The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
- The GPS device is missing it's unlock code
- The maps on the GPS device have been disabled
To
determine the cause of the message, touch the screen until the message
"No Detailed Maps Found That Support Routing" disappears.
- If
you see a "Can't Unlock Maps" message following this error, remove any
microSD / SD cards in the device and follow the instructions below for
Retrieving your unlock codes followed by the instructions for Creating
an unlock file
- If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to
https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your garmin device. Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
Retrieving your unlock codes:
- Log into your myGarmin account
- Select Manage Maps
- Select Details
- The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
- Plug your Garmin device into the USB port
- Double-Click on My Computer or Computer located on the desktop
- Right-Click on the Garmin or nuvi drive
- Click Explore
- Double-Click on the Garmin folder
- Right-Click in a blank space in this window
- Move your mouse over the word New
- Select Text Document
- Press Enter / Return on your keyboard
- Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
- Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
- Select File
- Select Save As
- Change the Save As Type to All Files
- Type gmapprom.unl in all lower-case letters for the File name
- Select Save
- Close the Notepad window
- Delete the New Text Document file
- Disconnect the GPS device from your computer
Creating an unlock code file for Mac:
- Open the TextEdit application located in the Applications folder on the Mac HD
- Click Format
- Select Make Plain Text
- Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
- Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
- Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
*nuvi x70 owners with transatlantic mapping will need to follow the
Creating an unlock code file instructions above for their U.S. mapping and then create another unlock file for their European maps:
- Click Explore
- Type
the European unlock code that is listed in the Manage Maps section of
your myGarmin account. This will need to be typed in all upper-case
- Select File
- Select Save As
- Type gmapprom1.unl in all lower-case letters for the File name
- Select Save
Enabling maps on the GPS device:
- Touch the wrench icon on the Where to/View map screen
- Touch Settings
- Touch Map
- Touch Map Info
- Select the checkbox next to the maps to be enabled on the device
is this ms word 2007? what do you mean with this " I cannot find ms word at all........." please clarify. thanks
postscript
