Question about Sharp ELW535 Calculator
Occasionally my calculator will multiply, divide, add or subtract 'k' from my equation. 'k' is always a different value, usually something I recently used. I have been unable to find 'k' on my calculator, except when it does this. As far as I can tell, there is no pattern to when it occurs.
SOURCE: Non functional keys
don't use those keys
Posted on Apr 06, 2008
  • 8064 Answers
SOURCE: I just want to find out how to use the simple
Usually you enter the first number then you press the key ( +, -, x or /) corresponding to the operation you want to perform and you press the equal sign (=).
ex: 15+3=18
Often you can perform the operations one after the other without bothering with the intermediate results. You can do so provided you respect the priority rules: parentheses,powers, multiplication/division, addition/subtaction...)
Hope it helps
Posted on Aug 18, 2009
  • 8064 Answers
SOURCE: how to calculate to the power of
To raise a number to some power other than 2 or 3, you use the [y to the x] key. Exemple 2[y to the x] 5 = 2x2x2x2x2=32.
Hope it helps.
PS. I could not understand what you wanted with those expressions.
Posted on Sep 17, 2009
  • 102366 Answers
SOURCE: how do i program my
Press MODE to bring up the mode screen. Use the arrow keys to move down to the line beginning "Real". Highlight either "a+bi" or "re ^ theta i" depending on whether you want to work in rectangular or polar coordinates, then press ENTER to save the change. Press 2ND [QUIT] to exit the mode screen.
Posted on Feb 17, 2011
  • 8064 Answers
SOURCE: We are trying to add, subtract, multiply, and
This post is rather exhaustive as regards the matrix capabilities of the calculator. So if the post recalls things you already know, please skip them. Matrix multiplication is at the end. As to division of matrices, I do not believe that this operation exits.
Let me explain how to create matrices. (If you know how to do it, skip to the operations on matrices, at the end.)
First you must set Matrix calculation
[MODE][6:Matrix]. Then By entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix
(mxn]. Once finished entering the matrix you clear the screen.
The operations on matrices are available by pressing [Shift][Matrix]
[1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
[2: D A T A] enter values in a matrix
[3:MatA] access Matrix A
[4:Matb] access Matrix B
[5:MatC] access matrix C
[6:MatAns] access the Answer Matrix (the last matrix calculated)
[7:det] Calculate the determinant of a matrix already defined
[8:Trn] The transpose of a matrix already defined
To add matrices MatA+MatB (MUST have identical dimensions same m and same n, m and n do not have to be the same)
To subtract MatA-MatB. (MUST have identical dimensions, see above)
To multiply MatAxMatB (See below for conditions on dimensions)
To raise a matrix to a power 2 [x2], cube [x3]
To obtain inverse of a SQUARE MatA already defined MatA[x^-1]. The key [x^-1] is the x to the power -1 key. If the determinant of a matrix is zero, the matrix is singular and its inverse does not exit.
Dimensions of matrices involved in operations must match. Here is a short summary
The multiplication of structured mathematical entities (vectors, complex numbers, matrices, etc.) is different from the multiplication of unstructured (scalar) mathematical entities (regular numbers). As you well know matrix multiplication is not commutative> This has to do with the dimensions.
An mXn matrix has m rows and n columns. To perform multiplication of an kXl matrix by an mXn matrix you multiply each element in one row of the first matrix by a specific element in a column of the second matrix. This imposes a condition, namely that the number of columns of the first matrix be equal to the number of rows of the second.
Thus, to be able to multiply a kXl matrix by am mXn matrix, the number of columns of the first (l) must be equal to the number of rows of the second (m).
So MatA(kXl) * MatB(mXn) is possible only if l=m
MatA(kX3) * Mat(3Xn) is possible and meaningful, but
Mat(kX3) * Mat(nX3) may not be possible.
To get back to your calculation, make sure that the number of columns of the first matrix is equal to the number of rows of the second. If this condition is not satisfied, the calculator returns a dimension error. The order of the matrices in the multiplication is, shall we say, vital.
Posted on May 10, 2011
What are 4 different fractions that are equal to 1 1/2
Hi Anonymous,
You can make equivalent fractions by multiplying or dividing both top and bottom by the same amount, but only multiply or divide, never add or subtract, to get an equivalent fraction.
I've only shown the fraction part of your question as 1 is a whole number.
1/2 = 2/4, or 4/8, or 8/16 or 16/32 or 32/64 & so on.
Going the other way, dividing 2/4 by 2 will give 1/2.
But, only divide when the top and bottom would still be whole numbers, for instance you wouldn't use divide for odd number fractions, for example 1/3 or 3/5 etc.
Trust this helps, best regards Alan
Feb 11, 2015 | Office Equipment & Supplies
Where do I find a Manual for scientific calculator BD-6108? If I multiply or add only the numbers I put in end up on the screen but it doesn't add or multiply them. There is an "a" at the top of the
Your calculator may have a solver of equations, which you activated. It is prompting you to enter the coefficient a. Is there a question mark after the a?.
Oct 02, 2014 | Office Equipment & Supplies
Complex matrix
Is it complex or matrix? You can have only one mode at a time.What kind of equations? The solve function uses real-valued equations.
Complex numbers: You can add, subtract, multiply and divide. You can convert a number from rectangular to polar forms and vice-versa; you can calculate the absolute value of a complex number, or a conjugate.
All the operations are done in the Mode CMPLX.
Feb 04, 2014 | Casio FX991MS Scientific Calculator
How to calculate percentage
Divide 20,000 by 10,000, subtract 1, then multiply by 100 to get 100%.
Feb 04, 2014 | Office Equipment & Supplies
Answer always appearing
Minus and change-sign are two completely different things. Minus is used to subtract one number from another. When you press minus when the input line is empty, your telling the calculator to subtract. The only way it can subtract the number you're about to put in is to subtract it from something else, and that something else is the previous answer, hence the "Ans."
If you want to input a negative number, use the change-sign key. If you want to subtract one number from another number, use the minus key.
Try pressing the plus key when the input line is empty. You'll get Ans+ in this case as well, The same with multiply and divide, among others, and for the same reason.
Sep 23, 2013 | Texas Instruments TI-84 Plus Calculator
Where does the parentheses go on this problem 16-5x2-2=20
pemdas, parentheses,exponent,multiply,divide,add,subtract. best I can do been out of school for awhile! Hope it helps.
Apr 05, 2013 | Mathsoft Computers & Internet
How to calculate mode with caso fx-991ES
MOD simply calculates the remainder that is left over after dividing by the MOD parameter.
For example, 10MOD7 = 3 since you can only divide 7 into 10 once, leaving a remainder of 3.
For larger numbers, eg 389487MOD31 you start by dividing 389487 by 31, which gives 12564.09677 (on the display), however you only want the fractional part so subtract 12564 to give 0.0967741935 . This includes the lower value digits that were previously hidden. Then multiply this result by 31 which gives 2.999999999 on the display. Since the result of a MOD calculation has to be a whole number, the answer needs to be rounded to 3. If the answer doesn't easily round to a whole number, it is likely that you have gone beyond the calculators working capacity.
An alternative method is to take the integer part of the first result (12564) and multiply it by 31 to get 389484, then subtract this from 389487, giving the answer of 3.
Feb 23, 2013 | Casio FX991ES Scientific Calculator
-3/5x-8 what is the value of x when y=-11
The following solution shows how to find the value of x:
Start with the general equation given:
y = -(3/5)x - 8
Substitute the known value of y:
-11 = -(3/5)x - 8
Add 8 to both sides:
-11 + 8 = -(3/5)x - 8 + 8
-3 = -(3/5)x
Now multiply both sides by 5 to get rid of the denominator:
-3 * 5 = -(3/5)x * 5
-15 = -3x
Now divide by -3 to get x:
-15/3 = -3x/3
x = 5
The answer is x = 5.
Apr 27, 2011 | Texas Instruments TI-84 Plus Calculator
Sharp ELW535 Calculator Logo
121 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
