Question about Toshiba Portege 3505 Tablet PC
Disk error When i try to open my pentablet i am always getting the below error "A disk read error occured Press Ctrl+Alt+Del to restart " I don't know what could be the reason. Can any one guide me to resolve this problem.Even i don't have DVD/CD ROM to boot OS from bootable disk.
    Problem Solver:
  • 23 Answers
Does the laptop have a usable cd/dvd rom drive?
Posted on May 13, 2008
Can't close tabs in google
OPEN TASK MANAGER //WITH (CONTROL/ALT/DELETE KEYS) HIT ALL 3 KEYS AT SAME TIME. CLOSE CHROME AND RESTART. IF THAT DOESNT WORK, DO A HARD RESTART.
RUN A VIRUS SCAN, CLEAN OUT YOUR CACHE
Jan 05, 2015 | Tablets & eReaders
Freeze up
reboot it 2-3 times or open up task manager by pressing
alt+ctrl+delete simultaneously and look for back ground apps
Apr 05, 2014 | Microsoft Surface RT
Dell tablet dont go pass the dell sign when i turn it on
Power on the system and immediately press the Power + Security (Ctrl-Alt-Del) buttons simultaneously for a
second. This will allow you to run a diag on the hardware. Do all the tests. If all passes, then you may need to reload the operating system.
Nov 18, 2013 | Dell LATITUDE-ST-128-R Latitude St Atom...
How do I access task manager?
There are several ways.
  • While logged in, press ctrl + alt + del, select task manager from menu
  • Right click on an empty area of the task bar and select task manager
  • In Windows Vista/7 click the window button and type taskmgr and hit enter, windows xp click start button, run and type taskmgr, in Windows 8 hit Windows Key + r then type taskmgr.
Dec 03, 2012 | Sharper Image Tablets & eReaders
I want to know how to reinstall toshiba portege m200
This is in case you cannot boot into windows but you can get into bios:
Open your disk drive. Insert windows operating system disk into your disk drive. Restart your computer.
If you can get to the stage where you can see see bios entry key then keep pressing whatever key it is that you press to get into bios at start up.
Select the option that let's you choose the drive to boot from, mine is in advanced bios options. then go to either something like bios features or change boot drive.select whatever drive represents your CD-ROM drive and select it to be the first boot drive.
then save exit bios, I do this by pressing escape then Y to save and boot from the rom drive.
This will let you restart your installation of windows and
re-format the drive...
If you can boot into windows:
Then either re-format the drive and delete the partition when you do or...
Run a recovery of the system by installing your disk and letting it get to the stage wher it asks what action/task you want to perform and press r when prompted then follow the prompts to repair the files. This might not work though,
you could even try running a disk check as maybe a lucky chance of repair if you can get into windows.
If your PC keeps trying to boot from the CD drive after repair then re-enter bios at start up and change your hard drive back to first boot device to boot into windows.
It's better if you re-format though as repairing windows can be a little tricky.
Aug 01, 2011 | Toshiba Portege M200 Tablet PC
Hi I have an Acer Travelmate 6492 first I wanted to reset it to factory settings I could not manage that & now it is not booting it's just flashing on top
Seems like your hard disk is not getting detected.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Start tapping the DEL key as soon as you power on the computer.
This will take you to the BIOS screen.
If it doesn't, you will have to check whether your hard disk is faulty with a local technician.
Once you get in to the BIOS screen, press F9 to load the default settings.
Than press F10 to save and exit.
Once you do this, the computer will restart.
Hope this helps.
Dec 21, 2010 | Acer TravelMate C112TCi-SP2 Tablet PC
Sir i had bought sony vaio laptop which showing text; boot mgr missing and press ctrl alt del to restart, pls give me a solution
http://cyberst0rm.blogspot.com/2007/04/how-to-fix-bootmgr-is-missing-in.html
I assume you are running vista because bootmgr.exe is used to run vista from startup. "bootmgr" is short for boot manager, and without this, your computer simply doesnt know how to start vista from your hard drive.
To fix it is quite simple. First of all go into your BIOS menu (usually press F2 or DEL when prompted when you turn on your pc). Make sure your cd/dvd drive is set to be your primary boot device. This way you can run your setup disk in the next step.
Insert your Vista install disk and restart your system. Press any key when prompted to begin running the dvd. Wait for it to give you a list of choices. This may take a while as it often stays a blank screen for some time. Choose "repair", and the setup will auto detect your operating system. It will also fix your bootmgr.exe at this point. If it does not, you can go on to the next screen and choose "startup repair".
Aug 20, 2010 | Sony Tablets & eReaders
Want to reinstall OS on compaq tc4200. don't have passwords..
If the BIOS password is set, you'll need to return the device to HP/Compaq to get that reset. Only other option I can think of would be to whip the hard disk out and see if it'll boot from a CD at that point. If that is the case, you could theoretically put the drive in another PC, wipe it completely and then reinstall it. The machine will try to boot from HDD, fail and then boot from CD next.
Mar 09, 2010 | Compaq tc4200 Tablet PC
I bought this computer at a garage sale and it is set up to log on by pressing ctl,alt,delet but I don't have the password is there any way around this
Try this:At startup, before you get the Windows splash screen,hit the F8 key to see if you can start in safe mode. If you can, the password for administrator may not have been set, in which case you can log on without entering one.Otherwise, you'll have to do a reinstall of Windows or, when starting the reinstall, when the computer says it's loading drivers, etc, you can press CTRL F10 and that should get you to the screen where you can see the passwords. Here's a link: http://www.mydigitallife.info/2006/11/25/easily-login-to-windows-xp-with-no-password-administrator-account-backdoor-trick/
Jun 10, 2009 | Toshiba Portege 3505 Tablet PC
Toshiba A200 laptop screen
if you got ATI i think its shortcut:
ctrl + alt + up to get him back to normal.
Jun 15, 2008 | Tablets & eReaders
Toshiba Portege 3505 Tablet PC Logo
339 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Alun Cox
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
