Question about Haier HD456 Dehumidifier
The dehumidifier will run, but will not collect any moisture from the air. The screen has been cleaned, the tub is cleaned, but no water will collect.
  • Haier Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Sep 09, 2010
The fan is operating properly but it is not pulling enough moisture out of the air. For a year now it has filled the container in about8 hours but now only about one inch of water. Is there a screen or...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Jun 25, 2011 | Kenmore Dehumidifiers
Tip
Dehumidifier VS. Air conditioner
A dehumidifier is basically the same thing as an air conditioner but both coils (condenser and evaporator) are in the same unit meaning a dehumidifier exhaust warm air in the same room it is in. running a dehumidifier would make an air conditioner run more because of the warm exhaust, when you run an air conditioner it acts like a dehumidifier and dries the air. As far as saving energy it all depends on the size of the AC and dehumidifier and the size of the room. If you want warm dry air, use a dehumidifier; if you want cool dry air run the AC but not both.
How do all these parts fit together to pull moisture from the air? It's fairly simple, but very effective:
  1. A fan collects air from the surrounding area and pulls it into the dehumidifier.
  2. As the air passes through, it comes into contact with the dehumidifier's cooled coils. These coils use condensation to pull moisture from the air. The collected moisture remains on the coils and drips into the dehumidifier's reservoir.
  3. The dehumidifier reheats the air and exhausts it back into the room.
A dehumidifier usually has a removable plastic bucket for are reservoir; most buckets also have a place where you can hook up a hose so the collected water can drain straight into a floor drain or pump. This frees you from having to remember to dump out the water. But don't worry too much about the reservoir overflowing -- most dehumidifiers also have an automatic shut-off. If you're using a dehumidifier in extremely moist conditions,however, or if you need to keep your dehumidifier on all the time, you should look into a unit with a built-in condensate pump, which regularly pumps water out of the unit's reservoir rather than simply relying on gravity to empty it as a hose does.
on May 18, 2010 | Dehumidifiers
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
I have a FDL70S1 dehumidifier that runs and runs but doesn't take out any moisture from the air. I have cleaned out the filter and front screens thoroughly but it still doesn't work. The unit...
heatman101
May 10, 2011 | Frigidaire FDL50R1 Dehumidifier
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
MY DEHUMIDIFIER RUNS BUT NO WATER IS COLLECTED AND I CAN FEEL MOISTURE IN THE AIR IN MY BASEMENT
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Aug 25, 2010 | LG LHD659EBL Dehumidifier
Haier HDN305 dehumidifier does not pull moisture from air and does not collect water in bucket
heatman101
Jul 26, 2010 | Haier HDN305 Dehumidifier
0GE Dehumidifier AHM65LKM1 not taking moisture out of the air
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
May 23, 2010 | GE AHK65LK Dehumidifier
Frostguard 36 Dehumidifier runs, but collects no water.
unfortunately it sounds as though your refrigerant leaked out. If your compressor is running and no moisture, this is probably the case. What is the temperature of the air coming out?
Jun 20, 2009 | Woods Dehumidifiers
Dehumidifier not removed moisture from air
heatman101
Aug 30, 2008 | DeLonghi DE400P Dehumidifier
Haier HD456 Dehumidifier Logo
476 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Shawn DuRee
Michael Youngman
Michael Youngman
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
