Question about DISH Network 311 DTV Receiver
No sound coming out of tv. I have tried 2 tv's s i a guessing it is the reciver. i have tried reseting it many times and the volume. But the tv shows a picture.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
Mikepiscitel,
If you are not getting sound on your tv, you could check your cables from the receiver to your tv to make they are secure. Have you tried a DVD player or VCR to make sure you get sound from those components? If you do get sound on those, then it might be the receiver, if the cables are secure.
Ray Calo
DISH Network
Posted on Jan 07, 2011
Sharp LC-32P70E TV: EPG suddenly not showing
hello, this sounds more like a cable or satelite problem. hame you tried reseting your cable or sat box? usually when you reset the box it will download the guide again...
Oct 16, 2007 | Televison & Video
Bose Life style 535
I had same problem once,i bought a new HDMI CABLE the salesman told me that my HDMI cable has loose grounding.
Feb 04, 2014 | Bose Lifestyle 38 System
Muted my sharp le 810 and now i can't retrieve the sound
If you push the volume button on set does it show on screen?
My guess would be the sound may be turned down on the box or tv or maybe in the TV menu the speakers may be turned off.
Does not sound (pardon the pun) like a circuit repair but like an error.
Check all audio settings or options first in the set and then the box.
Mar 21, 2012 | Sharp Televison & Video
How to reset sony tv KDS.60A2000 after replacing lamp so the warning doesn't keep coming on
With the set turned off:
RESETTING THE LAMP TIME
When replacing the lamp, use the following to reset the lamp time.
1. If the Self-Diagnostic screen is already displayed, proceed to step 4.
If not, Power off (Set to Standby mode).
2. Press DISPLAY Channel 5 Sound Volume -
POWER
3. To access the Lamp reset, press 5 until the TIME category displays.
4. Press 1 until the RSET item displays.
Mar 01, 2012 | Sony KDS-60A2000 60" HDTV
I accidently pressed the channel button on my remote instead of the volume button. I now have no picture or sound. I tried returning to the previous channel but it keeps saying " channel not...
Not familiar with your model, but the problem sounds generic. I am guessing your set is hooked to a cable tv box, and that is where you need to change channels. I also guess that when you changed channels on your TV you probably moved from channel 3 to either channel 2 or 4 and the cable tv box is not sending to those channels so you lose picture and sound. Now, more guessing, you try to put the channel back to 3 on your TV, but still nothing happens. OK, if close so far, there are a couple of things to try. First, be really sure you are actually going back to the same channel you started with. Assuming you don't actually have the signal coming in on an auxiliary line-in and that you had it coming in on a channel, you may need to reset the presets on the television so that it recognizes the one important channel the cable tv box is sending out -- just follow your television menu to select or set channels. There is one more possible easy problem ... I have seen this one happen, after getting the channel correct and reset, if it still doesn't work, you mght need to turn the set off and wait one minute, then turn it back on WHILE the cable box is ON. This can cause the set to RE-Latch onto the cable box signal. It really doesn't sound like something is truly broken or needs replacement, sounds more like a user error. If your set is still under warranty, just call the Panasonic hotline (find it in Google, and they may be able to walk you through exact instructions for your model). Hope this helps.
Aug 29, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Volume fix problem
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Good Luck! This worked for me.
Aug 02, 2008 | Yamaha RX-V659 Receiver
Sound cutting out
sub should work as long as u don't have the reciver on digital it should still work ur mains and the sub but no sound from the rears, the radio cuting out could because bye a resister failing it might not have burnt out yet but it is not working proprely if it only happens when the radios is on try to see if local stations come in clear with no antena . but if it happens when the reciver is on tv or another input take to ur closest repair shop to be fix or u might fry the mother board happen to one oif my old recivers.
Nov 16, 2007 | JVC RX-6042 Receiver
Audio noise on cold start
hi pick up the volume just a bit and so for the speakers and see if it continues to happen if soo try by putting all settings as normal( not your normal the tv's normal...speakers and volume without the reciver) if soothen the problem is in the tv's AMP which was mute all those years hope it works good luck
Mar 19, 2006 | JVC AV-32750 32" TV
DISH Network 311 DTV Receiver Logo
132 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
