I have a toshiba tv model# 62hm195. When I turn the tv on the blue light turns on then the yellow light starts flashing. It does this for a few minutes then both lights start to flash at the same time. I can hear audio but no picture. Any ideas what this could be?
  • 85champs Sep 07, 2010
    Is it worth getting the tv repaired? And do you have a guess what it would cost?
  • 4,889 Answers
The blinking code indicate protect fault in deflection circuit(horizontal). This is gonna be a really tough one and I do not recommend a DIY(DO it yourself) repair
Posted on Sep 07, 2010
  • eagle338
    eagle338 Sep 07, 2010
    Approx may be around 200$. Its probably worth it if the set is less than 10yrs old. CRT projection tvs last longer than the modern DLP and LCD projection models.
How do i determine if my ballast board or capacitor is bad in my toshiba hd tv model no 57HM167?
The chances of the ballast failing are small on this model. Count how many times the Yellow light flashes before it pauses. Then google 57HM167 and the amount of blinks. ie " 57HM167 Yellow light flashes 3 times" That will tell you what you need to know. You can also post it here and we can help. I suspect you have a stuck fan(the fans are monitored to see if they are spinning. If not, they will not allow the TV to start up). Or you have the cover for the lamp not installed all the way. There is a switch that the lamp cover activates and the the TV will not turn on without it secured.
Apr 02, 2015 | Toshiba Televison & Video
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Toshiba 62 inch dlp tv keeps flashing green and will not turn on
green flashing for .3 sec with solid red indicates lamp problem. and do you have the manual? If so, look in the appendix for a section 'LED indications'. that gives you the code for the indications.
Good luck..
Aug 29, 2011 | Toshiba 62HM195 62" HDTV
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
Jul 03, 2010 | Toshiba TP55H60 55" Rear Projection...
Toshiba 62HM195, Loud hum noise when TV is first turned on.
I have the exact TV and had the exact same problems. It is the light engine with color wheel that needs to be replaced, and they are VERY hard to come by for this model. Our repairman has had our TV for 5 months and still cannot locate a vendor that carries the part. He said according to Toshiba, the part has been discontinued. If you happen to find one, please post. I'll do the same.
Aug 18, 2009 | Toshiba 62HM195 62" HDTV
Needs a new light engine for toshiba 62hm195
A new light engine for any DLP TV ranges from $800 to $1200. I would advise not to repair. Cut your loses. Buy an extended warranty with any new TV. It will pay for itself.
Jul 14, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba Rear Projection Screen Problem
It's a DLP right?
I think ur TV's bulb is dying...check the running hours of the bulb in the menu.
Rifaa
Nov 19, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 62hm195 repair issues
This may sound obvious but did you check to make sure that your lamp access door is properly secured? The set will not power up if the door does not contact the micro switch. Also double check all of your internal wire connections. You may have inadvertently forgot to reconnect a cable or not fully seated one. I know I was guilty of both errors at one time or another while I was working on mine.
Jul 07, 2008 | Toshiba 62HM195 62" HDTV
62hm195
It sounds similar to my Toshiba 62HM195 that I posted about except my screen is spit down the middle and my bottom half is messed up but the upper half is Ok.  I have been told it is a bad Light Engine Part # 23405481.
Oct 07, 2007 | Toshiba 62HM195 62" HDTV
Televison & Video Logo
Top Televison & Video Experts
