HOW TO REPLACE THE INVERTER BOARD ON A SANYO DP32647 32' LCD TV?
  • storm47 Sep 07, 2010
    ok thank you
  • 11,800 Answers
All you have to do is to make a very detailed drawing with all the cables and their positions (label them to be sure), touch a metal part on the tv to ground yourself, take them out gently (be very careful not to rip a wire), unscrew the board from the chassis, ground yourself again and install the new one and plug the cables accordingly.
Posted on Sep 07, 2010
  • 4,889 Answers
Inverter board is pretty easy to replace. It has 3 connectors. One of them goes into the power supply and the other two go into the panel. Its as simple as unplug them from the old board and plug them into the new board. Only problem is ESD(Electro static discharge). Make sure that you touch Some grounded metal before you start working. That should take care of the ESD. Also make sure you unplug the set from the mains and try not to touch any capacitors. They have residual voltages and will give you a nasty shock if you touch them. As an added safety measure wear Hawai slippers.
Backlight inverter board for LG TV What is correct part to restore illumination to TV
LED TV Repair Tutorial - Common Symptoms & Solutions ...
? 6:43
https://www.youtube.com/watch?v=8HG7efTMj78
Jan 3, 2014 - Uploaded by ShopJimmy.com
LED TV Repair Review & Overview-Common Problems - Symptoms, Solutions Click Here to BUY TV REPAIR PARTS: ...TVs inputs and outputs, this main board is connected to thebacklight inverter/LED driver via this ribbon cable. ... ofillumination for the screen and the board that drives thatillumination.
LCD TV Repair Tutorial - How to Replace the Backlight ...
? 2:30
https://www.youtube.com/watch?v=s3r1GZCA0K4
Dec 31, 2012 - Uploaded by ShopJimmy.com
Philips TV Repair Flickering Image On TV Screen Tutorial Guide How to ... Inverter on LCD TV Easy Fix Help Click Here to BUYTV REPAIR PARTS: h... ... How to Replace the Backlight Inverter Board in LG & Philips LCD TVs.Missing: restore ‎illumination
Sanyo 42 led lcd tv - Engine cork
Jan 27, 2016 | LG Televison & Video
Replacing t-con board on 39" sanyo LCD tv
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Jan 26, 2016 | Sanyo Televison & Video
My Sanyo Television model#DP26640-07 has sound &a blank screen ?
Nov 12, 2015 | Sanyo 42 in. LCD TV
Which replacement board to order to fix LCD with no picture, but sound.
Oct 26, 2015 | Sanyo Televison & Video
My tv has sound but no picture what part would I need to get to fix it? Its a Sanyo 2008 LCD
Jul 15, 2015 | Sanyo Televison & Video
New sanyo baklight inverter making loud buzzing sound
Oct 24, 2014 | Sanyo DP42848 LCD TV
No picture Sanyo dp42848
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 08, 2014 | Sanyo DP42848 LCD TV
I own a sanyo "26
Tv now have it on green LED power on for good and tv flashes of pictures only for few min,than dies and have sound left only?Yes,take the tv aparts.U have all the tools and understanding basic electronic also can do basic soldering work too?Check the tv power supply board,that the board where the power a/c cord plug into it.Check the tv power supply board carefully for dead and dying components parts call capacitors.These dying and dead capacitors parts most likely all of the times,will bulges up or puffing up onto it tops.Changes all these dying and dead capacitors parts components,will solved this problems 70% of the times.If the tv power supply board it is good and no dying or dead capacitors component at all.Than the tv a long board that call the LCD inverter board it is dead.This LCD inverter long board are to helping the LCD screen panel to have a backlight to produced a picture.The tv long LCD inverter board have no parts for sale indivitually,al way have to buy a refurbish whole long LCD inverter board for the replacement.Also if you have no tools and soldering skills to fixed the power supply board by replacing capacitors component parts indivitually too.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a long LCD inverter board for the replacement.
May 28, 2011 | Sanyo DP26649 26 in. TV
My sanyo hdtv shows no pictures when you turn it on (the screen is black) but you can hear the audio. The remote control can change the channels and volume up&down but the picture won't show
Good day!
The problem of your TV could be the inverter board or the cold cathode light is busted.
Follow this instruction on how to fix that problem:
  1. Remove the back cover of your TV.
  2. Look for the Inverter board.
Inverter board looks like this:
3. Check the input voltage of the inverter board if have 24vdc.Using multimeter (range on DC)
4. If you have 24vdc,check the output voltage of the inverter board it should have 500vdc.
5. If you don't have 500vdc output on the inverter,replace it.
6. If the you have the output voltage on it,the problem could be the busted cold cathode light (C.C.T).Replace it.
I hope this solution will be helpful.Thank you and don't forget to rate my answer.
May 07, 2011 | Sanyo DP32648 32 in. LCD TV
My Screen Went Black and i can only hear Audio.
Ur tv the LCD inverter board it dead.This board it help to get a backlight to ur LCD screen panel go through the Tuner board to produre a picture.Replaced this LCD inverter board u will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 26, 2010 | Sanyo 42 in. LCD TV
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
