Televison & Video
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
Lost picture
When was the last time u replaced the projection bulb,yes it could be that simple the projection bulb it dead.The bulb last only about 1 or 2 years,by using the tv on about 4 or 5 hours a day.
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound but no picture
no bulbs to replace here, i might have better news for you. Toshibas with this time frame has an inverter problem. turn tv on tilt back wards at 45degree angle and flack a light to the screen and look closely if you can see the image the replace the inverter units. to help you see hit menu on remote, the menu is white so will make it more visible. If you did want to replace the inverters they are like 60-80 $ for hte pair and simple to replace.
Apr 27, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Picture is gradually getting darker
It sounds to me like your bulb is going out. You have a rear projection TV, and since so, there is a bulb that shines the image onto your screen. Because of this, you need to replace the bulbs after awhile. Call customer support or look around online for a replacement bulb and directions on how to change it. Very simple, but takes a little time and effort. :D
Mar 20, 2010 | Hitachi 46F510 46" Projection HDTV
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
Turn tv on, sound comes on but no picture, power light blinks,
The clear bulb located back left side needed to be replaced. Too much heat causes the bulb to burn out. Simple fix. One screw to open door to bulb compartment. Two screws to remove bulb assembly. Thank goodness for extended service warranty which paid for it. This is the second one in three years. At the price of $200 for bulb and $100 for trip and labor, this is not an inexpensive fix. Anyone purchasing a projection tv should get an extended warranty.
Apr 08, 2009 | RCA P61940 61" Rear Projection Television
PT-52LCX66-K picture is darker than normal...
Sounds like you need to replace your lamp. The lamp number for this panasonic TV is TY-LA1001. Lamps run anywhere from $120-$250.
Nov 12, 2008 | Panasonic PT-52LCX66 Projection Television
RCA 52' Projection TV Model 52W19B Need help with bulb replacement
bulb? what model do you this a d52w19? if this is a rca itc222 chasis unfortunatly it has no bulbs.. it should have tubes and these are not fesable to change
Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
TV won't power on
Your model doesnt have a bulb. It has 3 CRTs instead. Sounds like something minor in the start up voltages. thereby allowing the start up relay to click then other times the relay doesnt click. So its either standby or start up supplies where the fault is. You can get a manual here at this link and also free support to help you figure it out.
Mar 18, 2008 | Samsung HCL4715W 47" Rear Projection...
Zenith Z50PX2D 50 in. Plasma HDTV Logo
78 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
